6v electrical wizard help needed. (Starter issue)
NAES
NAES is offline
PostPosted: Sun Jul 06, 2025 8:07 pm    Post subject: 6v electrical wizard help needed. (Starter issue) Reply with quote
Helping my buddy on his '58 Westy. Very original with a 6v system and minimal hackery to the wiring.
The problem is the starter not engaging intermittently.
Ignition was removed and sprayed down with contact cleaner. Terminal function verified with a test light and power applied.
Power to the 6v starter relay verified.
Ignition switch power to the relay verified.
Relay clicks when power is applied.
Power verified at starter solenoid when ignition switch is activated.
6v power at the back of starter motor verified.
Screwdriver will jump both starter motor and solenoid to sterter motor. Both sound good with no hesitation.
Battery terminals cleaned.
Battery ground cleaned
Trans strap grounds cleaned
Starter connections cleaned.
Ignition switch screw terminals cleaned.
We're still having an intermittant issue with the switch engaging the starter solenoid. My guess is the starter solenoid is the problem even though it will engage every time with a screwdriver jump.
Are we missing anything? I've exhausted all the things I can think of. Before we swap solenoids or starters is there anything you guys can come up with. I'd hate to have hime throw $130 bucks at the problem with no change.
Thanks everyone, NAES
Barndoor Mafia
Box On Wheels
SBS #00
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sun Jul 06, 2025 10:57 pm    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
Remove and clean the inside of the ignition switch with electrical contact cleaner. Remove the starter and shine up the mating surfaces on the starter and the bell housing. These are things I need to do to my 1957 Kombi after each winters storage. The switch is 69 years old and the wiring gains resistance with age.
You might also consider tinning the ignition switch wire ends.
Roads Scholar
Member# 2059
sub-hatchtim
sub-hatchtim is offline
PostPosted: Sun Jul 06, 2025 10:59 pm    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
Og harness maybe full of corrosion
Try adding a hard start relay
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
thom
thom is offline
PostPosted: Mon Jul 07, 2025 10:19 am    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
Dumb question, but what condition is the battery? I've had this issue many times, and even though the battery "wasn't that old" when I took it down to have it tested, it was bad.
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
NAES
NAES is offline
PostPosted: Mon Jul 07, 2025 11:14 am    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
Thanks everyone for the replies.
OG VW switch was removed and internals sprayed with contact cleaner through the key hole. We didn't pop it apart to physically clean contacts. We weren't ready to go that far seeing as we don't have a backup unit on hand in case we screw something up.
I forgot to mention there is a 6V relay installed. We verified power to all the terminals and the relay clicks when starter power is engaged. Guessing that's good enough?
No idea on the age of the battery. Being 6V I guess its a crap shoot. Lights seem like they're bright enough for 6V. The engine cranks over like a champ when the starter actually engages.
We didn't think to remove the starter and clean the surface between the starter and bell housing. Seems like a smart thing to do, especially since there's a lot of oil on the engine and trans.
Again, thanks for the feedback. We'll get it up in the air and check things again soon.
Barndoor Mafia
Box On Wheels
SBS #00
swharris
swharris is offline
PostPosted: Mon Jul 07, 2025 11:20 am    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
With all the other issues checked, as you have pointed out, IMO this will either be a bad spot on the starter armature or the solenoid is going south/bad. Pull the starter, take it apart, and clean/sand the armature. Confirm the solenoid works every time with 4-6v. Also make sure the actuating arm that connects the solenoid to the starter armature is not binding and is working as it should. BTW there is no reason to clean the mounting surfaces of the starter/bell housing other than to make sure the gear engages properly. There is no electrical reason. The bolts will ground the starter to trans/ground strap/body.
guatebus
guatebus is offline
PostPosted: Mon Jul 07, 2025 12:04 pm    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
I'll repeat the battery advice given above: get the battery tested or just get a new one.
When in the "pull in" phase, the solenoid on the starter will draw more current than when just turning over the motor. So just because it cranks OK once it gets going doesn't mean that the battery is OK.
The first bad battery symptom I get on my 6V system is the starter not engaging, especially when the motor is warm.
'64 standard microbus
'69 deluxe microbus
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Jul 07, 2025 4:01 pm    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
Definitely load test the battery.
1. Did you clean dielectric the starter and transaxle surfaces where they mount together?? Need that for a good ground there.
