Looking for the owner of this van!
johnnytod
johnnytod is offline
PostPosted: Wed Dec 04, 2024 8:37 pm    Post subject: Looking for the owner of this van! Reply with quote
I am looking for the owner of this van. Does anyone know how to find him? Van was lastly sighted in Florida. I want to ask him a question.
Any hints would be appreciated!
1.9 Diesel NA, 1Y, Adventurewagen high top roof, Joker interior
Ahwahnee
Ahwahnee is offline
PostPosted: Wed Dec 04, 2024 10:34 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
I guess you're looking for who bought it at auction?
https://hideautovin.com/en/vehicle/215682503/volkswagen--vanagon/WV2ZB0256HH024182
vanis13
vanis13 is offline
PostPosted: Wed Dec 04, 2024 10:44 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
Surprised it sold fur 875
Interesting shot of the engine and tranny, I don't recognize it. Any ideas what it is?
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Dec 04, 2024 10:49 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
Looks like a FAS kit to me.
tdivan82 Premium Member
tdivan82 is offline
PostPosted: Thu Dec 05, 2024 6:11 am    Post subject: Re: Looking for the owner of this van! Reply with quote
What happened to that poor westy? Drivers door looks like a dinosaur tried to get inside.
- George
'82 Westy TDI
MsTaboo
MsTaboo is offline
PostPosted: Thu Dec 05, 2024 12:57 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
This is another example of the Fire Dept going nuts trying to locate the fire source. The door must have been locked and they went to town prying it open (why they didn't just go though the window is a mystery) Note the damage to the front as they tried to open the front hood. Rolling Eyes
Currently:
We are asked to bear it, to take in the whole,
The long indifferent beating down of soul.
SLOWoody
SLOWoody is offline
PostPosted: Thu Dec 05, 2024 2:07 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
Looks like the fire was concentrated in the front of the van. Much more fire damage up front and the area around the radiator is torn up.
83.5 Westfalia, GW 2.3L w/ GW EFI, 4 speed
tdivan82 is offline
PostPosted: Thu Dec 05, 2024 3:00 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
Front left corner looks the worst, the left headlamp looks much worse than the right, and large puncture in the sheet metal next to the antenna hole. Maybe the fire started in the Fusebox area?
- George
'82 Westy TDI
Mile High Puma
Mile High Puma is offline
PostPosted: Thu Dec 05, 2024 7:30 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
The transaxle looks heavy duty. Is that a Subagears unit?
1965 Velvet Green DC
1990 Westfalia Syncro
vanis13
vanis13 is offline
PostPosted: Thu Dec 05, 2024 8:03 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
I was wondering about that transaxle. Mine has a diff bellhousing....and man, it's clean!
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Dec 05, 2024 11:10 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
I can't access the pics anymore but it was a Vanagon transmission, just clean.
vanis13
vanis13 is offline
PostPosted: Fri Dec 06, 2024 1:03 am    Post subject: Re: Looking for the owner of this van! Reply with quote
This should be all of them if not they are in my gallery
Abscate Premium Member
Abscate is offline
PostPosted: Fri Dec 06, 2024 1:46 am    Post subject: Re: Looking for the owner of this van! Reply with quote
Hemp vent block off plates
Very Happy
.ssS!
82westyrabbit
82westyrabbit is offline
PostPosted: Fri Dec 06, 2024 4:38 am    Post subject: Re: Looking for the owner of this van! Reply with quote
That’s definitely a FAS engine conversion. The transmission is stock vw. It looks different because it has an adapter plate for the FAS engine conversion. The fire looks like it was in the front so it probably it wasn’t the usual bad fuel lines. Someone had a lot of money it that van. The fire must have been devastating to them. On the bright side someone got a great deal on a FAS engine conversion and what looks like a rebuilt transmission. John
vanis13
vanis13 is offline
PostPosted: Fri Dec 06, 2024 6:01 am    Post subject: Re: Looking for the owner of this van! Reply with quote
Yeah, and I was thinking of it's FAS it is diesel which would less likely be a fuel fire.
tdivan82 is offline
PostPosted: Fri Dec 06, 2024 6:17 am    Post subject: Re: Looking for the owner of this van! Reply with quote
How can you tell diesel from the photo? I guess the fact that the engine didn't burn is a pretty good clue.
It's giving off electrical fire vibes. Van seems to be well accessorized, so could be sketchy wiring / unfused circuit at the battery or fuse box.
I think those are palm trees...
- George
'82 Westy TDI
vanis13
vanis13 is offline
PostPosted: Fri Dec 06, 2024 6:31 am    Post subject: Re: Looking for the owner of this van! Reply with quote
I thought FAS did only diesel conversations.
tdivan82 is offline
PostPosted: Fri Dec 06, 2024 6:39 am    Post subject: Re: Looking for the owner of this van! Reply with quote
They also offer the 2.0 ABA engine.
- George
'82 Westy TDI
vanis13
vanis13 is offline
PostPosted: Fri Dec 06, 2024 9:01 am    Post subject: Re: Looking for the owner of this van! Reply with quote
Well there you go! Thanks for the education.
4Gears4Tires
4Gears4Tires is offline
PostPosted: Sat Dec 07, 2024 8:03 am    Post subject: Re: Looking for the owner of this van! Reply with quote
Definitely looks like a great way to get a rebuilt transmission at the very least. I don't know if the wiring or motor is any good though. Does the FAS kit put the wiring and ecu in the cabin? Certainly the major engine swap bits of the engine swap like the carrier bar, oil pan, and transmission adapter plates look good.
Maybe it was a failed brake switch that caused the fire.
