1969 Baja Bug Seat Question
Low82C10
Low82C10 is offline
PostPosted: Wed Jul 02, 2025 8:32 am    Post subject: 1969 Baja Bug Seat Question Reply with quote
we got a 69 baja bug and previous owner has the EMPI race trim high back seats like these https://www.kustom1warehouse.net/Race_style_suspension_seats_p/superseathighbackplus2.htm?gQT=1
and they added these https://empius.com/products/slide-slide-6-pr-2/ race trim seat risers but what they did was just welded a bracket on the floor with some bolts to bolt the risers to.
my question is, is there a way to properly use those seats but also use them with the original factory sliders on the floor?
the sliders in the seat riser link above are not in the car or the seat so i wasn't sure if i had those would i be able to use the factory sliders with the seats/risers we have??
NJ John
NJ John is offline
PostPosted: Wed Jul 02, 2025 3:10 pm    Post subject: Re: 1969 Baja Bug Seat Question Reply with quote
I guess you want to have adjustable seats? You can add the adjusters that came with the mounts. Or cut apart factory seats and steal the bottom framing. Then it’s up to you to make it work. I did it on 73 and up style sliders. It was a pain, but I added them to Scion seats.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
viiking
viiking is offline
PostPosted: Thu Jul 03, 2025 5:52 pm    Post subject: Re: 1969 Baja Bug Seat Question Reply with quote
I always worry about the attachment points for seats on the VW pan. The originals were poor so adding even more weight and fulcrum potential IMO just can lead to failure in an accident.
If I was actively using the baja off road, I'd be looking at adding some sort of reinforcement for the brackets or seat slider under the pan to bolt to. Or to cross brace across a roll bar if you have one??
