robin.richard Samba Member
Joined: February 17, 2012 Posts: 515 Location: V. Beach VA
Posted: Thu Dec 05, 2024 3:18 pm Post subject: Eberspacher power source. |
Hello,
I have a question for the electrical minded mechanic or a BN4 Eberspacher user.
I have been running my Eberspacher for two winters now. Great accessory for those cold morning drives. Especially for passengers in the back. I used the 67 and earlier instal instructions, except I didn’t run the power off the starter terminal 30, rather I run it directly off the battery + post. Everything seems to run fine. It Produces heat as it should. Unfortunately if I run the heater without the motor running it instantly kills the battery and I can’t start the bus.
So my routine is - start the bus, then turn on the heater, have a nice and warm drive, once I get to my destination I turn the heater off and it goes into its cool down cycle, then when the heater shuts off I turn off the engine. If I accidentally turn off the engine before the heater goes off I can’t start the engine. I know the glow plug in the heater draws a lot of volts but once that shuts off I didn’t think the heater drew much while running and during the shutdown cycle.
Is this issue because I’m running the heater straight from the battery + post? Would this correct itself if I run it from the starter or the regulator? Easy enough to do, but wanted to ask first.
I also have a lithium leisure battery under the foldout bed and I am considering running the heater from it but I would need to change some wiring from the switch.
What do you think is causing the issue?
-Rich _________________ Drive your bus! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52168 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Dec 05, 2024 4:50 pm Post subject: Re: Eberspacher power source. |
Battery or starter terminal doesn't matter, does that heater have a glow plug?, or just a spark plug?, if glow the flame switch could be defective and not shutting it off, that's a huge draw.
What size is your battery?, how old?, alternator or generator? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Dec 05, 2024 5:32 pm Post subject: Re: Eberspacher power source. |
Busdaddy,
The Eberspacher is from ‘68. It has the glow plug and spark plug. I don’t know the size off hand but the battery is about three years old. Running stock SP with generator.
The strange thing is the battery still runs the heater/lights/stereo but doesn’t have enough cranking amps to turn over the engine. Even with running the heater without engine running only for the length of time it takes the cooling cycle to turn off the heater. What is that, 2 mins?
Once the battery is jumped and I drive home (45mins) the battery is fine and starts with no problems.
I put a trickle charger / tester on last night. Tests show battery is good.
Tomorrow I will check to see if the glow plug is going out once the heater warms up. I work as it should during bench tests before I install the heater two years ago. But I wouldn’t think a glow plug would run down the batter in two mins.
BarryL Samba Member
Joined: November 01, 2004 Posts: 14794 Location: Casa de Oro, California
Posted: Thu Dec 05, 2024 7:05 pm Post subject: Re: Eberspacher power source. |
robin.richard wrote: |
Unfortunately if I run the heater without the motor running it instantly kills the battery and I can’t start the bus. |
But can you still run the heater on purpose with the motor not running? |
Posted: Thu Dec 05, 2024 7:06 pm Post subject: Re: Eberspacher power source. |
....... But I wouldn’t think a glow plug would run down the batter in two mins. |
Neither would I, maybe have the battery load tested, if that checks out put a volt meter on the electrical system, maybe your starter is weak? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Dec 05, 2024 8:03 pm Post subject: Re: Eberspacher power source. |
BarryL wrote: |
Yes, I can run the heater with the engine off, but I can’t restart the engine while the heater is running or afterwards.
It’s starting to sound like a battery issue, or as busdaddy said, maybe it could be a starter issue.
Nitramrebrab72 Samba Member
Joined: November 10, 2018 Posts: 764 Location: France
Posted: Thu Dec 05, 2024 8:59 pm Post subject: Re: Eberspacher power source. |
Those heaters drain a quite a bit of energy especially at the end of your journey when the cab is up to temperature the thermostat will be flickering between on and off regularly doing many more start ups for the same time period. Not the case when the cab is getting upto temp , that coupled with the effects of the battery temperature vs cranking amps. The two combined will show up any defects in either the charging circuit or the battery and starting circuit. Or a combination of the two. Have the battery tested (with a battery reader to check for available capacity and maximum available CCA). Check with the chart below for temp vs CCA your battery for the climate you have and the attached aux. might not be big enough. Test the voltage at the battery with the engine running, it should be between 13.8 and 14.4 the latter would indicate a strong alternator.
crofty Judas of the North
Joined: August 09, 2000 Posts: 19728 Location: Land of Whine and Phonies
Posted: Fri Dec 06, 2024 8:34 am Post subject: Re: Eberspacher power source. |
The heaters do draw a significant amount but this sounds like a battery Starter issue.
Ive run my heaters for long periods and never had a problem starting the bus. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Clara Samba Member
Posted: Fri Dec 06, 2024 11:20 am Post subject: Re: Eberspacher power source. |
crofty wrote: |
Ive run my heaters for long periods and never had a problem starting the bus. |
x2
I'd like to add that running the heater when the engine is off when camping, is one of the nice things about them.
If I'm getting going in the morning when it's very cold, I'd turn the engine and the heater on. I don't think I've used the heater with engine off much except when camping. But you should be able to. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Ollie W Samba Member
Joined: May 20, 2004 Posts: 835 Location: Portland, OR
Posted: Sat Dec 07, 2024 6:03 pm Post subject: Re: Eberspacher power source. |
I concur with the last two responses, you should be able to run the heater for a while on a fully charged battery and still be able to start the bus.
Changing the power wire draw location likely wont change anything. If you can, I'd put an amp meter to it, let it go through a cycle and see what the draw is like and if there's a spike or continuous draw even after it's all cooled down and off.
