David Bunin Samba Member
Joined: June 24, 2025 Posts: 16 Location: Rockwall, TX
Posted: Tue Jun 24, 2025 4:34 pm Post subject: New Kid |
Hello Forum,
My name is David. I'm the new kid in school here. I have recently become the new caretaker of a yellow 1974 Ghia convertible that I bought from my uncle. It was his pride and joy, and he kept it very clean. But he isn't a mechanic, and I am. Sort of. I am an aircraft mechanic, so I'm used to air cooled, horizontally opposed piston engines. On the other hand, I know virtually nothing about Volkswagens.
My uncle gave me his dog-eared copy of John Muir's book How to Keep Your Volkswagen Alive and I've purchased a second-hand Chilton manual. But both of those publications cover a variety of models, and I'm going to need help that is more specific to THIS car.
My goal is to keep this neat little car on the road. I already took it to a local drive-in and parked next to a Dodge Viper. The Viper didn't get half of the looks that my little sunbeam collected.
But the car does need some work. I've already adjusted the choke and it starts and idles much better. I've also shortened the fuel line between the pump and carburetor. It was so long that the fuel filter was rubbing on the part of the intake manifold that is actually a piece of exhaust manifold.
The problem I'm worried about most is that it smells like gasoline. Yeah, sure, it's an old car and they smell like gas in the garage much more so than a new/modern car. But this one smells like gas in the cabin while I'm driving it down the road, with the top down. That can't be right.
In my mind there are two possibilities. Either engine compartment vapors are coming through the heat ducts (I'm not using the heater) or there is a fuel leak related to the gas tank in front of me. I'm not sure where to begin, so I thought I would join up here and ask the experts. What say you? |
Leonard Hooks Samba Member
Posted: Tue Jun 24, 2025 5:06 pm Post subject: Re: New Kid |
Welcome, David. Congratulations on your acquisition. You will find great friends here. The gas smell could be coming from the front. I'm dealing with one of those were the interior smells gas on a hard turn. There are numerous threads here about gas smells.
Post some pictures. _________________ Ghia again...after 48 years
1970 Karmann Ghia, Irish Green
1965 Mustang
Owned a 1971 Ghia, Irish Green from 71-77
Owned a 1982 Porsche 924 |
22manybugs Samba Member
Joined: March 30, 2006 Posts: 398 Location: Yorba Linda, Calif
Posted: Tue Jun 24, 2025 5:08 pm Post subject: Re: New Kid |
Hello David, welcome!
Post some photos, I am sure everyone wants to see the car. Also, people may point out things for you to check.
The John Muir book is good overall, especially for someone new; it can be long-winded when you just want to review a particular maintenance or repair step. I don't personally get much from the Chilton manual, but that could be just me. My favorite is the Haynes manual for finding information quickly and clear information. Also, if you really want to dig into everything, you should get the Bently manual - you want the orange one for 1970 to 1979.
Fuel smell is almost always caused by broken/cracked/rotted fuel vapor lines. Those are under the front hood, most are small diameter hoses (plus a couple large diameter hoses) that connect to the gas tank, expansion tank, and fuel filler pipe. There are also a couple vapor lines under the right front fender connecting to the fuel filler pipe. Do a search in the Ghia forum for "vapor line sketch" and there will be a post that includes a sketch of the filler lines along with lots of photos of the vapor lines.
Hope that helps! _________________ Lon
1969 Karmann Ghia convertible
1971 Westfalia camper |
Posted: Tue Jun 24, 2025 5:20 pm Post subject: Re: New Kid |
Car with my Uncle:
Car with my wife:
You might notice that I was able to get the same custom plate in Texas that my Uncle had in California. I like that it's very cagey. He is great for jokes like that. He is a doctor, and his Acura had a plate that said ICURYA.
Engine compartment:
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1913 Location: Raleigh, NC
Posted: Wed Jun 25, 2025 4:28 am Post subject: Re: New Kid |
Aside from the fresh air hoses coming off the fan shroud, which should be corrugated paper hose, that engine bay is incredibly factory original for '74. Don't see that very often!
