HAPI Magnum 2.2L, SCAT heads , dual ignition airplane engine
I'm familiar with the HAPI engine, and...
it's not worth fixing
0%
 0%  [ 0 ]
it's worth fixing, get a crank
0%
 0%  [ 0 ]
it's worth fixing, the crank is not the problem, read my comment
0%
 0%  [ 0 ]
Total Votes : 0
Harvey Cheyne Jr
Harvey Cheyne Jr is offline
PostPosted: Sun May 25, 2025 8:03 pm    Post subject: HAPI Magnum 2.2L, SCAT heads , dual ignition airplane engine Reply with quote
I have been told HAPI went out of business because they went with bigger displacement without going to a bigger crank, and as a result, some cranks broke
Is this true?
If it is true, I have to split the case and find out which crank I have, right ? (this engine is supposedly pickled NOS, never run, and has no documentation with it)
If this is true, what crank do I need ?
Will the bigger crank have bigger main bearings, longer stroke, or both ? What was the crank failure mode and what's the fix ?
Also, supposedly they used aluminum flywheels which also broke, so I just need a stock steel flywheel, right ?
I am not a VW guy but i want to keep this engine and run it, because other than the crank issue, this engine and HAPI as a company have a great reputation
Should this thread be in a different forum ? 'Off road" seemed the closest match
oprn
oprn is offline
PostPosted: Mon May 26, 2025 4:23 am    Post subject: Re: HAPI Magnum 2.2L, SCAT heads , dual ignition airplane engine Reply with quote
I have no idea what issues the HAPI engines had. What are you going to use the engine for and what will it be installed in? There are way too many unknowns here.
By the way, in a type 1 VW engine it is not possible to get 2.2 L displacement with a stock VW crankshaft. It's got somebody's stroker crank in there...
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Tue May 27, 2025 10:25 am    Post subject: Re: HAPI Magnum 2.2L, SCAT heads , dual ignition airplane engine Reply with quote
This would be better asked in the Performance forum. Those guys would know about such things.
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
