panicman Samba Member
Joined: December 18, 2011 Posts: 2629 Location: Canby, OR
Posted: Fri Mar 07, 2025 9:15 am Post subject: Early pop out hinge part; help needed; installation |
After years of wanting them and looking at them, I bit on a set of original early pop outs for my 1960 bug.
One of the hinges is missing 2 parts, what I would instinctively call a tension bushing, and the other is a white plastic spacer:
As you can see, the plastic spacer I do have is broken and could stand to be replaced. I scoured the classifieds for hinge parts and found none of these.
Can anyone tell me the names of these parts for a better search, or even better, does someone know where I can buy these?
I can imagine I will have to make these on my own to match as closely as possible, but I'd prefer the genuine parts. Thanks!
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 2054 Location: San Fernando Valley, CA
my3bugs Samba Member
Joined: June 18, 2003 Posts: 863 Location: Moreno Valley
Posted: Fri Mar 07, 2025 1:12 pm Post subject: Re: Early pop out hinge part; help needed |
as i recall it goes in the hinge . when you tighten the knob it compresses to that cone to hold it open or closed .
i remember shipping some pop outs so i took half of the hinge off so as not to break the glass , and packaged that cone , knob and special screw real good ..... buy a used latch n rob it ? |
Posted: Fri Mar 07, 2025 1:20 pm Post subject: Early pop out questions |
56Cabrio wrote: |
Where does it go on the hinges ? |
The metal bushing is accessed by removing the knob, as it is situated directly under the knob. Tightening the knob applies pressure to this part, which allows you to position the hinge as desired, then tighten the knob against this bushing to lock it in place. The plastic washer is also situated at this joint in the hinge. Here is an image that shows where these parts are located on the hinge, but keep in mind, this is an image of an aftermarket hinge.
Posted: Fri Mar 07, 2025 1:23 pm Post subject: Re: Early pop out hinge part; help needed |
Bingo my3bugs! I have considered doing that, also I wonder if these internal parts stay the same for the later pop out hinges that are more plentiful. I also wonder if the aftermarket hinges contain the "cone" or if the manufacturers have changed to a different/cheaper option. |
Posted: Fri Mar 07, 2025 1:25 pm Post subject: Re: Early pop out hinge part; help needed |
If I can't source this part, I am considering a graduated stack of washers that would fit in there, perhaps JB welded together and sanded smooth. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11086 Location: Oregon
Posted: Fri Mar 07, 2025 1:31 pm Post subject: Re: Early pop out hinge part; help needed |
panicman wrote: |
Have you contacted Averys Aircooled in Kelso, Wa.?
Jason picks parts all over the PNW.
Also there's Always VW in Portland. Ashley has a pretty good parts stash. At least he did the last time I visited many years ago.
He's worth a call. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Fri Mar 07, 2025 1:48 pm Post subject: Re: Early pop out hinge part; help needed |
Thank you 67- great reminder. I have been trained and conditioned to go to the internet of things first.... not proud! |
Posted: Sun Mar 09, 2025 12:57 pm Post subject: Re: Early pop out installation; panicman's questions |
I got the pop outs in pretty good shape, but the old seals were cracked and brittle. Also, no pitting of the frames, and the hinge chrome is in decent enough shape, so with some disassembly, then cleaning and polishing them, I think they look good.
Here they are with most hardware removed and the old seals cut out.
I polished each piece of chrome in a bench grinder with a buffing wheel. The knobs I cleaned and soaked in detergent and then hand polished with rubbing compound, then I waxed everything.
Getting ready to install the new seals.
I first carefully buffed the frames on the wheel, and got them remarkably clean and bright.
The seals went on pretty easily with a plastic trim tool. I reassembled everything, and am happy with how they turned out.
I still plan to find that correct part for the hinge tensioner, but that can be done anytime.
Now it's time for me to gather my guts and install these. The car interior still looks like the day I installed the cloth headliner and windows, so I'm not eager to start kicking glass out and cutting the fabric.
