chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3765 Location: San Diego
Posted: Wed Oct 09, 2024 5:06 pm Post subject: Re: 58 Ghia Restoration Begins |
That is some of the most pro metal work ive ever seen, thanks for sharing |
VeloMikey Samba Member
Posted: Sun Oct 13, 2024 3:02 pm Post subject: Re: 58 Ghia Restoration Begins |
Lots of little things for this months rotation. Lots of filling and grinding Most notable, all the support braces have been removed and the radio hole has been repaired.
_________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
Posted: Fri Nov 08, 2024 11:38 am Post subject: Re: 58 Ghia Restoration Begins |
Jason got a lot of little things done this month. Filled holes and smoothed out small dents all over. The most significant things are the roof and both cowls got the treatment.
The most significant thing this month is the body is out of the rotissery and ready to be reunited with the pan next month. Jason plans on bolting it down with all new seals and hardware to set the door gaps along with the hood and decklid.
We are that much closer to paint!
DaveB9 Samba Member
Posted: Fri Nov 08, 2024 12:09 pm Post subject: Re: 58 Ghia Restoration Begins |
Coming along very nicely! It's going to be so good in paint. Keep posting the pictures. |
WrennMetallWerks Samba Member
Joined: December 06, 2007 Posts: 3197 Location: Rescue ca
robbiecanter Samba Member
Joined: October 16, 2005 Posts: 70 Location: Gig Harbor, Wa.
Posted: Sat Nov 30, 2024 10:02 pm Post subject: Re: 58 Ghia Restoration Begins |
Rad work, but my favorite part is the tree log you use in the shop! I do the same thing with beam scraps etc. They work great to hammer on or even dish out for a certain profile you're trying to achieve with metal. Cheers Jason! _________________ 52' Split
59' lowlight ghia
64' Bug-turbo
68' Notch
84' westfalia 1.8t
91' 2.9 vr6 coupe |
Posted: Mon Dec 02, 2024 12:26 pm Post subject: Re: 58 Ghia Restoration Begins |
I can't wait to see your progress this week. We are approaching the finish line! _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Posted: Mon Dec 02, 2024 11:38 pm Post subject: Re: 58 Ghia Restoration Begins |
More of today''s progress.
The dash started going back together.
Jason had to repair the glove box door latch catch.
Then on to the hood latch.
Next was the mud doors. The drivers side need the lower portion replaced.
Once that was fixed, They were installed with fresh rubber.
A few more pieces got the blasting treatment as well.
I need a decklid latch for a lowlight. Anyone got one for sale?
Lastly, the tail lights got fitted.
kingkarmann Samba Member
Posted: Tue Dec 03, 2024 10:08 am Post subject: Re: 58 Ghia Restoration Begins |
I always look forward to the updates.
Simply amazing work.
Are you planning on using later marker lights?
Posted: Tue Dec 03, 2024 11:03 am Post subject: Re: 58 Ghia Restoration Begins |
kingkarmann wrote: |
I am not sure what you are asking. Those are the correct turn signals for a December 1957 KG.
What is a "later maker light"?
FYI, I have NOS turn signal housings and headlight rings. _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Posted: Tue Dec 03, 2024 12:43 pm Post subject: Re: 58 Ghia Restoration Begins |
VeloMikey wrote: |
FYI, I have NOS turn signal housings and headlight rings. |
I thought they look very similar to the later Ghia's.
I thought lowlights had a similar front markers like this.
Trylons 59
After looking at 57's and 58's it's plain to see I was wrong.
Learned something new. Carry on |
Posted: Tue Dec 03, 2024 12:45 pm Post subject: Re: 58 Ghia Restoration Begins |
VeloMikey wrote: |
I thought all lowlights had a similar front markers like this.
