Vanagon steering column coupler attachment
K9e1n4
K9e1n4 is offline
PostPosted: Mon Nov 25, 2024 7:25 pm    Post subject: Vanagon steering column coupler attachment Reply with quote
I change all 3 of the steering couplers on my 81 months ago.
Today I had serious steering sloppiness. Investigating further one of the “bolts” came off.
I never want this to happen again. Do these “bolts” look correct? They are next to impossible to tighten since they have no hex head or socket.
Should I use a standard bolt or drill out the flange and use a bolt and lock nut? Advice needed please.
1965 Beetle
1973 914 2.0L
1974 Super Beetle Convertible
1981 Vanagon Westy with 2.5 Subaru conversion
dieseltdi
dieseltdi is offline
PostPosted: Mon Nov 25, 2024 8:08 pm    Post subject: Re: Vanagon steering column coupler attachment Reply with quote
I just inspected and replace 2 of mine and I have never seen anything like this! Looks like someone just pulled something out of a box that had the "right" size bolt and screwed it together. Very definately replace that thing with a real bolt, washer and lock nut.
When a clown moves into a palace he doesn’t become a king, the palace instead becomes a circus. — Turkish proverb
Those who will willingly sacrifice freedom for security, deserve neither.
Currently:
1982 Vanagon Westy TDI conversion with Coast Mt. Hightop - SKYE
2025 Hyundai Ioniq 6 EV
2015 Golf Sportwagen S TDI
Way too many previously owned to list!
dhaavers
dhaavers is offline
PostPosted: Mon Nov 25, 2024 9:58 pm    Post subject: Re: Vanagon steering column coupler attachment Reply with quote
Yeah, that’s not right…
…at all. Evil or Very Mad
- Dave
"The WonderVan"
vanis13
vanis13 is offline
PostPosted: Mon Nov 25, 2024 10:05 pm    Post subject: Re: Vanagon steering column coupler attachment Reply with quote
Curious, if you changed those couplers, didn't you have to deal with this "bolt" to do so?
dhaavers
dhaavers is offline
PostPosted: Mon Nov 25, 2024 10:07 pm    Post subject: Re: Vanagon steering column coupler attachment Reply with quote
FYI: https://www.thesamba.com/vw/forum/viewtopic.php?p=9080089
- Dave
"The WonderVan"
K9e1n4
K9e1n4 is offline
PostPosted: Tue Nov 26, 2024 8:28 am    Post subject: Re: Vanagon steering column coupler attachment Reply with quote
Thanks for the feedback everyone.
Yes when I changed the couplers I took this “bolt” out and put it back in. It never was a problem before.
I didn’t think much of it because it looks specialized and also maybe it’s purpose would be if the coupler disintegrated some steering could be achieved with this interference “bolt”.
I really like the link that was sent showing the bolts and lock washers. I am going to go with that!
1965 Beetle
1973 914 2.0L
vanis13
vanis13 is offline
PostPosted: Tue Nov 26, 2024 8:33 am    Post subject: Re: Vanagon steering column coupler attachment Reply with quote
Please show us this funky bolt when you pull it out. Really curious to see it.
On that link, the "stover" nuts, cone lock nuts is the key thing likely nyloc nuts would also work well.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Tue Nov 26, 2024 2:21 pm    Post subject: Re: Vanagon steering column coupler attachment Reply with quote
https://volkswagen.7zap.com/en/usa/vanagon/va/1981...ring+gear/
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
Nitramrebrab72
Nitramrebrab72 is offline
PostPosted: Tue Nov 26, 2024 9:16 pm    Post subject: Re: Vanagon steering column coupler attachment Reply with quote
Something to be weary of is the type of coupling as the original type is a combination of fibres and rubber to stop the rubber part tearing over time.
K9e1n4
K9e1n4 is offline
PostPosted: Sun Dec 08, 2024 6:55 pm    Post subject: Re: Vanagon steering column coupler attachment Reply with quote
I haven’t had a chance to work on this due to Thanksgiving travel and work. I plan to work on it this weekend. I will post more. Thank you everyone for your input! More to come,
1965 Beetle
1973 914 2.0L