One suggestion: please move the fuel filter out of the engine bay. Ideally down beside the trans where the hard line exits the frame horn. They have been known to be the cause of engine bay fires. _________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
Posted: Wed Jun 25, 2025 6:57 am Post subject: Re: New Kid |
Thank you. Yes, the car is very original. Surprisingly so. One of my little projects is to try to replace any of the hoses that look to be 50 years old, and I think it might be all of them.
I'll see if I can find the location you suggest for the filter. I believe there is a hard line in the engine compartment in the feed to the fuel pump on the engine, but I haven't traced it forward of the cooling shroud. Still, there needs to be a connection inside the engine bay because the outlet of the fuel pump is larger in diameter than the inlet on the carburetor. Somehow or another, there has to be a reducer, and it takes two different size hoses. Right now the filter is serving as the reducer, in addition to just being the filter.
One hose that made me scratch my head was the crankcase vent that runs from a nipple adjacent to the oil fill to a nipple on the air intake. It's a plastic hose rather than rubber, and it is in an S shape, but the bends are so sharp that the hose is almost completely kinked off at both ends. That can't be right. (Yes, I know that crankcase venting isn't creating any problems, it's an emissions thing. But still I want this car to be as "right" as I can make it. Remember, I think like an aircraft mechanic.) |
smuenchrath Samba Member
Joined: February 20, 2005 Posts: 376 Location: Calgary, Alberta
Posted: Wed Jun 25, 2025 1:38 pm Post subject: Re: New Kid |
I installed one of these brackets on my 69 Ghia.
https://www.thesamba.com/vw/classifieds/detail.php?id=1901747
Its not required, but nice to keep the filter good and secure. _________________ 68 Ghia Regatta Blue Convertible
69 Ghia Toga White Coupe
74 Westfalia |
Posted: Wed Jun 25, 2025 4:16 pm Post subject: Re: New Kid |
Very nice looking Ghia.
David Bunin wrote: |
Yes, there should be a fuel hard line in the engine compartment that passes through the tin between the engine and transmission, bends around the fan shroud, and gets close to the inlet on the fuel pump. Then there only has to be a small length of fuel line connecting the hard line and fuel pump. The recommended filter location is in front of the hardline, next to the transmission.
One thing you may want to check is the hard line where it passes through the tin has a rubber grommet to prevent the tin digging a gouge in the hard line from vibration. If there is no grommet, a lot of people use a short piece of fuel line, cut it open lengthwise, wrap it around the hard line, then shove it into the tin opening. That serves as a rubber grommet.
A stock fuel pump and stock carburetor use the same size fuel line, a reducer should not be needed. I can't tell what fuel pump is installed from the photo, but something isn't right if the same fuel line won't fit between the fuel pump and carburetor. _________________ Lon
Posted: Thu Jun 26, 2025 5:27 am Post subject: Re: New Kid |
This crankcase vent hose? This is a 74 I used to own. If you search through the more original '74 models on Bring a Trailer, you'll find a similar looking vent hose.
This pic is on an older car with swing axles (you've got CV axles on your 74) but this is the general location where you want the fuel filter, beside the transmission.
So that this doesn't happen
If you need a reducer for the the fuel pump, then you have the wrong fuel pump. It's probably an inexpensive aftermarket pump. If you want the original German Pierburg pump, you can buy immaculately restored ones from Bill at sparxwerks.com. Bill can also rebuild your distributor if you ever think you need it done. And if you feel like your carb ever needs rebuilding, Tim at volkzbitz.com is your guy. _________________ Currently own:
Previously owned:
jason_hamilton Samba Member
Joined: February 07, 2003 Posts: 1125 Location: Abbotsford, BC
Posted: Fri Jun 27, 2025 1:31 pm Post subject: Re: New Kid |
If you are using gasoline with ethanol, your fuel lines may not be compatible and may have started to break down.
I would replace all soft fuel lines out of caution. _________________ Jason Hamilton
1969 Karmann Ghia coupe
@MiddleAgedHoon |
Posted: Fri Jun 27, 2025 3:46 pm Post subject: Re: New Kid |
Yeah, I'm kind of thinking the same thing. My uncle drove this car weekly for a lot of years and then he filled up the tank for me (which I think he usually wouldn't have done for himself). It's probably safe enough to drive in the short term. I think I'll run it down closer to empty than full before I go after hose replacements wholesale. That could take a while.
