spacebiscuit Samba Member
Posted: Mon Jul 07, 2025 12:18 pm Post subject: Flasher issue |
Hi all - bus has been laid up for a while - I've replaced the emergency flasher relay - when I pull the switch all for turn signals flash as expected. But using the turn signal the right side work but on the left side i have nothing, no lights on the dashboard and no flashing turn signals.
My guess is the issue might be around the 4 point cable connector (T3 on the attached image - J2 is the relay). Can I rule out a bad earth if the flasher works?
My bus follows this diagram:
https://www.thesamba.com/vw/archives/info/wiring/bus_8_71.jpg
Any ideas or suggestions welcome - thanks!
[/url] _________________ 1972 Type 2 1600cc
1990 MKII Golf 1.6 CL
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52725 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jul 07, 2025 1:07 pm Post subject: Re: Flasher issue |
Dirty/corroded fixtures are usually the cause, the bulb shell has to make clean contact with the socket, if it doesn't it finds a ground path through the parking light circuit, it's enough to work on the 4 ways, but not on a single side. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jul 07, 2025 1:18 pm Post subject: Re: Flasher issue |
Thanks BusDaddy - so are you suggesting that when the hazard/emergency lights are on it could be picking up the ground from the good side that works independently? _________________ 1972 Type 2 1600cc
1990 MKII Golf 1.6 CL |
Posted: Mon Jul 07, 2025 4:03 pm Post subject: Re: Flasher issue |
The flasher relay is designed to not flash on one bulb, or flash super fast, it's a way to alert you to a burned out bulb, a weak ground acts just like a bad bulb as far as it's concerned.
The hazards use 4 bulbs so even if one is weak the system still flashes. Walk around with them on and look for the slightly dimmer bulb. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
70bus  Samba Member
Posted: Mon Jul 07, 2025 4:52 pm Post subject: Re: Flasher issue |
A similar issue was just explored on the split bus forum; in their case, the turn signal switch had a bad connection between power and a light circuit. Cleaning it out helped. Also check the Y connector under the dash to the switch for a loose/broken wire. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3301 Location: Hamble, Hampshire, UK
Posted: Tue Jul 08, 2025 4:26 am Post subject: Re: Flasher issue |
Because the hazards work, proving the flasher relay, wiring to external lamps and the external lamps are OK, its either the indicator switch or wiring between it and where the hazard switch feeds the right hand indicator wiring. The hazard switch shorts the flasher relay output to both left and right hand indicator wiring.
Could be the connector block for the indicator switch under the dash as you say. Its just a bundle of spade connectors. Quite easy to push wires in and miss the spade going into the female socket, so it falls out later. _________________ Ancient vehicles and vessels
Posted: Tue Jul 08, 2025 12:01 pm Post subject: Re: Flasher issue |
it was the 4 way connector - T3 in the screenshot. Of the 4 wires that should plug into the block only 3 were connected. I fished around and found the wire that had become disconnected - all turn signal now working nicely.
Now to stop that turn signal from moving around the steering column every time I use it! _________________ 1972 Type 2 1600cc