But it must be done! |
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3842 Location: Eastern WA
Posted: Sun Mar 09, 2025 4:28 pm Post subject: Re: Early pop out hinge part; help needed |
Search for pop out latch parts not hinge, might have better luck if there is anything out available. _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Sun Mar 09, 2025 5:04 pm Post subject: Re: Early pop out hinge part; help needed |
Thanks Teeroy! Now that you say that, it dawns on me that I see 'latches' used more than 'hinges'. |
DAWGNME Samba Member
Posted: Sun Mar 09, 2025 6:38 pm Post subject: Re: Early pop out hinge part; help needed |
I have to say Great work! love the way the parts turned out.
Were the old seals hard to remove and did you polish the frames also? I am trying to follow along with you to get mine done. _________________ Having Fun While Learning With My Build/Refresh/Just get it Driving already S*YTTT!
http://www.thesamba.com/vw/forum/viewtopic.php?t=648483&highlight=
The Rich Can Buy What Ever They Want.
But!
They Have To Beg For What They Really Need.
Now 1963, 69 BUG, Blue 67, 74 FATTY |
Posted: Sun Mar 09, 2025 7:44 pm Post subject: Re: Early pop out hinge part; help needed |
Thanks!
No, the old brittle seals fortunately came out easily and cleanly. I carefully made a slice along one side of the "spine" of the seal, maybe 4 inches long and tried pulling, and out it came, and then I just pulled it out of the joint all the way around.
I did clean the channel with lacquer thinner and paper towels. Then I slowly worked the frame across a polishing wheel on my bench grinder. I started with fine polish, and worked up to coarse. I was able to easily remove all oxidation and almost all the scratches.
I fear this has been the easy part. Now I need to work up the cajones to actually start drilling holes in the car. |
Bub Samba Member
Joined: June 10, 2004 Posts: 1300 Location: Central Washington
Posted: Mon Mar 10, 2025 7:41 am Post subject: Re: Early pop out hinge part; help needed |
I'd love to see any method you come up with for locating the rear-latch part that screws to the body. That's a horrible thing when you have a fresh headliner...even with no headliner I don't like it. _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Posted: Mon Mar 10, 2025 9:03 am Post subject: Re: Early pop out hinge part; help needed |
That's the part that is going to wreck my sleep. I am sooo not eager for that part. |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Wed Mar 12, 2025 10:03 am Post subject: Re: Early pop out hinge part; help needed |
I wonder if a test tube rubber stopper could be adapted to replace the missing latch bushing.
You're almost there...
_________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Wed Mar 12, 2025 2:14 pm Post subject: Re: Early pop out hinge part; help needed |
panicman wrote: |
Trust and believe I am not eager also, but my question will be is there a right or wrong way to install the seals. Curve to the inside to the car or the other way around? _________________ Having Fun While Learning With My Build/Refresh/Just get it Driving already S*YTTT!
But!
Posted: Wed Mar 12, 2025 10:26 pm Post subject: Re: Early pop out hinge part; help needed |
Mukluk, thank you for the Tech bulletin AND the rubber stopper idea. I think that might work.
DAWGNME, when I installed my seals, there is no contour to them. They are just straight up and down.
Posted: Thu Mar 13, 2025 6:40 am Post subject: Re: Early pop out hinge part; help needed |
Now those look really nice and straight I have seen ones that have curved edges. (there's even no bacon like they call it) where did you purchase your seals. Great work and very informative! _________________ Having Fun While Learning With My Build/Refresh/Just get it Driving already S*YTTT!
But!
Posted: Thu Mar 13, 2025 8:20 am Post subject: Re: Early pop out hinge part; help needed |
They were included with the windows and I think they had been stored with them, boxed for some time, so it's possible they shrank a little. They are WW seals. New pinch welt arrives today, so I may take a stab at these this weekend. |