2. Did you clean and dielectric grease between the starter body and the solenoid for a good ground there??
3. How is the starter motor brushes?? Need to be longer than the cages they reside in.
4. How worn are BOTH STARTER BUSHINGS?? If not running a self supporting starter.
5. Fuse box riveted connections soldered up??
6. Headlight switch internal and external riveted connections soldered up??
7. Have you load tested the wiring for voltage resistance with a spare sealed beam head light connected (solenoid disconnected for this test) to the smaller wire at the solenoid?? Need to know how much voltage at the battery and at the solenoid.
If the starter solenoid pulls and engages the starter motor by shorting at the solenoid, then it is fine.
In Stereo, Where Available!
NAES
NAES is offline
PostPosted: Tue Jul 08, 2025 11:21 am    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
We didn't remove the starter. We did remove the battery cable and solenoid plug and cleaned them well but did not use dielectric grease.
Starter wasn't removed
3. How is the starter motor brushes?? Need to be longer than the cages they reside in. We'll get to that next time we work on it
4. How worn are BOTH STARTER BUSHINGS?? If not running a self supporting starter. We'll check next time
5. Fuse box riveted connections soldered up?? We didn't mess with the fuse box at all. Just peeked at the fuses and cleaned the connectors
6. Headlight switch internal and external riveted connections soldered up?? We didn't mess with the headlight switch.
7. Have you load tested the wiring for voltage resistance with a spare sealed beam head light connected (solenoid disconnected for this test) to the smaller wire at the solenoid?? Need to know how much voltage at the battery and at the solenoid. No load testing was done
If the starter solenoid pulls and engages the starter motor by shorting at the solenoid, then it is fine. Well we got that part figured out! LOL
Barndoor Mafia
Box On Wheels
SBS #00
NAES
NAES is offline
Thanks everyone for the replies!
We'll tackle this job again soon.
Barndoor Mafia
Box On Wheels
SBS #00
Eric&Barb
PostPosted: Tue Jul 08, 2025 2:08 pm    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
Did not realize you were answering at first, thought it was just an echo back for some reason. Probably best in future to answer back by the numbers outside of a quoted post to avoid future confusion of us old folks and any newbies that come across this thread decades from now. Smile
Edit: Figured it out. You colored your responses back in red. For some reason it is not showing up as red here, possibly due to using dark screen settings on our computer.
matthew henricks
matthew henricks is offline
PostPosted: Tue Jul 08, 2025 4:18 pm    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
Oh how this sounds so familiar.
https://www.thesamba.com/vw/forum/viewtopic.php?t=792826&highlight=
My problem ended up being the solenoid. Poor contact internally.
1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat.
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Tue Jul 08, 2025 5:45 pm    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
My experience with this issue usually involved the wire running from the switch to the solenoid. As this long length wire ages, resistance builds and you no longer get a good flow of current to the solenoid. In my case it occurred now and then, not all the time. . Good luck Bob
BarryL Premium Member
BarryL is offline
PostPosted: Tue Jul 08, 2025 6:26 pm    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
So you are getting strong high amp 6 volt to the tab on the starter solenoid when it clicks?
swharris
swharris is offline
PostPosted: Wed Jul 09, 2025 10:03 am    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
You guys do understand "dielectric grease" is NON-CONDUCTIVE, right? It is used not to help promote electrical conductivity, but to PROTECT connections from corrosion(which I guess could eventually help with conductivity) and as a thermal barrier in some cases.
Many people do not understand that dielectric grease does not help enhance good connections with respect to conductivity. It is an insulator not a conductor.
Maybe all that non-conductive grease is your issue Wink
From the interwebs:
"What is Dielectric Grease?
Dielectric grease is defined as a silicone-based grease used to protect electrical components from dirt, moisture, and corrosion. It is also known as silicone grease.
It is a non-conductive, waterproof grease made by combining silicone oil with a thickener. It helps transfer heat from electrical devices.
What is Dielectric Grease Used For?
Dielectric grease is used to disturb the flow of electric current with the property of good lubricants. It is used in many applications including home electrical work, vehicle wiring, and automotive tune-up.
Dielectric grease does not dissolve in most liquids like methanol, mineral oil, ethanol, and water, making it suitable for marine and outdoor applications. However, it can dissolve in xylene, mineral spirits, and Methyl Ethyl Ketone (MEK).
