Ever replace the bulkhead WITHOUT lifting the body off?
mkhanshaw
mkhanshaw is offline
PostPosted: Mon Oct 28, 2024 1:42 pm    Post subject: Ever replace the bulkhead WITHOUT lifting the body off? Reply with quote
Yeah...I know what you are going to say.
Quick story - Bought a 1954 and way overpaid the more I dig. Got a fast one pulled on me by the seller...who if I reach out I am sure will claim ignorance but the reality is he/his brother did the work.
Car was so low to the ground that I could not inspect under the front.
Get it home, put it on my lift and..... grrrrr
Front end took a hard hit as some point in its life. So much so that one side of the bulkhead was ever so slightly pushed rearward, and the steel cracked near the threaded sections.
Their solution? Just permanently weld a new aftermarket carcraft beam to that broken side and be done with it. Bolted as normal on the other side. What a mess.
I want to install a better front end. Spoke with Russ at Oldspeed. He is down to do it. I do not want to bring this mess to him to fix as it is.
I ordered a new bulkhead to be welded in. I have a fantastic fabrication shop near me fully capable of welding it in. I really only need from the hump forward....not the Napolean hat section.
My goal is to see if someone can do all the repair without having to lift the body off. Why? Most shops do not have room and it would double my cost.
If they cut the crapwork off the front, leaving just the existing bulkhead, there is room it seems like to weld in a new one, and even do more bracing.
My car will never be a show winner, original or even near perfect but functionally I want it to be awesome.
Anyway, just wondered if anyone has attempted such a feat.
Also - who did you purchase your bulkhead through?
Thanks!
54 Oval
fredybear
fredybear is offline
PostPosted: Mon Oct 28, 2024 2:57 pm    Post subject: Re: Ever replace the bulkhead WITHOUT lifting the body off? Reply with quote
Pics, we need pics.
Like this?
Daddy got suckered back in the day. But, I’m at it, 30 yrs later Cool
Anything can be fixed.
1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus
finster
finster is offline
PostPosted: Tue Oct 29, 2024 2:33 am    Post subject: Re: Ever replace the bulkhead WITHOUT lifting the body off? Reply with quote
to be clear (maybe it's just me Anxious ) you seem to be talking about replacing the frame head with the body in situ. I've always thought of the body panel that sits on the naps hat as the bulkhead...
this is a new frame head (black part) ready to go on
the main issue I see is that getting the alignment right might be harder with the body on. plus the inevitable fact that once you open things up there's often more damage/rust than first thought.
quote - My goal is to see if someone can do all the repair without having to lift the body off. Why? Most shops do not have room and it would double my cost.
but you say you have a lift at home...so would you be able to separate the body/pan and take the pan to the fabrication shop?
esde
esde is offline
PostPosted: Thu Oct 31, 2024 5:11 pm    Post subject: Re: Ever replace the bulkhead WITHOUT lifting the body off? Reply with quote
I have done it.
You need to tack the new frame head in place, and then make sure the pan is jacked up level on stands. Bolt a bare front beam to the new frame head, and make sure you have even measurements to the spring plate caps on each side, and make sure the beam level matches the pan. This way the car will sit square and even. Once you are sure it's good, weld it home, but alternate side to side so the frame head does n't get twisted from the weld heat.
If you doubt the fuel line, do it while the cut is open..
modok wrote:
mkhanshaw
PostPosted: Fri Nov 01, 2024 2:56 pm    Post subject: Re: Ever replace the bulkhead WITHOUT lifting the body off? Reply with quote
Thanks for the replies!
@fredybear - Body on though
@finster -
So yes, I mean the Frame head *the black replacement piece pictured*
The lift I have are quickjacks, and not a proper 2 post lift you probably imagined.
@esde - Yes great points. I ordered the replacement framehead (Heritage Parks in the UK had the one I need and in stock, so paid the freight and got it.) It is on the way, so my next step is to take it, and my 54 via trailer down to my local fab guys (@fullcirclefabrications on Insta) and have them do the dirty work. The replacement framehead piece comes without the Napolean Hat so I am hoping they can trim RIGHT UP to where the original hat is, then grind out the original and weld in and reinforce the new one.
Another reason I am fearful of pulling the body is truly finding more rust damage that I do not want to deal with, or stored energy that would contort the dimensions (since it was hit at some point in its past)
The tips you provided are invaluable as you are right....need to ensure its on center vertically, horizontally and diagonally lol.
