Ragtop hook not correctly aligned with hole
pgiraud
pgiraud is offline
PostPosted: Mon Jun 16, 2025 2:26 am    Post subject: Ragtop hook not correctly aligned with hole Reply with quote
Hi,
I'm currently reassembling a car (I bought in pieces). I has a 2 folds ragtop. The cover is brand new. And I restored (repainted) the mechanism.
But the hook doesn't perfectly align with the hole. I have to push the hook a bit upwards.
Did you already experienced a similar problem. Any suggestion on how to fix it?
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Mon Jun 16, 2025 12:07 pm    Post subject: Re: Ragtop hook not correctly aligned with hole Reply with quote
Are the guides in good shape?
Jimbo
TDCTDI wrote:
67rustavenger wrote:
pgiraud
pgiraud is offline
PostPosted: Mon Jun 16, 2025 9:51 pm    Post subject: Re: Ragtop hook not correctly aligned with hole Reply with quote
They seem to be in a rather good shape.
VW_Jimbo is offline
PostPosted: Mon Jun 16, 2025 10:23 pm    Post subject: Re: Ragtop hook not correctly aligned with hole Reply with quote
On the underside of the header assembly there are 2 phenolic rub blocks. Are those in place?
Jimbo
pgiraud
pgiraud is offline
PostPosted: Mon Jun 16, 2025 10:42 pm    Post subject: Re: Ragtop hook not correctly aligned with hole Reply with quote
Are you talking about the inner slides (white plastic rectangular pieces)?
The answser is "yes, they are in place". I replaced them with a kit from Grumpy's Metal.
I wonder if the powder coat can distort the metal.
Käfer2
Käfer2 is offline
PostPosted: Tue Jun 17, 2025 7:15 am    Post subject: Re: Ragtop hook not correctly aligned with hole Reply with quote
You could check, if the powder coating layer thickness varies at
the locking bow and longitudinal guide plates at their contact surfaces
If the layer thickness is larger at the front, the hook points downwards
VW_Jimbo is offline
PostPosted: Tue Jun 17, 2025 8:39 am    Post subject: Re: Ragtop hook not correctly aligned with hole Reply with quote
Yep, the phenolic rub blocks! Slides are different.
Jimbo
56Cabrio
56Cabrio is offline
PostPosted: Tue Jun 17, 2025 3:40 pm    Post subject: Re: Ragtop hook not correctly aligned with hole Reply with quote
Does the 2 fold have phenolic rub blocks ? I thought they were only on 3 fold & bus ragtops
F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023
VW_Jimbo is offline
PostPosted: Tue Jun 17, 2025 9:44 pm    Post subject: Re: Ragtop hook not correctly aligned with hole Reply with quote
Try this website. There is a 2 Fold video install down mid page. Check it out and see if anything is different or wrong.
https://grumpysmetal.com
Jimbo
pgiraud
pgiraud is offline
PostPosted: Fri Jun 20, 2025 12:08 am    Post subject: Re: Ragtop hook not correctly aligned with hole Reply with quote
Sanding down some of the coat in some places (support zones) helped a bit. Seems to make the cover waterproofing better as well.
Also I rectified / straightened the hook itself a bit. It was slightly distorted.
VW_Jimbo is offline
PostPosted: Fri Jun 20, 2025 8:39 am    Post subject: Re: Ragtop hook not correctly aligned with hole Reply with quote
That’s great! Just a little bit too much here and there can make all the difference. Glad you found the reason.
That would have driven me nuts!
Jimbo
