Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 742 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Sun Sep 03, 2023 10:06 pm Post subject: 1953 Super 1500cc typ 528 / 2pc. Complete Eng. Build / John T. |
Follow along as I put together a complete 1953 typ 528 Super 1500cc 2pc. case engine build for John T's Coupe. This engine will be built from scratch.
All bits & pieces gathered into one pile and carefully cleaned, fitted & massaged to bring this engine back to life...... Enjoy!
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com
Rome Samba Member
Joined: June 02, 2004 Posts: 10156 Location: Pearl River, NY
Posted: Mon Sep 11, 2023 12:38 pm Post subject: Re: 1953 Super 1500cc typ 528 / 2pc. Complete Eng. Build / John T. |
Very impressive crankcase, Mr. O. The gold appears to be even more intense than that which you usually use for VW cases. Do you keep the case in the Alodine soaking longer than for VWs? Did you bore the cylinder openings for a larger diameter than the original 80 mm? |
Posted: Mon Sep 11, 2023 1:10 pm Post subject: Re: 1953 Super 1500cc typ 528 / 2pc. Complete Eng. Build / John T. |
Rome wrote: |
To answer your questions in order:
What I've noticed on the earlier blocks, the "gold" is more intense than the post 1956 blocks. Also, 2 blocks usually don't come out looking the same.
I'm thinking that the alloys when melted were not consistent so each block had different "hues" when treated after they came out of their molds.
Alodine is NOT used for magnesium but rather aluminum. I'm very familiar with Alodine because I used it on aluminum surface skins on the C-17
US military cargo lifter while employed at The Boeing Company. The Alodine that I used for aluminum does nothing to the surface nor appearance
on magnesium. I do not do the chem. treatment. I send my blocks out to be done by a professional that has been in the business for over 40 years.
My understanding is the chemicals are very toxic and causes cancer if not properly handled.
I use Dura-Bar cylinders and like to "clean-up" the bore openings. The P/C's are 80mm _________________
VW www.Okrasa.com
356 www.PreA356.com |
wdfifteen Samba Member
Posted: Mon Sep 18, 2023 3:03 am Post subject: Re: 1953 Super 1500cc typ 528 / 2pc. Complete Eng. Build / John T. |
Watching this thread. This should be interesting. |
Posted: Mon Sep 18, 2023 10:24 am Post subject: Re: 1953 Super 1500cc typ 528 / 2pc. Complete Eng. Build / John T. |
Fresh 10/10 crankshaft assembly that has been balanced along with conn. rods ready to assemble.
VW www.Okrasa.com
Kafer_Mike Samba Member
Joined: June 23, 2004 Posts: 383 Location: Noblesville, IN
Posted: Tue Oct 10, 2023 10:06 am Post subject: Re: 1953 Super 1500cc typ 528 / 2pc. Complete Eng. Build / John T. |
That's pure mechanical art. Following and can't wait to see the finished engine. _________________ Kafer_Mike
Build 'em fast...or let 'em sit. |
alanhall Samba Member
Joined: February 18, 2006 Posts: 120 Location: Northern California
Posted: Tue Oct 17, 2023 7:08 am Post subject: Re: 1953 Super 1500cc typ 528 / 2pc. Complete Eng. Build / John T. |
Hey Joe, Interesting valve springs...looks like a flat inner spring (or damper?). What is the source of these and do they work well? Thanks |
Posted: Tue Oct 17, 2023 9:01 am Post subject: Re: 1953 Super 1500cc typ 528 / 2pc. Complete Eng. Build / John T. |
alanhall wrote: |
These springs have a flat inner damper / spring, not the usual rolled wire. I got them years ago from an old Pre A guy. They work well as they don't have
the extreme lifter pressure that the modern 356 valve springs have for the later mushroom lifters. Never had any issues. My engines seem to love 'em.
VW www.Okrasa.com
Posted: Wed Oct 02, 2024 8:27 pm Post subject: Re: 1953 Super 1500cc typ 528 / 2pc. Complete Eng. Build / John T. |
Repairing heater box flappers......
This was the old, holey & rusted piece that I removed. You can see the "donor".
Piece spot welded.......
As fitted and installed......
VW www.Okrasa.com
Posted: Sun Oct 13, 2024 9:52 pm Post subject: Re: 1953 Super 1500cc typ 528 / 2pc. Complete Eng. Build / John T. |
Front breast plate was previous repaired by a "metal guy" and when I secured one side, the other side was W A Y off!
This piece of tin is the most visible and needs to fit nothing less than perfect!
So I took it apart......
And re-fitted the pieces...........
VW www.Okrasa.com
Posted: Tue Nov 26, 2024 9:46 am Post subject: Re: 1953 Super 1500cc typ 528 / 2pc. Complete Eng. Build / John T. |
Although the firewall tin is hardly noticeable, it still needs attention. The seal channel strip
is always beat up so this needs to be removed and replaced with "fresh" metal...
Horizontal side pieces get the same treatment.......
VW www.Okrasa.com
Posted: Wed Dec 04, 2024 12:46 pm Post subject: Re: 1953 Super 1500cc typ 528 / 2pc. Complete Eng. Build / John T. |
Now that I have all 3pcs. of the rear breast plate located in the correct positions, I spot welded them together, I can now focus on installing
the new channel tack strip. Here, I'm measuring the CORRECT length it should be when it meets the side horizontal piece. Note where I
marked with an arrow where the edge of the horizontal pc. ends. This is where the channel strip is suppose to end and NOT where it was
previously located by past "metal guy".
VW www.Okrasa.com
Posted: Sat Dec 07, 2024 11:23 pm Post subject: Re: 1953 Super 1500cc typ 528 / 2pc. Complete Eng. Build / John T. |
Spot welded the 3 channel strips to their perspective tins. Notice how there's no mis-alignment where they
meet so the rubber will stay uniform when the engine is installed.
VW www.Okrasa.com
