Ozmello Samba Member
Joined: December 05, 2023 Posts: 49 Location: Nature Coast
Posted: Fri Dec 27, 2024 7:06 pm Post subject: Lack of Centering on Steering |
The steering on my Safari has always been very good. This morning I was driving it and suddenly there was an extreme lack of centering. I could move the steering wheel 4-6 inches without encountering any tension from the steering linkage. I pulled over and examined the front end to make sure everything was still connected. Visually, I saw no problems.
I went home, lifted the car and removed the front tires and wheels. The steering column looked good, and when I manipulated the column back and forth there appeared to be no slack there, but rather the slack appeared to be in the steering gear box. I pulled the fill plugs on the box and added 90 weight gear oil. I also adjusted the set screw on the box. The slack in the steering was not reduced.
Can the forum gurus point me in a good direction for correcting this issue? |
obus  Samba Member
Joined: March 08, 2001 Posts: 11776 Location: just off Garden State Parkway Exit 81
Posted: Sun Dec 29, 2024 1:49 pm Post subject: Re: Lack of Centering on Steering |
| I've not tried adjusting the nut on the end of the steering box as I didn't have the special tool, but I will see if I can tackle it using Mondshine's hack. I also need to confirm that nothing between the steering wheel and the steering box is loose. |
Posted: Thu Jan 23, 2025 11:50 am Post subject: Re: Lack of Centering on Steering |
| Decided to just suck it up and replace the steering box. Also replaced the tie rods and steering damper. Haven't taken it off the jackstands yet, but will likely do that tomorrow. We'll see how the camber and caster look then. |
madster Samba Member
Joined: November 01, 2006 Posts: 221 Location: Rio Grande Valley Texas
Posted: Thu Feb 06, 2025 4:38 pm Post subject: Re: Lack of Centering on Steering |
 _________________ 1966 BEETLE @ 1973 THING |
Posted: Mon Feb 10, 2025 1:52 pm Post subject: Re: Lack of Centering on Steering |
| LOL! Got the car off the jackstands. Front end feels good. Lack of centering and vague steering is corrected. Changed out brake shoes and found that I couldn't get the brakes to bleed, so back on jackstands and in goes a new master cylinder. Got that in today and will bleed the brakes tomorrow. Once I can actually stop again I will be heading to an alignment shop for a final tweak. Then I'm just going to enjoy the car for awhile rather than try to start any more projects. |