Of course, it's getting cold, so in all reality, I'd stick with the routine that you know works for now and then address it in the Spring. |
Posted: Tue Dec 10, 2024 10:14 am Post subject: Re: Eberspacher power source. |
Ollie W wrote: |
Ollie and other interested parties,
I ran a multimeter on the battery today. Here are my numbers:
Battery sitting at rest - 12.60
Running at med idle while parked~13.50 (first running)
Running at normal 800 RPM idle while parked ~ 12.50 (parked)
Running with heater on while parked ~ 12.48
Running during heater “cool down” while parked ~12.31
Running after “cool down” and heater off ~ 12.43
Engine off ~ 12.60
This morning I inadvertently turned off the engine before the heater completed its “cool down” cycle. One the heater was off and I attempted to see if I could start the bus and it started. No issues.
I’ve come to a couple of conclusions: first, this morning temps were north of 40 degrees so I believe so Nitramtebarb72 has a point with the temps. When I was having issues the temps were below 32 degrees. Secondly, I believe I need to address the + wire connection on the starter. I’ve never cleaned it or looked at it since I’ve owned the bus. Likely some minor issues there that may give issues during extreme weather.
Lastly, I’m going to take Ollie’s recommendation and hold off until warmer days to start switch things around. I’ve got a system - when I can remember it - and really love the extra heat on those sub-32 degree days.
Thanks for the hep guys.
Posted: Tue Dec 10, 2024 11:29 am Post subject: Re: Eberspacher power source. |
Those are some really low numbers for engine running, ever considered raising the idle speed? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Dec 10, 2024 12:36 pm Post subject: Re: Eberspacher power source. |
Agreed about the low voltage. Do you have an adjustable voltage regulator by chance? If so, bump it up a bit. If not, clean the connections and bump up the idle. |
Posted: Tue Dec 10, 2024 3:53 pm Post subject: Re: Eberspacher power source. |
Busdaddy and Ollie,
I see your point. I checked the volts before departing work this afternoon.
Before starting - 12.8
Engine running after warmup - ~ 13.89
I didn’t check with the heater running.
I’m going to follow your advice and clean all connections and bump up the idle a little. I don’t believe my BOSCH regulator is adjustable.
What should the volts be a normal idle, 14.0+? How about when not running, 12.5+?
Posted: Tue Dec 10, 2024 4:04 pm Post subject: Re: Eberspacher power source. |
12ish stopped and close to 14 running is the normal, the regulator cuts out below a certain output voltage to prevent reverse current flow, that ~12.5 sounds like no charging is happening at that speed.
You don't happen to have a degree pulley do you?, how low in the generator pulley does the belt sit? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Dec 10, 2024 4:23 pm Post subject: Re: Eberspacher power source. |
Busdaddy,
I have a standard OG pulley. Admittedly the belt might be a little loose.
All these great suggestions are just reinforcing what I already knew to be true, that I need to do my annual engine tune-up sooner rather than later.
I will check volts while the heater is running tomorrow.
Again, thanks for all the great insight and suggestions.
Posted: Fri Dec 13, 2024 2:00 pm Post subject: Re: Eberspacher power source. |
Busdaddy et al,
All is sorted out now…I believe.
All these great suggestions got me thinking about a loose belt, dwell angle, timing, etc. Once I tighten a loose belt, reset the dwell angle to 47, set timing at full advance with timing light and raised the idle speed to approximately 1000 rpm, I got good numbers. I even tested running the heater for 20mins. with the engine off. Then started the bus with no issues. I’m going to try the same test tomorrow morning when the temps are much lower.
One thing I noticed is while the heater was running without the engine running, the battery measured @ 12.5 -12.6 volts. Once the heater ran through its cool off period and shut down the battery reading went up to 12.7 volts, where it stays when the engine is not running. With the engine running at idle the battery measured 13.7 -13.8 volts, with the engine running at idle and the heater running it falls to approximately 13.5 - 13.6 volts.
I still have more to do including cleaning all electrical connections, but I believe I’m now in an acceptable range.
Please let me know if I’m still off.
Posted: Fri Dec 13, 2024 3:40 pm Post subject: Re: Eberspacher power source. |
I'd be satisfied with that, good job! _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25371 Location: Olympia Wash Rinse & Repeat
Posted: Fri Dec 13, 2024 7:57 pm Post subject: Re: Eberspacher power source. |
-Rich |
Have you soldered up the internal connections inside the fuse box and headlight switch?? sometime in the 1967 model year VW started to spot weld the brass pieces inside the fuse box together to skip corrosion and voltage drops.
Highly recommend the Wolfsburg West battery cables. The battery clamps are made of much longer lasting (if not over tightened) brass. Plus the terminals are soldered not just swedged onto the cable, so sealed against battery acid, water and oxygen from getting into that connection causing corrosion and thusly voltage drops.
When cleaning up and tightening down connections do use a dielectric grease to seal out all oxygen and water. For us here in cold wet PNW went from about every two years of needing to clean all the connections to over ten years and even then only a few connections needing that. _________________ In Stereo, Where Available! |
Posted: Sat Dec 14, 2024 5:59 pm Post subject: Re: Eberspacher power source. |
Eric&Barb,
My bus is a late 67 model so I’ll need to check for the soldered connections.
I do need new battery cables, both pos and neg. I’ll check out WW.
I will also use your advice on the dielectric grease. I use it for most things electrical. And having grown up in the PNW I am very familiar with the endless wet/cold weather. It may come as a surprise, but I really miss it.
