kintail Samba Member
Posted: Sat Dec 07, 2024 9:40 pm Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
Pulled the trigger on the West Coast Interiors fabric kit to match the OG fabric in evidence. This needs to be replaced.
Now to get some work done. Found a local welder to make the tray and rear window repair as needed. In the meantime dealing with minor surgery so a wee bit of recovery time in order.
_________________ Scott |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2291 Location: Graz, Austria, Europe
Posted: Thu Dec 12, 2024 4:00 am Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
Mika has a super nice quality repair panel for your rusted section ! Would be a shame to cut what seems another really good ( even donor) body that maybe still could be used for another project in future ! 54s don't grow on trees anymore... _________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Posted: Thu Dec 12, 2024 7:04 am Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
I understand your thoughts on this as well.... a lot of vw cars and parts have disappeared over the decades. And thanks to new technology and those who have stepped up to reproduce parts accurately and affordable.
I should have taken a full picture to the extent the body has been cut before I got it. The pan is gone, and the b-pillars have been cut for the semaphores. the bottom of the body has been sitting on the ground for decades so the heat channels are rusted pretty badly. Plus the front clip cut off as well. I did order some great repair panels from Mika just as the Canada Post strike started...... Hopefully ends soon!!
The VW Canada plate was saved for the record.
Posted: Thu Dec 12, 2024 9:16 am Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
In the foreground a rare 1953 VW Custom sunroof to be restored. In the background the remains of the '54 donor body. _________________ Scott |
Posted: Fri Dec 27, 2024 6:22 pm Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
Got some replacement sheet metal today from Virtanen Replacement Panels for both doors and A pillars. This was held up because of the Canada Post strike here but they arrived safely.
Found out both headlights on the car are the originals put on at the factory, noted by arrow mark on glass and two rivets on chrome headlight ring. Hopefully the stone chip on one can be reasonably repaired.
Determined that heater channels have to be replaced. Klassic panels now ordered. Discussions regarding body work continue. Ordered European bumper kit to return to original and.... birth certificate on the way!! Last time I ordered one of these they were free from VW..... oh well.[/img] _________________ Scott |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1888 Location: Winnipeg
Posted: Tue Jan 07, 2025 5:27 pm Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
This is a parcel tray I cut out of a '59 that was intended for your convertible but should work in your '54. It is different from the '54 but since no one will ever see it, it should be Ok
Don _________________ Better and better mistakes! |
vw356 Samba Member
Joined: January 09, 2004 Posts: 267 Location: Cullman,Alabama
Posted: Tue Jan 07, 2025 5:42 pm Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
This clip is possibly a late '59, but I usually consider this a 1960 because of the rib differences. A '54 is completely different, but this could work. I do not think a '54 rear seat will fit with this clip installed though. In a '54, the rear cargo shelf curves sharply downwards at the front edge, then curves outward at the bottom sharply to meet the crossmembers and the whole lower area is more flat and the seat base sits on it and the seat back meets the sharp upper curve.
I can make pictures if needed of a '54 body and '54 back seat.
As correct as this car is, might as well go all the way.
Best of luck!
Don _________________ Current projects:
1950's Volkswagens!
51,52,54's,55,56's,57,58's,'60's And then a bunch of '60's, but the '50's are my favorites.. |
vw356 Samba Member
Posted: Tue Jan 07, 2025 5:48 pm Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
Oops.. I just replied impulsively seeing this latest picture in the gallery. I forgot the correct '54 package area was already posted above.
I would use that '54 donor car. Other people will want to buy the other donor clip pieces left over too.
Best of luck!
1950's Volkswagens!
Posted: Tue Jan 07, 2025 7:17 pm Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
I actually have a 54
However I think you're right. As soon as it warms up a little I can head over to John's place and directly compare the two and figure out if the '59 tray will work or not.
vw356 Samba Member
Posted: Tue Jan 07, 2025 7:32 pm Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
I like your '54 too!
I know your clip can weld in and look decent, but I am fairly sure the '54 back seat will not fit in with the later clip.
I do all kinds of vw welding as my hobby, and I have early beetles for each year from 1951-'60.
Still, I learn new details very often even after 30 years. We will know soon.
Thank You. _________________ Current projects:
1950's Volkswagens!
Posted: Thu Jan 16, 2025 6:53 am Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
Another update.....
Since my garage is not insulated, work is restricted until warmer temperatures and spring show up. -20C is no fun for the fingers.
Since the car came with the engine lid lock from the factory I decided to clean it up The key also operates the ignition. When I bought the car it appeared that the key did not work on the engine lid. However carefully cleaning out the lock and putting graphite in, it now operates smoothly 110%. Cleaning all the locks and door handles has to be the most satisfying part of a restoration.
A couple of new developments.....
Like mkhanshaw, I was also struggling to find somebody to undertake the heat channel project and also door hinge repair who had previous experience. Fortunately, I did find somebody local who had done this for a fellow VW club member on his 1966 Beetle sunroof.
So this work will start in early summer.
Another direction for the '54 Beetle. Years ago I got a NOS set of Foxcraft fender-skirts for my 1959 Beetle Kabriolett and test fit them on my then '53 Canadian Standard.
(As a side-note this '53 still exists under new ownership and hopefully returns to the road after basically being in storage for 50+ years.)
I like the fender-skirt look and discovered Ricardo of Split Parts Unlimited is reproducing them.
https://www.thesamba.com/vw/classifieds/detail.php?id=1212609
So ordered a set and eagerly wait their arrival. Since they are based on an original set they should fit perfectly in my original German rear fenders. Be aware that reproduction fenders will not fit and need modification!
And also finally decided I will be repainting the car in the original ultra maroon.......
Posted: Yesterday 8:32 am Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
So the Klassicfab heater channels and firewall arrived yesterday. Along with a pair of well done lower door hinges from Neil Shaddox. A couple of more parts to arrive shortly to complete the list.
One item to be replaced is my H pattern rear apron. Rather than cut two exhaust holes in the apron, the previous owner decided to roll/crush it up to fit. Have ordered Wolfpart but will keep original to see if it can be repaired later. _________________ Scott |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 10639 Location: Huntington Beach, CA
Posted: Yesterday 9:19 am Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
Nice updates! It all looks so familiar! Keep at it, it will get there! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
mkhanshaw Samba Member
Posted: Today 10:05 am Post subject: Re: New project - 1954 VW Beetle Deluxe w/ VW Canada prodn plate |
kintail wrote: |
One item to be replaced is my H pattern rear apron. Rather than cut two exhaust holes in the apron, the previous owner decided to roll/crush it up to fit. Have ordered Wolfpart but will keep original to see if it can be repaired later. |
Those look high quality! Do the heater channels include the bottom section with the nut inserts in them? _________________ 54 Oval |
