PeteSC Samba Member
Posted: Tue Nov 19, 2024 6:30 am Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
PeteSC wrote: |
It can be fun to blame things on prior owners, and in your car's case many times that was warranted. However, I think in this instance your throwout bearing clip simply gave way, as they can be prone to do.
Personally I'd replace the T.O. bearing, clutch disc, and pressure plate while I'm in there, but that's an opinion worth the price charged. Others may disagree. |
A tempered response to be sure— I suppose I am basing my opinion on the fact that there is but one such clip to be found.
Thanks Pete! |
If there were no pin in at all I don't believe the bearing would have lasted for a single clutch engagement.
EverettB wrote: |
Does his cross-shaft look ok?
It looks like it might have too much wear where the throwout bearing sits, making the amount of material between that area and the area where the retaining clips sit very thin.
This photo:
Click for full-size image |
Agreed, that doesn't look right. If I didn't know any better it almost appears that someone wrestled with the bearing clips too much and decided to clearance it. |
kingkarmann Samba Member
Rome Samba Member
Joined: June 02, 2004 Posts: 10152 Location: Pearl River, NY
Posted: Wed Nov 20, 2024 3:38 pm Post subject: Re: '59 Karmann Ghia fever |
Trylon, I also think your throwout bearing arm is at the end of its life- and that you've been lucky that one of the arms has not broken off at the thin point. The thickness between the small (front) curve for the spring retainer and the large (rear) curve for the TO bearing is really thin.
Here's a shot of what a less-worn arm should look like (yamaducci gallery)-
Ignore the small holes above the curves, which were drilled by an owner for safety-wiring the parts to avoid them from falling off the arms. |
McFunzeepants Samba Member
Joined: February 04, 2015 Posts: 131 Location: Santa Cruz
Posted: Wed Nov 20, 2024 3:52 pm Post subject: Re: '59 Karmann Ghia fever |
Is that the missing clip up there next to the starter? |
Trylon Samba Member
Joined: August 16, 2019 Posts: 4938 Location: Connecticut
Posted: Wed Nov 20, 2024 4:40 pm Post subject: Re: '59 Karmann Ghia fever |
Ok, so let’s do the whole clutch assembly.
As usual, there seem to be many versions and none marked for the year of our car. And I am not even sure that the transmission is from ‘59!
Suggestions for parts shopping?
Thanks! _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
Loren Samba Member
Posted: Wed Nov 20, 2024 5:17 pm Post subject: Re: '59 Karmann Ghia fever |
It doesn't look like the stock split case transmission. Look for the transmission number at the front passenger side of the transmission and use the beetle vin and chassis number chart on this site (under Technical) to find out what year it's from. From there you can find the correct part.
Here is an example. It's the stamped vertical number you are looking for:
Trylon Samba Member
Posted: Wed Nov 20, 2024 5:31 pm Post subject: Re: '59 Karmann Ghia fever |
Loren wrote: |
Thanks Loren! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Tue Nov 26, 2024 1:37 pm Post subject: Re: '59 Karmann Ghia fever |
Whelp, I find no stamped numbers on the transmission:
On another note:
Seems that we have the wrong engine seal as it puckers around corners. Is a correct one available?
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Loren Samba Member
Posted: Tue Nov 26, 2024 2:05 pm Post subject: Re: '59 Karmann Ghia fever |
That is a later transmission. The transmission number is just below the VW logo and you can make out a few numbers on your photo, but you will likely need to scrub it clean to read them. |
Trylon Samba Member
Posted: Tue Nov 26, 2024 2:25 pm Post subject: Re: '59 Karmann Ghia fever |
Loren wrote: |
Ha! I did not see those— will scrub. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Rome Samba Member
Posted: Tue Nov 26, 2024 3:18 pm Post subject: Re: '59 Karmann Ghia fever |
McFunzeepants wrote: |
Yes; you can see it in Trylon's photo from today- |
Loren Samba Member
Posted: Tue Nov 26, 2024 4:00 pm Post subject: Re: '59 Karmann Ghia fever |
Looks like any 61-70 cross shaft kit will work on your transmission.
This video shows what you would be getting yourself into:
https://www.youtube.com/watch?v=p48ymIe2UTw |
Marcdeb Samba Member
Posted: Tue Nov 26, 2024 5:50 pm Post subject: Re: '59 Karmann Ghia fever |
There's 2 different types of engine compartment seals, some have formed corners. Sort of like windshield seals with formed corners, usually referred to as "blocked" seals. Your seal looks like it was a straight seal without formed corners. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Trylon Samba Member
VeloMikey Samba Member
Posted: Tue Dec 03, 2024 1:06 pm Post subject: Re: '59 Karmann Ghia fever |
Show us your flywheel. It's not by year but by size. It's either 180mm or 200mm. You might need to remove the flywheel wheel and resurface it too. _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
Trylon Samba Member
Posted: Tue Dec 03, 2024 1:50 pm Post subject: Re: '59 Karmann Ghia fever |
VeloMikey wrote: |
Show us your flywheel. It's not by year but by size. It's either 180mm or 200mm. You might need to remove the flywheel wheel and resurface it too. |
Oo I think I know this one— remember our burned out 6-volt starter? The reason I realized we could rewire the car back to 6-volts? So we have the 6-volt flywheel, the smaller one right? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
PeteSC Samba Member
Posted: Tue Dec 03, 2024 2:48 pm Post subject: Re: '59 Karmann Ghia fever |
Yes, your 36hp has the 180mm flywheel. I put the Sachs in mine about 7 years ago (that's the one marked as "German made"). |
Posted: Tue Dec 03, 2024 4:14 pm Post subject: Re: '59 Karmann Ghia fever |
Hold on fellas! You can have a 6v 200mm flywheel, a 12v 200mm flywheel or a 6v 180mm flywheel. The stater teeth or the transmission year have no bearing on what size the flywheel is. You need to measure the cultch disc or flywheel to be sure. _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
PeteSC Samba Member
Posted: Wed Dec 04, 2024 6:55 am Post subject: Re: '59 Karmann Ghia fever |
VeloMikey wrote: |
Hold on fellas! You can have a 6v 200mm flywheel, a 12v 200mm flywheel or a 6v 180mm flywheel. The stater teeth or the transmission year have no bearing on what size the flywheel is. You need to measure the cultch disc or flywheel to be sure. |
He posted the photo below of his clutch and flywheel on the previous page. It's a stock 36hp engine, and it sure looks like a 109 tooth flywheel versus a 130 tooth 200mm. I believe 36hp dowel sizes are pretty unique as well which limits what works with that engine without extensive machine work, which is hard to fathom someone taking the time to retrofit a 109 tooth 200mm 1500 type 2/3 for a stock 36hp.
Measuring won't hurt anything, but I'll stick with 180mm as being what he needs.