I am tickled with this car's originality, but I won't let that stop or slow me from making it safe to drive on the streets.
One problem with old cars that are very original is that some of the bits are past their best-by date.
Like I said, Uncle Nelson kept this car nice and clean. Kept it maintained regularly by shops near him, and fixed things as they broke. But he's not a mechanic and I (mostly) am. That's why I was 'the chosen one' among his nephews. He judged me the most likely to be capable of keeping his baby on the road for the long term.
David |
Posted: Fri Jun 27, 2025 5:43 pm Post subject: Re: New Kid |
If the soft fuel line under the gas tank fails, there's nothing stopping total loss of fuel. The gasoline will follow the hose into the central chassis tunnel, pool there, then exit at the drain hole just forward of your rear axle. You then get a huge puddle of evaporating gas under your car, ready to be sparked by just about anything. Like say, your furnace's pilot light if your garage is arranged that way.
You'll want to check this out sooner rather than later. _________________ Jason Hamilton
@MiddleAgedHoon |
Marcdeb Samba Member
Posted: Fri Jun 27, 2025 6:17 pm Post subject: Re: New Kid |
Hi David,
Welcome to TheSamba. Your car looks great. Nice color too. The most helpful Repair manual is The Bently. There's many different volumes so make sure you get the 1970 to 1978 Beetle & Ghia book with the orange cover.
Here's a link to one, but you can shop around on TheSamba classifieds, ebay, and other online book sellers. Usually I see them anywhere from $30 to $60. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Posted: Sat Jun 28, 2025 3:53 pm Post subject: Re: New Kid |
Thank you, I appreciate the help. I'm feeling a little dumb. You said "here's a link" but I'm not seeing the link, and also I failed to locate the Classifieds section here. I feel like it must be hiding in plain sight, but... a little more help, please?
Having a copy of The Bently book sounds like a good idea. |
Posted: Sat Jun 28, 2025 3:55 pm Post subject: Re: New Kid |
jason_hamilton wrote: |
You'll want to check this out sooner rather than later. |
I concur. Please bear in mind that it's now the middle of summer in Texas. It's quite possible that very little will happen to/with this car over the next two months. I'll drive it a little maybe, and I'll keep my battery charger handy. |
Posted: Fri Jul 04, 2025 1:09 pm Post subject: Re: New Kid |
Wife and I took the Ghia out for a cruise today. A VW dealer recently opened in our little county, and I couldn't resist stopping by to take this picture.
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4141 Location: Georgia
Posted: Fri Jul 04, 2025 1:17 pm Post subject: Re: New Kid |
That’s awesome!
I think VW needs to be reminded of where they came from. _________________ Volkswagen!
(Compression 8.7:1) |
kingkarmann Samba Member
Posted: Sun Jul 06, 2025 8:23 am Post subject: Re: New Kid |
Very Cool!
Congrats on being the next caretaker and.....
Welcome to The Samba  |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25875 Location: Olympia Wash Rinse & Repeat
Posted: Thu Jul 10, 2025 2:06 pm Post subject: Re: New Kid |
Definitely the best idea!!
https://duckduckgo.com/?t=lm&q=OFFICIAL+VW+WOR...x=shopping
Older copies have the wiring diagrams in color, later mid-1990s? they went to B&W. _________________ In Stereo, Where Available! |
Rome Samba Member
Joined: June 02, 2004 Posts: 10517 Location: Pearl River, NY
Posted: Sun Jul 13, 2025 8:19 am Post subject: Re: New Kid |
You can get the engine compartment side panels' yellow paint much cleaner simply with WD-40 and firm, repeated wiping with many paper towels.
Ghias (also Beetles and Type 3) with this style bumper had a black strip in the center channel. This visually reduced the "bulkiness" of the solid bumper. If you plan to apply the strip, don't use electrical tape- the adhesive will ripple and pull off soon. Instead, use marine "bootstripe" tape after you wipe the channel clean with isopropyl alcohol or similar. Here's a press photo of a '74 in which you can see the black strip.
And a good photo from the German '73 Ghia brochure-
