Subaru EJ25 Shortened Oil Pan Options
Page: Previous  1, 2
Franklinstower
Franklinstower is offline
PostPosted: Wed Jul 02, 2025 9:05 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
skemems wrote:
dobryan wrote:
shagginwagon83 wrote:
ALIKA T3 wrote:
Zanzinger in Germany Cool
https://www.zanzinger-automobiltechnik.de/LMB-OElwanne-gekuerzt-fuer-Subaru-EJ-Motoren/010-049
Wonder what the depth dimension of their pan is?
Description says its 60mm reduction in height from stock pan.
Seem to be similar to the outfront motorsport pan (cut and welded) with fins for heat dissipation. Capacity is only 3.75L. Would not be my first choice.
Yes, I agree about the capacity, otherwise a really nice pan especially equipped with their baffles found here:
https://www.zanzinger-automobiltechnik.de/OEl-Schwall-Blech-Kit-passend-fuer-Subaru-EJ/010-011
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB
dobryan
dobryan is offline
PostPosted: Wed Jul 02, 2025 9:06 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Ouch! 3.75 liters is not for me either.
Dave O
The Western Syncro build
MSGGrunt
MSGGrunt is offline
PostPosted: Wed Jul 02, 2025 2:03 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Is the Van Cafe pan the only shortened pan that retains the stock capacity?
skemems
skemems is offline
PostPosted: Wed Jul 02, 2025 6:31 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Stock capacity is about 4.5q.
Each company has listed oil capacity with their oil pan, depending which pan your looking into their site should list capacity.
87 VW Westfalia - EJ25
86 VW Westfalia - EJ22
85 VW Westfalia - WBX 2.1 project
a914622
a914622 is offline
PostPosted: Wed Jul 02, 2025 9:53 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Now that’s a work of art!!
87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru
syncrodoka
syncrodoka is offline
PostPosted: Wed Jul 02, 2025 10:19 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Any oil pan that is wider than stock has more of a potential for the oil pickup to be starved as oil sloshes to a side during a combination of cornering, engine acceleration and surface grade.
Deep sumps have the potential to get damaged and lose the oil.
Not all oil pans work with other company engine carrier system designs.
Things to think about when buying
Jake de Villiers
Jake de Villiers is offline
PostPosted: Fri Jul 04, 2025 5:00 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
With respect to capacity, I use a Wix 51344 filter help with that.
Similar drain back provision and bypass pressure to stock Subaru but holds a little more than twice as much oil while remaining above the bottom of the pan.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
MSGGrunt
MSGGrunt is offline
PostPosted: Sat Jul 05, 2025 4:21 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Capacity can also be increased with the use of an oil cooler, but that and an extra capacity filter doesn't solve the problem of starvation at the pickup. I guess it is all a tradeoff. For my purposes and since I already bought the Van Cafe engine cradle I will go with their oil pan. At least I will be confident their parts work with each other.
a914622
a914622 is offline
PostPosted: Tue Jul 08, 2025 2:36 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
So I was changing the oil today . Walking the drain pan to the recycling bucket the oil slosh got out of control and I spilled. Laughing i thought, this is what is going on in the pan all the time. I could not see running with it and not spilling, lol
Just saying.
Franklinstower
PostPosted: Tue Jul 08, 2025 4:08 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Just saying.
Which oil pan do you have?
I am currently using the burley pan, and he said it holds 4.75 quarts, but that is about 1 1/2" higher on the dip stick than the stock high oil mark....I guess I really need to pull the pan, fill it with 4.5 quarts and and make new marks. For some reason I thought I did that, and 5 quarts was the top of the pan, which would be way to high.
I would really like to have 5 to 6 quart capacity.
YITB
Braukuche
Braukuche is offline
PostPosted: Tue Jul 08, 2025 8:53 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Franklinstower wrote:
Just saying.
I have that pan and have the same thing. Someone etched some marks on the stick, but after I put in the specified amount of oil it still reads high.
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
a914622
a914622 is offline
PostPosted: Wed Jul 09, 2025 5:59 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
I’m still running the stock 2000 Subaru .
Looking to order a 2010 setup, or at least the baffling
AndyBees
AndyBees is offline
PostPosted: Wed Jul 09, 2025 6:56 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
I did read the initial post to this Thread and looked at the links.
As others have posted, I have no experience with a Subaru conversion, zero.
But, here is my experience with a TDI.
I probably spent over $600 on custom made oil pans because there were no aftermarket pans for the 50 degree lay over of the engine (OE Diesel style) when I was doing my conversion.
