bloomsburyVW Samba Member
Posted: Mon Jun 26, 2023 1:34 pm Post subject: Current info on low profile battery 6v for Split? |
Hello,
I have been looking for a low profile 6v battery for my split (1952).
I am in Canada and the stores, Nappa & Canadian tire, only have an 8.75 inch height battery.
Any recommendations?
I'll have to buy in the USA if necessary.
Thanks. |
dmooresc Samba Member
Joined: August 14, 2004 Posts: 31 Location: upstate SC
Posted: Mon Jun 26, 2023 4:58 pm Post subject: Re: Current info on low profile battery 6v for Split? |
I believe it would be the same as I run in my stock 1960 beetle: 19L. these are 7.5" tall and available at many locations in the USA. prices have almost doubled in the last few years so expect in the $200 range.
I have typically gotten a decade of life out of mine.
NAPA: Part #: BAT 7217L
best wishes |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9401 Location: Northwood, NH USA
Posted: Tue Jun 27, 2023 6:16 am Post subject: Re: Current info on low profile battery 6v for Split? |
I buy the 19L batteries. Have to call around, getting harder to find, and expensive. Paid $193 for the last one at my local Auto Parts Chain. They had to order it from their main distribution center. _________________ John Henry
'57 Deluxe
'56 Single Cab |
c_wilburn Samba Member
Joined: December 17, 2012 Posts: 54 Location: Kentucky
Posted: Tue Jun 27, 2023 7:38 am Post subject: Re: Current info on low profile battery 6v for Split? |
Optima makes a 6v battery that is half as wide as a regular battery and can be mounted sideways. It's also 800cca
#8010-044 _________________ 1972 Westfalia (Marshmelo)
1952 Beetle (Krampus)
1968 Beetle convertible (Buttercup) (the wife's car) |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6536 Location: Northern Illinois
Posted: Tue Jun 27, 2023 8:57 am Post subject: Re: Current info on low profile battery 6v for Split? |
Somebody needs to get creative and make a battery box for the Optima that looks like an old battery! _________________ Midwest Autosavers, Inc. Woodstock, IL |
finster Samba Member
Joined: May 26, 2012 Posts: 9219 Location: not far from the madding crowd
bob hailend Samba Member
Joined: November 27, 2007 Posts: 6 Location: Gallatin,TN
Posted: Tue Jul 04, 2023 9:35 am Post subject: Re: Current info on low profile battery 6v for Split? |
I have this one it is NOS and it is ready to go all you have to do is fill it with battery acid give me a call or e mail me. Thanks
615-516-3791 |
rglsr Samba Member
Posted: Wed Aug 09, 2023 1:51 pm Post subject: Re: Current info on low profile battery 6v for Split? |
Man the 19L batteries have become hard to find, and with cost approaching that of an Optima I got motivated. I've always run 19Ls since they are so OG, but need to consider alternates.
I came up with this adapter. The two plastic blocks simulate the size of a 19L battery, so the original battery cover/strap can be used. This one is for an oval window. You also need a longer ground strap, and some sort of terminal covers for the clamps, to prevent shorts. Now on a later beetle with kick panels you're good to go.
Putiting this out there for comments and/or interest... |
grailoc Samba Member
Joined: March 25, 2004 Posts: 1470 Location: FRANCE and now QUEBEC city
rglsr Samba Member
Posted: Thu Aug 10, 2023 3:05 pm Post subject: Re: Current info on low profile battery 6v for Split? |
Yes, these are 3D printed. I also modeled up a simplified version if you wanted to machine/fabricate a set out of solid plastic. They are the same parts upper/lower.
The battery is held in place with features, so it won't slip/shift while driving, sort of like a "saddle" clamp design. |
Posted: Fri Aug 11, 2023 3:24 am Post subject: Re: Current info on low profile battery 6v for Split? |
a neat and simple idea _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1323 Location: south san francisco
Posted: Tue Aug 15, 2023 3:29 pm Post subject: Re: Current info on low profile battery 6v for Split? |
cool idea . you can sign me up for one or 2 .
Steve _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
geneL3c Samba Member
Joined: October 08, 2007 Posts: 306 Location: Bridgehampton,NY
Posted: Wed Nov 13, 2024 9:02 pm Post subject: Re: Current info on low profile battery 6v for Split? |
Recently had to order a 6V battery for a project and tried to get an Interstate 19L which had been spec't at 172mm wide, 227mm long, which converts to 6.77" x 8.94"not sure of height. The 19L is no longer listed and has apparently been superceded by P/N 1-VHD. The newly listed battery measures 9" L, 6 15/16" W, 8 3/4" H. Battery should arrive next week, so I can check fit of cover, which I hope fits, not too many options at this point. Hope this helps those looking for new batteries. |
Posted: Thu Nov 14, 2024 11:35 pm Post subject: Re: Current info on low profile battery 6v for Split? |
Update on low profile 6v battery for Splits. Advance Auto has a Die Hard 6v 19L battery listed for $192-. Ht - 7.5", W - 6.8", L -8.2". I'm staying with the Interstate battery I ordered since height is not a concern ( no back seat ) and have always had very good luck with Interstate batteries for my other 6v cars. |
