56 Ghia build with Webasto and Judson
Page: Previous  1, 2, 3 ... 18, 19, 20, 21, 22  Next
JeffL
JeffL is offline
PostPosted: Tue Jul 04, 2023 10:32 am    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
Braukuche wrote:
The new straps are too short and made of garbage rubber that breaks. At least the ones Airhead sells. I’ve gone through four of them, I ended up relocating the strap mount to shorten the distance.
Maybe I should just clean up the 59 used one I have them. I don’t think my early 56 has a bottom hook when the seat back is down. I’ll check for screw holes.
http://karmannghias.org/
https://karmannghias.org/GAlken/index.html
Braukuche
Braukuche is offline
PostPosted: Tue Jul 04, 2023 10:53 am    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
My later 56 does have the lower hook.
My rubber strap was white.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
obus Premium Member
obus is offline
PostPosted: Tue Jul 04, 2023 6:55 pm    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
JeffL wrote:
Rear seat strap minutia 111-885-585, Beetle part
Might have found a local shop to put on my seat covers if not I’ll have to do it myself.
Here is my rear seat strap and pivot on the left.
The strap is long because the rubber stretched.
Note the ball is solid rubber with out a hole/relief in it.
Even more interesting is the pivot. It is just a ferrule with ring at the top like a hollow rivet . It is not like the later straps with a “full cover” like the 59 example next to it.
The 57 manual just shows a cone washer so several changes here.
maybe i am wrong but is it similar to one from The Thing? https://www.thingparts.com/seat-retaining-strap/
JeffL
JeffL is offline
PostPosted: Fri Jul 07, 2023 12:32 am    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
What is the Thing part number it could be the same
JeffL
JeffL is offline
PostPosted: Wed Jul 19, 2023 8:21 pm    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
Well, back to storage and almost done. Moving again as I want to retire at 60 so it might be a few months to a year to finish our 56. Florida bound in a few months.
I was test fitting the carpet, tunnel and rubber mats.
JeffL
JeffL is offline
PostPosted: Sat Jul 22, 2023 8:47 am    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
Ran her around the development loop for the first time and she ran fine. It’s been over 30 years to get this far. All gauges and brakes worked. Getting ready to load her up for the trip to Florida.
obus Premium Member
obus is offline
PostPosted: Sat Jul 22, 2023 9:12 am    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
obus Premium Member
obus is offline
PostPosted: Sat Jul 22, 2023 9:13 am    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
That Ghia is gorgeous!!!
calexican
calexican is offline
PostPosted: Sat Jul 22, 2023 11:36 am    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
Congratulations! 30 years…wow…good things take time…and that’s one beyond good Ghia….pretty amazing rock too.
JeffL
JeffL is offline
PostPosted: Thu Aug 31, 2023 6:05 pm    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
Well finally in Florida and both cars here. Had some trailer issues half way down but thanks to Tractor Supply we made it.
Maybe in a few months we will finish her.
Got to get some AC installed first.
We unloaded just to load her up again and go inland for the hurricane. No issues though with the new house.
udo dreisoerner
udo dreisoerner is offline
PostPosted: Fri Sep 01, 2023 1:15 am    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
i love the roof, fantastic
Searching for a 1956 lowlight karmann ghia with a VIN number between1273054 and 1273440, and the matching engine with an Engine Number between
1525510 and 1525519 PLEASE OFFER ME ONLY THE CARS THAT I'M LOOKING FOR, THANKS!!
rbsurfguy
Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
rbsurfguy is offline
PostPosted: Fri Sep 01, 2023 3:36 pm    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
Both cars are beautiful! What is the one on the left?
Happy you survived the hurricane!
Jeff
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
Loren
Loren is offline
PostPosted: Fri Sep 01, 2023 3:37 pm    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
It's an Alken, and it was beautifully restored:
https://www.thesamba.com/vw/forum/viewtopic.php?t=539063&highlight=alken
rbsurfguy
PostPosted: Fri Sep 01, 2023 3:42 pm    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
Thanks Loren, never seen one before, as I am sure most have not. Very nicely done JeffL!!!!
Jeff
2012 Passat-Sold
downlowmatt
downlowmatt is offline
PostPosted: Sun Oct 15, 2023 1:14 am    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
I just wanted to say how great this thread is. I am rebuilding a '56 myself, mine is a November '56 in Antelope brown. I bought it on thesamba in 2010 and it came over to the UK from the USA. It was already a shell with boxes of parts so I've never seen it as a whole car.. hence my appreciation for your detailed photos and descriptions. Thanks!
JeffL
JeffL is offline
PostPosted: Sat Dec 23, 2023 4:45 pm    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
You are welcome. My move stalled my restoration some but we are hoping to finish her early next year.
downlowmatt
PostPosted: Tue Oct 22, 2024 8:13 am    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
Hi Jeff, I hope you are well. Have you made any progress on your excellent ghia, please?
Matt
JeffL
JeffL is offline
PostPosted: Tue Oct 22, 2024 5:17 pm    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
Matt
Well a hurricane and flood surge had some impact on our girl and the Alken. The Thing was a trooper and our only car for 2 weeks as our 2 new electric cars were bricked like iPhones dropped in a pool. Pretty crazy right now but she is on deck to be finished. Thanks for your energy to help us get her to the finish line
JeffL
JeffL is offline
PostPosted: Thu Dec 05, 2024 12:32 pm    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
Update at bottom on seal part number 66
56 to early 57 tail light lens
These lenses did not have the rubber packing seal between the lens and the bezel as seen in this photo of my car
Here are some photos from January 57 parts manual where the rubber packing does not exist
In a later, 1958 parts manual you can see that the rubber packing part 66 is added
The screws that hold on the bulb holder, and the bezel are Ghia specific part numbers. If anybody has found a substitute for these I would like to know, and we could post it here. The ones holding on the basil are the most important and seem to be about 25 mm long. 141 945 185 part for bezel
I find it interesting, like most Volkswagen light fixtures, that they are not grounded. The rear lenses do have a terminal inside to attach a ground wire. I will run a ground wire from each of these lights into the firewall to assure that I have a good ground.
In the following pictures you can see I found some NOS packing for the bulb holders and they’re still pretty soft.
Here in my box of seals I think this is the added seal 66 and it is split to accept the lens in it, it has a VW logo and hella part number I can not read. Not sure how it would fit with my bezel. Maybe they made newer ones.
JeffL
JeffL is offline
PostPosted: Mon Dec 09, 2024 5:47 pm    Post subject: Re: 56 Ghia build with Webasto and Judson Reply with quote
Stock 6v lights
Got some oval head screws to install
Page 19 of 22
