Oil Drain Plug in Case
2067Bug
2067Bug is offline
PostPosted: Fri Dec 13, 2024 5:57 am    Post subject: Oil Drain Plug in Case Reply with quote
Hello - for a 1957 36 hp engine with the oil drain plug in the case, is the drain plug the same for the engine, gearbox, and steering box? My engine oil case plug is worn, and I'm searching for a backup German plug. I believe the correct part number is 111101193. It also appears that Febi makes one, but I prefer original German.
Thank you and happy holidays.
esde
esde is offline
PostPosted: Fri Dec 13, 2024 8:20 am    Post subject: Re: Oil Drain Plug in Case Reply with quote
I have not compared them side-by-side, but I do think it is the same as the split case transmission drain plugs
Personally, I feel that you get a finite number of cycles with a steel plug in an alloy case, so I drain oil through the sump plate instead.
modok wrote:
2067Bug
2067Bug is offline
PostPosted: Fri Dec 13, 2024 4:55 pm    Post subject: Re: Oil Drain Plug in Case Reply with quote
esde - good point. Still curious if anyone knows for sure if the plugs are the same. Thanks
Eric&Barb
Eric&Barb is offline
PostPosted: Fri Dec 13, 2024 9:36 pm    Post subject: Re: Oil Drain Plug in Case Reply with quote
Lots of the original VW dealer parts manuals here:
http://www.oacdp.org/
The beetle parts manual for now is thru the "Upcoming" button at the top of that webpage.
Only downside to the above parts manual is it is from the 1970s, so while it has a lot of the early parts in it, there is a lot of later parts to wade thru.
There are several parts manuals in among the owner manuals here, several are pre-1961:
https://www.thesamba.com/vw/archives/manuals/type1.php
In Stereo, Where Available!