Here is a short video I took of what I am dealing with. So heartbreaking but I am hoping can be fixed
https://www.youtube.com/shorts/2pZy-EhuESM
54 Oval
mkhanshaw
PostPosted: Mon Nov 04, 2024 3:48 pm    Post subject: Re: Ever replace the bulkhead WITHOUT lifting the body off? Reply with quote
@Finster - I got my new Framehead in the mail today. It looks much like yours with a big round hole up front vs the normal inspection hole I was expecting. What did you do for a cover? Also, mine is a 1954, and I have some e brake complications. What year is yours?
54 Oval
Dan22
Dan22 is offline
PostPosted: Mon Nov 04, 2024 4:51 pm    Post subject: Re: Ever replace the bulkhead WITHOUT lifting the body off? Reply with quote
Mkhanshaw,
You may have to cut out and swap that part of the front plate to match the needs of the 1954 model. Perhaps share a couple pictures comparing what you had and what your new part looks like. Of course the new part is probably based on late beetles only.
At least you want your original cover to fit. That extra front room is necessary for the brake cable mechanism movement.
1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074
mkhanshaw
PostPosted: Mon Nov 04, 2024 5:37 pm    Post subject: Re: Ever replace the bulkhead WITHOUT lifting the body off? Reply with quote
Dan22 wrote:
Mkhanshaw,
@Dan22 you are absolutely correct. The earlies have the emergency brake adjuster all the way at the front (vs inside next to the lever on later VWs). Here is a picture of the mechanism (I stole from a YouTube video as it was the nicest)
The one I received looks like this up front:
The replacement Framehead section (which is I guess ok for 56 and later, And the one I ordered since they do not make a true 55 and earlier with provisions for the e-Brake assembly on the frame head) is here:
https://www.heritagepartscentre.com/uk/113701037g-complete-frame-head.html
You are correct in that I need to have my fab guys graft that end onto this new frame head. Sigh...
54 Oval
finster
finster is offline
PostPosted: Tue Nov 05, 2024 2:57 am    Post subject: Re: Ever replace the bulkhead WITHOUT lifting the body off? Reply with quote
that photo isn't my car, just one from the gallery to show a replacement frame head.
as dan22 says, you - or the guys at the shop - will have to graft the old front plate/brake adjuster area into the new.
Dan22
Dan22 is offline
PostPosted: Tue Nov 05, 2024 10:00 am    Post subject: Re: Ever replace the bulkhead WITHOUT lifting the body off? Reply with quote
I took a look at my '55 last night. The bracket that holds the ebrake rod is bolted on to the front. Enlarging the hole to the proper size (from round to rectangular), and then locating the weldnut locations, and installing rivnuts to accept the bolts might be all that is needed.
This assumes you have the support bracket for the cables/rod.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Tue Nov 05, 2024 1:53 pm    Post subject: Re: Ever replace the bulkhead WITHOUT lifting the body off? Reply with quote
And…..welding in the metallic conduit for the e brake cables (2) and the fuel line. There is also a reinforcement piece of steel that does not come with those frame heads. It is a lot of work!
It is cheaper to find an old cut off section from an old pan. You would be light years ahead in the long run!
Add to that, if you weld the frame head on, even a degree of 5 out of square, the thrust angle or caster will be off and
May not be able to be adjusted for with the allotted amount incorporated into the OG units. This piece has to be PERFECTLY INSTALLED! No easy job! Ask me how I know!
Found the drawing of the tool!
https://www.thesamba.com/vw/archives/manuals/local_manufacture/670a.jpg
Loren
Loren is offline
PostPosted: Tue Nov 05, 2024 3:44 pm    Post subject: Re: Ever replace the bulkhead WITHOUT lifting the body off? Reply with quote
I had to replace this section on my 57 Ghia pan and I made a bracket to align it. I installed a used section and it fit perfectly. This is a critical piece to replace and getting the body off is crucial. In hind sight I should have leveled the pan and used a level together with my jig. Making some sort of jig will help keep things properly aligned.
VW_Jimbo is offline
PostPosted: Tue Nov 05, 2024 11:00 pm    Post subject: Re: Ever replace the bulkhead WITHOUT lifting the body off? Reply with quote
Nice job!
A used axle beam is the way to go. Welding a section of 2 x 4 square tubing, maybe 1/4” thick, then tack welding it down to the top of the tunnel. The next step is to create an arm that welds to the channel and reaches over to a previously bolted up used axle beam unit. That way you have a fixture in place to align the new beam with.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
