Windshield Wiper Wiring
13nunez
13nunez is offline
PostPosted: Tue Dec 16, 2014 4:07 pm    Post subject: Windshield Wiper Wiring Reply with quote
So it recently started raining here in So Cal, so now i decided to wire up my windshield wipers. I've been going based on the 1967 VW Diagram but i keep blowing my fuse. So i need help wiring the Wiper motor to my Wiper Switch. PLEASE. I am using using my bug as my daily driver so i really need to get this working. any help?
Here is my Motor
Here is my Switch
grandpa pete
grandpa pete is offline
PostPosted: Tue Dec 16, 2014 4:45 pm    Post subject: Reply with quote
This diagram is in the technical section on the Samba
lf you click on this twice it will enlarge
center left W is wiper motor .....under it is the switch E
31b black wire from switch to motor
53 black wire from switch to motor
53a black and red from switch to motor
53b yellow black to motor
31 on switch 12 volt to fuse
switch has to be grounded...clean it
Confusing that the drawing has 6 wires and only 5 pin designations .
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
jhoefer
jhoefer is offline
PostPosted: Tue Dec 16, 2014 5:20 pm    Post subject: Reply with quote
31 on the switch is ground. It does NOT go to the fuse box.
The power wire from the fuse box goes to the + tab on the switch.
The dimmer switch on the column grounds through terminal 31 on the wiper switch. The wiper switch itself is grounded through its housing to the metal dash.
grandpa pete
PostPosted: Tue Dec 16, 2014 5:24 pm    Post subject: Reply with quote
The power wire from the fuse box goes to the + tab (or #30) on the switch.
YOU should take ANOTHER look at the DRAWING !!!
31 black wire direct to the fuse !!!!
There isn't any contact 30 on the switch E !!!
63 two fold rag
jhoefer
jhoefer is offline
PostPosted: Tue Dec 16, 2014 5:32 pm    Post subject: Reply with quote
You're right, #30 would be for a later switch, a 67 would still be labeled "+".
You connect 31 to the fuse box and you'll blow the fuse as soon as you turn the key.
#31 is a standard designation for a ground terminal. Just as #30 is a standard designation for a constant +12V terminal, or #15 for switched +12V.
grandpa pete
PostPosted: Tue Dec 16, 2014 5:38 pm    Post subject: Reply with quote
If you are trying to tell me that 31 is the designation for the brown wire below the number 31 then what is the designation for the black wire to the right of the number 31
I can only work with the drawing I have ...do you have other sources ?
I am teachable.......
63 two fold rag
jhoefer
jhoefer is offline
PostPosted: Tue Dec 16, 2014 5:46 pm    Post subject: Reply with quote
grandpa pete wrote:
If you are trying to tell me that 31 is the designation for the wire below the number 31 then what is the designation for the wire to the right of the number 31
+: black wire to fuse box (wiper power) (Look for the + in the lower left corner of the switch in the diagram) (In '68, this changed from + to #30)
53: black wire to wiper motor 53 (low speed)
53b: black/yellow wire to wiper motor 53b (high speed)
53a: black/violet wire to wiper motor 53a (park power)
31b: brown wire to wiper motor 31b (park ground)
31: brown wire to dimmer switch (ground toggle for dimmer relay)
(unlabeled): ground symbol to wiper switch body (park ground)
Circled 4: Wiper motor grounds through case mounting to body. (But can also be a separate brown wire from wiper motor #31 to ground depending on year/part.)
grandpa pete
PostPosted: Tue Dec 16, 2014 6:46 pm    Post subject: Reply with quote
I have never seen this designation before so 13nunez you are left with following the wire colors on the non designated terminals .
63 two fold rag
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Tue Dec 16, 2014 7:49 pm    Post subject: Reply with quote
The wiper switch is GROUNDED just by being bolted to the dashboard! Terminal 31 on the switch is not for the wiper circuit at all, it is a "source" of ground for other circuits.
Some Official VW diagrams weren't laid out very well. I went in and "fixed" the wiper diagram here, making it easier to see what designation goes with which wire:
Donnie strickland
Donnie strickland is offline
PostPosted: Tue Dec 16, 2014 7:52 pm    Post subject: Reply with quote
As Andy says that factory diagram can be a little confusing, but yes, 31 is always ground, and the black wire is simply labeled with a "+" sign -- you have to look really really closely to see it on the diagram. Another giveaway is the color -- solid black, on a VW, is always switched power.
13nunez, here's a key to the numbers and what they mean:
http://en.wikipedia.org/wiki/DIN_72552
71 Elm Green FI A/T Squareback
Dynaflash
Dynaflash is offline
PostPosted: Wed Dec 17, 2014 8:31 pm    Post subject: Reply with quote
Anybody have a diagram like above for a 62 ?
I have the full diagram but think this wiper only one would be more clear to me
The Android
PostPosted: Thu Dec 18, 2014 3:06 am    Post subject: Reply with quote
1962 is really simple.
Abscate Premium Member
Abscate is offline
PostPosted: Thu Dec 18, 2014 3:32 am    Post subject: Reply with quote
Nicely done. That switch on the diagram is reall easy to mix up the + and 31 terminals. You sure can't count on the colours being right on a thrice rewired a Beetle.....
Dynaflash
PostPosted: Thu Dec 18, 2014 6:34 am    Post subject: Reply with quote
Wow. Thanks for the info. On the 62 that will be a big help to me
alidabiri
alidabiri is offline
PostPosted: Mon May 19, 2025 1:13 pm    Post subject: Re: Windshield Wiper Wiring Reply with quote
Hi folks. I'm trying to test my wiper motor.
everybody says 53, 53a, 53b, 31, 31b. I don't know what does are and where they go (maybe the steering column).
they are: black, brown, green, black/white, black/yellow.
I know the brown is ground.
I just kneed to know the high high and low speed so that I can connect the battery to it and see if the motor is working or not.
Eric&Barb
Eric&Barb is offline
PostPosted: Mon May 19, 2025 1:24 pm    Post subject: Re: Windshield Wiper Wiring Reply with quote
Always good to mention the year of the wiper or at least the VW in question.
jhoefer posted that wiring info earlier in this same thread.
In Stereo, Where Available!
alidabiri
PostPosted: Mon May 19, 2025 1:34 pm    Post subject: Re: Windshield Wiper Wiring Reply with quote
Sorry about that. My bad.
it's a 72 VW super beetle wiper motor.
Eric&Barb
PostPosted: Mon May 19, 2025 2:24 pm    Post subject: Re: Windshield Wiper Wiring Reply with quote
No worries, still the terminal number designations will be the same. Euro auto manufactures standardized both wiring colors and terminal designations so that someone working on a Volvo or other Euro make could understand working on VW wiring also.
Down at the very bottom of each of the wiring webpages is a listing of all colors and terminals to what they meant.
alidabiri
PostPosted: Mon May 19, 2025 2:40 pm    Post subject: Re: Windshield Wiper Wiring Reply with quote
Sorry. that didn't help or answer the question.
My question is:
what color wire of the above color wires provide the power to the motor?
Eric&Barb
PostPosted: Mon May 19, 2025 2:44 pm    Post subject: Re: Windshield Wiper Wiring Reply with quote
My question is:
Look at the 1967 wiring diagrams a couple of posts below what jhoefer posted and combine those two bits of info.
