Help! Vanagon dies when releasing clutch
vodo1976
vodo1976 is offline
PostPosted: Sun Aug 03, 2025 10:46 am    Post subject: Help! Vanagon dies when releasing clutch Reply with quote
Been having issues with my 86 Westy lately. Mostly rough idle.
But then last night I drove to town. Things seemed ok on the way there.
Then, on the way home, I stopped to get gas.
After filling up the clutch felt really spongy and was hard to shift.
Then I noticed that I was not really accelerating properly. On the highway at 55 I had it floored and she seemed to not wanna break 60. Occasionally I would feel power re-engage, but that was only for a brief few seconds.
Barely made it home.
She fired up fine but dies immediately when I release the clutch, even if I’m revving to higher RPMs.
I was planning on checking fuel pressure as well as replacing clutch/brake fluid.
But now I fear it’s something worse. Maybe need a new clutch?
This might be my excuse to upgrade to a 5speed and replace the old wasserboxer.
MarkWard
MarkWard is offline
PostPosted: Sun Aug 03, 2025 11:02 am    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
Does the van roll easily if you push it?
vodo1976
vodo1976 is offline
PostPosted: Sun Aug 03, 2025 12:24 pm    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
With it in gear?
I did a compression test. All cylinders above 110 psi
vodo1976
vodo1976 is offline
PostPosted: Sun Aug 03, 2025 12:35 pm    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
Yes. In gear it practically rolled down without pushing.
Yikes.
MarkWard
MarkWard is offline
PostPosted: Sun Aug 03, 2025 6:35 pm    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
Brakes can hang enough to kill an engine on move off. Since it rolls easily it’s not the brakes.
DanHoug
DanHoug is offline
PostPosted: Mon Aug 04, 2025 7:03 am    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
can you drive fine in reverse?
-dan
www.thefixitworkshop.com
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Mon Aug 04, 2025 7:35 am    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
Yikes.
are you saying that the car rolls easily while in gear?
if so, the clutch would be suspect.
88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
MarkWard
MarkWard is offline
PostPosted: Mon Aug 04, 2025 9:02 am    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
If the clutch were shot, I'd expect the engine to rev easily and have no movement. I like the idea of testing how does it do in reverse?
vodo1976
vodo1976 is offline
PostPosted: Mon Aug 04, 2025 11:26 am    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
It moves forward and backwards a little bit if I basically smoke the clutch.
I’m beginning to think it’s the throttle position switch. The switch isn’t clicking in the low end. Gonna check it soon.
If that’s it, I have to thank VanAgain.
DanHoug
DanHoug is offline
PostPosted: Mon Aug 04, 2025 11:36 am    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
to be obvious, that ain't right. if you are literally smoking the clutch, it is not a throttle switch problem but either a brake issue, which you've ruled out by pushing it easily, or something with the transmission or final drive.
you COULD be mistakenly trying to take off in 3rd gear instead of 1st. this happens with a shift linkage misalignment. that's why i ask if it moves okay in reverse. it sounds like it doesn't.
be prepared for ring and pinion damage that is binding under torque.
might be time to pull the drain plug on the transaxle and examine the fluid and magnet. be sure you can loosen the FILL plug prior to removing the drain plug.
-dan
4Gears4Tires
4Gears4Tires is offline
PostPosted: Mon Aug 04, 2025 11:41 am    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
I was thinking misaligned shifter too. But, at 55mph in 4th gear the van should accelerate. So I think that rules that out as well.
Does it rev easily in neutral?
MarkWard
MarkWard is offline
PostPosted: Mon Aug 04, 2025 1:36 pm    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
Still sold on testing in reverse. No mistaking what gear you’re in. As far as the TPS, I’ve seen plenty of vans running with misadjusted and non functioning tps switches.
zerotofifty
zerotofifty is offline
PostPosted: Tue Aug 05, 2025 8:33 am    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
A slipping clutch which is shot, may allow the van to move.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
?Waldo?
?Waldo? is offline
PostPosted: Tue Aug 05, 2025 9:11 am    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
A slipping clutch may still allow the van to move, but it will not cause the van to stall nearly as easily as a non-slipping clutch. In fact, a common way to test if the clutch is slipping is to dump the clutch in a higher gear and if the engine keeps running, the clutch is slipping. Considering the title of this thread, it seems very unlikely to me that the culprit is a slipping clutch.
E1
E1 is offline
PostPosted: Tue Aug 05, 2025 9:28 am    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
I suspect that the clutch is not fully disengaging, if not fully engaging either.
It’d be interesting to watch the distance that the slave “lever” moves into the transmission, and compare it to what one or several of our own vans travel. I’ll measure mine if you measure yours.
It’s also possible the bracket holding the slave has recently cracked, is flexing with full clutch pedal travel, and coming up short of full travel and disengagement. This could explain why the soft pedal suddenly showed up — or the softening wasn’t noticed and could be as easy as needing a good fluid flush.
Is your level full in the brake fluid reservoir? If not or if so, looks for any leaks below the reservoir but especially under the boot of the slave itself.
I sense the stalling and weak highway power is another issue altogether, possibly a failing O2 sensor or Temp 2 sensor, or since it started at the gas station, some water in a load of bad gas.
If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
MarkWard
MarkWard is offline
PostPosted: Tue Aug 05, 2025 9:35 am    Post subject: Re: Help! Vanagon dies when releasing clutch Reply with quote
My previous point wasn’t clear. A slipping clutch is not going to cause the engine to stall. It’s actually the opposite. Engine will rev and not stall.
There was a member sometime back had a similar problem and someone suggested they were moving off in third and that was the actual problem in the end. Finding first or second can be difficult with worn bushings so it can be difficult to tell. Reverse is obvious. You either select or you don’t. If the engine runs and the van moves in reverse, linkage might be suspect. If the symptom is the same in reverse you need to be looking elsewhere.
