Dormobile Top Install
Page: Previous  1, 2
nineteensixtyfiveVG
nineteensixtyfiveVG is offline
PostPosted: Sat Apr 25, 2020 10:49 am    Post subject: Re: Dormobile Top Install Reply with quote
me next please
pyrOman
Fire Master
pyrOman is offline
PostPosted: Sat Apr 25, 2020 11:53 am    Post subject: Re: Dormobile Top Install Reply with quote
nineteensixtyfiveVG wrote:
me next please
Laughing
Get yourself the top, then come on over! Cool
Daddybus
Daddybus is offline
PostPosted: Sat Apr 25, 2020 1:59 pm    Post subject: Re: Dormobile Top Install Reply with quote
Westfalia mounted their dormy tops 2" farther to the front and hinges on the left, which is how I will mount mine...with pyro's help I hope.
PS
What instructions?
crofty wrote:
srfndoc wrote:
pyrOman wrote:
It’s supposed to “shrink” over time which they do state so on the installation instructions. Cool
srfndoc wrote:
Nice! You are becoming Dormobile-West with your latest installation. Good thing you installed it in the correct direction this time. Very Happy
I'm sure Eric is stoked.
For reference:
And yes, he likes it! Razz
Westfalia never installed them in that direction (and I'm just messing with you):
Either direction that top is the shit.
They also never put a black wheel in a flipseat!
PDX db
PDX db is offline
PostPosted: Thu Apr 30, 2020 8:54 pm    Post subject: Re: Dormobile Top Install Reply with quote
Where did you get the wood framework?
pyrOman
Fire Master
pyrOman is offline
PostPosted: Fri May 01, 2020 5:25 am    Post subject: Re: Dormobile Top Install Reply with quote
Preferably you want to score it with the top, as well as EVERYTHING needed! But it’s basically 1x1 inch wood sticks. If you were to make the frame, the bows would be the most difficult to make, though no impossible. Confused
velvetgreen
velvetgreen is offline
PostPosted: Fri May 01, 2020 6:51 am    Post subject: Re: Dormobile Top Install Reply with quote
Any chance you could post up a few pics of what the wood frame AKA "sticks" looks like ? Smile
pyrOman
Fire Master
pyrOman is offline
PostPosted: Fri May 01, 2020 7:19 am    Post subject: Re: Dormobile Top Install Reply with quote
Check out the first post in this thread. You’ll see the front and rear bows. The sides are straight. You can also check out my gallery pix here, I may have pictures of the wood frame off the other 2 tops installs. In any case, they are pretty much the same as it’s used for Westy wood headliner installs. Cool
srfndoc
srfndoc is offline
PostPosted: Fri May 01, 2020 9:36 am    Post subject: Re: Dormobile Top Install Reply with quote
Clara does the same wood bracing for the Westy poptops, I wonder if she would also do them for the Dormy top.
tisius
tisius is offline
PostPosted: Sun Aug 23, 2020 3:06 pm    Post subject: Re: Dormobile Top Install Reply with quote
https://www.dormobile.co.uk/conversions/classic
How about this for Dormobile top? Looks like the real deal, new. Cool stuff for sure.
https://shop.dormobile.co.uk/dormobile-roof-conver...gon-parts/
drive it like you just robbed the bank
.... if it ain't dutch, it ain't much!
zuggbug
zuggbug is offline
PostPosted: Mon Dec 02, 2024 2:11 pm    Post subject: Re: Dormobile Top Install Reply with quote
pyrOman wrote:
At the Garaj Mahal installing my third Dormobile top! Cool
how did you locate the hinges on the bus so you knew where to drill the holes for the hinges in the roof of the bus?
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
pyrOman
Fire Master
pyrOman is offline
PostPosted: Tue Dec 03, 2024 9:59 am    Post subject: Re: Dormobile Top Install Reply with quote
The process:
1) Place the top with the hinges on top of the roof centered as best you can.
2) Mark where the hinges will be.
3) Remove the top and take off the hinges.
4) Place the hinges on the marks to drill the holes.
One thing I do is use a square plate on the inside of the roof for each hinge for a stronger support than just the skin of the roof. Cool
zuggbug
zuggbug is offline
PostPosted: Tue Dec 03, 2024 11:04 am    Post subject: Re: Dormobile Top Install Reply with quote
pyrOman wrote:
The process:
Thank you
58 15 window
56 westy
BarryL Premium Member
BarryL is offline
PostPosted: Tue Dec 03, 2024 6:45 pm    Post subject: Re: Dormobile Top Install Reply with quote
Is that Chris Cross' bus?
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed Dec 04, 2024 9:12 am    Post subject: Re: Dormobile Top Install Reply with quote
No, it’s a different one. Cool
Page: Previous  1, 2
Page 2 of 2