The first two were aluminum. One was badly designed. The second one was perfectly designed, with baffles. But, it eventually cracked.
The third one has been awesome.
Stainless Steel......... about 5.5 quarts.
No lower than the transmission.
No baffles......... I've used it for close to 75k miles. I've never seen the
Oil Pressure Gauge flicker or drop due to sucking air during sharp corning because of the lack of baffles.
So, the prices you are seeing are not bad and thank to the aftermarket for their availability.
'84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful.
CTSkim
CTSkim is offline
PostPosted: Wed Jul 09, 2025 7:42 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
I have no real world experience with it yet, but I just ordered the van cafe pan and am initially very impressed with the construction/welds. It won't be installed for a few more weeks so if theres anything you'd like a photo or measurement of I can certainly grab that.
Project 67 Beetle
72 Sierra Yellow Westy
82 Tin Top Vanagon
Sodo
Sodo is offline
PostPosted: Wed Jul 09, 2025 10:48 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Pull the pan???? Or pull the oil?
Drain the oil, put in 3.5 qts, make your 3.5 qt mark.
Add one quart, make your 4.5qt mark.
I will suggest that with thousands of cavernous non-baffled Smallcar pans out there, surviving,
that "non-baffled" has been tested and approved by the Vanagon masses.
Mind you this testing is on RVs, not track-racers cornering hard at peak HP output.
Some of these RVs (Syncros) test often with very high lean angles, but relatively low RPM and low combustion pressures.
Much more significant than baffling is the oil-appetite of some EJ25s.
For that, you want more quarts. More quarts is better for oil longevity too, and then for engine longevity too.
3.75 qts could get dangerously low (2.75qt) after your oil-drinker EJ drinks one quart.
based upon this "theory" I extended the PCV oil drain to "below oil level". To be similar to what Subaru did.
I don't know if it helps, but I do know my PCV hoses have very little oil in them.
The Smallcar pan and its mounts allow for re-mounting the Syncro skid bars which can be modified to protect the oilpan.
You cannot re-mount Syncro engine bars with the VanCafe exhaust.
I don't think any engine or pan or exhaust protection can be built for the VanCafe system, so I personally would not choose that for a Syncro.
VanCafe exhaust is very vulnerable..... so I would definitely agree to limit off-roading to 'gravel roads ONLY' .
....KTMs, GasGas, SPOT mtb
harvgwen
harvgwen is offline
PostPosted: Wed Jul 09, 2025 2:00 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Sodo thanks for posting that. I very recently installed a SmallCar pan, and was also surprised to note that it didn’t have baffles or that drain tube. After reading this thread (before your post), I was hoping I hadn’t made a mistake buying it, but at the same time, like you said, thinking that there must be a lot of Vanagons with these that aren’t killing their engines. I can see why they wouldn’t be a good choice for more serious off roading. I only have a few hundred miles on the oil pan, but so far haven’t noticed any issues. The clearance is way better (I did hit the Subie pan a couple of times).
1986 Westfalia Vanagon, 2.2 Subaru
Okanagan Valley, British Columbia
MSGGrunt
MSGGrunt is offline
PostPosted: Fri Jul 11, 2025 4:20 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
As always Sodo, you are a wealth of information. An easy mod and nothing lost if it doesn't make a difference and everything to gain if it does.
I ended up ordering the Van Cafe pan. They advertise a full 5-quart capacity, we will see. This, along with a larger filter mentioned earlier and an external oil cooler, will add even a little bit more oil capacity, though not a significant amount.
Franklinstower
PostPosted: Fri Jul 11, 2025 11:16 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
I was recently in Pullman picking up my kid from college. The campus is on a hill with a few pretty steep grades. When I stopped to pick him up, I heard the clattering of valves. Ended up I sucked air going up the hill.
Didn't know it at the time, I thought I dropped a valve seat or something.
I was a little low on oil, but not too much. A roadside pulling of the rocker assembly and checking the lifters didn't show much. I added another quart of oil for peace of mind and made it the 310 miles home without incidence.
Having a pan that I holds 5 quarts or more, and an accurate dipstick sure would provide some peace of mind.
I have been contemplating raising my engine to the max and going back to a stock new style pan. I think the stock EJ22 pan is about 6-3/4" in height. I wonder if I can get an inch or two more in engine height? Anyone know the height of new style stock pan? I think I currently have 9" from the bottom of the pan to ground which seems to be plenty.
I will do some measuring when my wife gets back with the van...it's dog walk time....
YITB
Page: Previous  1, 2
Page 2 of 2