Silicon grease base thermal grease is a good thermal conductive filler and it has good heat transferability. It is used in PCB to transfer heat from the device.
Is Dielectric Grease Conductive?
Dielectric grease is not a conductive material, it is an insulator. Hence, it prevents the flow of current.
To assures the insulator property of dielectric grease, we can perform a simple test with the help of a multimeter. Keep the multimeter on the diode symbol which used to find the conductivity. Inflate the dielectric grease on one probe of the multimeter. And make a normal connection of this probe with the second probe. You will not hear any sound. So, it is an insulator.
How to Use Dielectric Grease?
Dielectric grease helps to prevent arcing between the electrical components. But before using the dielectric grease, you must know that it is an insulator. So, use the dielectric properly with an electrical connection.
The thermal paste (thermal grease) is used to drain out the excess amount of heat from the electrical circuit components like transistors, LED, etc.
When you use the silicon grease, inflate the grease only on the outer surface or body of the component. And must assure that it must not touch where you are connecting the components or in the path of the electric current."
Eric&Barb
PostPosted: Wed Jul 09, 2025 1:55 pm    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
Yes!
Exactly, and since the metal parts cut thru the grease and make a good metal to metal connection so it does not matter if the grease is conductive or not. The grease is ONLY there to keep out any water and all oxygen from the connection surfaces so as to keep away corrosion.
So far in our experience connections can stay clean and free of voltage drops for over ten years, verses 2 to 3 years connections need cleaning without the grease.
swharris
swharris is offline
PostPosted: Thu Jul 10, 2025 12:50 am    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
Eric&Barb wrote:
Yes!
Uh, huh. ok. Sure. Not what you said in your first post, but good to see you get the concept. Many don't. Still, I would not be slathering it between two metal parts you want to have conductivity through. By definition, it is an insulator. Over and around already fastened connectors, yes. BETWEEN the bell housing and the starter uh, no. Smile
Eric&Barb
PostPosted: Thu Jul 10, 2025 9:06 am    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
Well VW did! Open any of the old headlight switches and you will find a clear grease inside that is dielectric. Why dielectric grease? Because VW wanted to have arcing and corrosion kept to a minimum. Why not use a conductive grease?? Because the grease would bridge the insulating gaps in the switch, and one would not have the any of the lights turn off with the switch turned off.
Yes, between starter and transaxle and between starter and solenoid. Works fine, sure would like to try a conductive grease there, but have had not found an easy off the shelf product locally. Heck even went to NAPA, no luck. Might try ordering online, but since the dielectric grease so far has worked fine....
Have eyed the anti-seize compound we do have with its metal powder in it, but not sure if a good idea since introducing different metals to the magnesium with some aluminum alloy of the engine and transaxle cases might cause galvanic corrosion itself. Seen the results of using white lithium grease that someone used to pack a 36 HP newly reground crankshaft with the old style aluminum crankshaft bearings around the crankshaft. The bearings inner sides turned into something looking like cooked oatmeal. Found that back around 1980 in a very small wrecking yard in the back of an old delivery van like the UPS uses. Who knows how many years or decades that crankshaft with the new bearings sat there tucked away.
Even VW instructed the dealer mechanics in the workshop manuals when installing the starter to (the below from our type 2 1963-67 workshop manual 8/66 printed page):
2 - Seal starter flange mounting surface on the transmission with Genuine VW Sealing Compound D 1a.
Doubt that Genuine VW Sealing Compound D 1a is conductive (would be so cool if someone has an old tube of this stuff to test, even if hardened up), but even if it is conductive, main thing VW wanted it in there to keep out water and oxygen to prevent corrosion. Water is totally attracted by capillary action of having two pieces of metal with any of the smallest of any gaps between them.
70bus Premium Member
70bus is offline
PostPosted: Thu Jul 10, 2025 10:12 am    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
Advice from a pro on dielectric grease
https://www.w8ji.com/dielectric_grease_vs_conductive_grease.htm
One incorrect logic is the "dielectric" in "dielectric grease" means the grease should only be used to insulate. All greases work by the low viscosity allowing the grease to completely push out of areas with metal-to-metal contact. Dielectric grease is just better at holding off high voltages over long paths.
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
Eric&Barb
PostPosted: Thu Jul 10, 2025 12:21 pm    Post subject: Re: 6v electrical wizard help needed. (Starter issue) Reply with quote
Cool! Thanks for posting that!! Smile
