Braukuche Samba Member
Posted: Mon Sep 08, 2025 9:20 am Post subject: Rear axle advice needed |
Went on another long trip…1200 miles to the redwoods…with clicking and clacking left axle most of the way.
Frankenstein engine and auto trans were all rebuilt about 30k ago by the PO and I have to assume the axles or CVs were done too. Boots are solid, axles have no play, bolts are tight, just standard lateral movement, but clearly something is wrong.
Van looks to have the GW 1.5” lift kit.
I’ve read plenty of threads about replacing the CVs and reusing The original axles but I’ve no way to know if my axles are original or not.
So, my questions are:
With the lift kit can I use stock CVs/axles?
I see there are aftermarket kits for M/T with lift kits but is there any for A/T if needed?
If I have aftermarket axles am I better off replacing the whole assembly vs using German CVs on possible Chinese axles?
Is there anyway to tell of the axles are original? Is there a VW stamp on them anywhere?
Thanks for any advice, _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3669 Location: Dartmouth, Mass.
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12408 Location: Santa Cruz, CA
Posted: Mon Sep 08, 2025 10:55 am Post subject: Re: Rear axle advice needed |
Automatics have different length axles from a manual, they are different length left to right as well.
Are your CVs dry or are they worn out?
Check with t3technique if you need CVs with more articulation. |
zerotofifty Samba Member
Posted: Mon Sep 08, 2025 12:28 pm Post subject: Re: Rear axle advice needed |
| Braukuche wrote: |
Thanks for any advice, |
If you cant find the right length axles, you might be able to find axles with correct splines, and length from an axle supplier. Several spline types are fairly standard across many different applications. You might find what you need from a Porsche, or BMW, or what ever. Check out axle sources from hotrodding or off roading fabrication places, they may have a line on what you need if you cant find a stock vanagon type that meets your need Locate an axle manufacturers catalog. _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Posted: Mon Sep 08, 2025 1:28 pm Post subject: Re: Rear axle advice needed |
| syncrodoka wrote: |
Pretty sure the axles are correct as We’ve out over 3k miles on it since we bought it with no issues.
Boots are solid so I’m going to assume they have grease in them. _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
1989 Westfalia |
Posted: Mon Sep 08, 2025 1:59 pm Post subject: Re: Rear axle advice needed |
They are likely correct, I was mostly mentioning the axle length difference so that you don't swap them from side to side.
The higher articulation CVS should be run with a lift. What do you have?
If your CV grease is still in good shape then you need to remove the CV, clean them and inspect for damage. |
SCM Samba Member
Joined: January 26, 2011 Posts: 3477 Location: Bozeman MT
Posted: Mon Sep 08, 2025 2:17 pm Post subject: Re: Rear axle advice needed |
| Braukuche wrote: |
Boots are solid so I’m going to assume they have grease in them. |
I wouldn't assume that at all. My CVs all looked brand new (although I assume they were original to the van) going into this summer when one of 'em started clacking like mad. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
clamay Samba Member
Posted: Mon Sep 08, 2025 3:13 pm Post subject: Re: Rear axle advice needed |
Only one way to find out for sure. Take "em off. _________________ 91 Carat, automatic, GW 2.2, GW EFI, Peloquin TBD
When you come to a fork in the road, take it. --Yogi Berra |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 2024 Location: Pittsburgh PA (ish)
Posted: Mon Sep 08, 2025 4:46 pm Post subject: Re: Rear axle advice needed |
| Braukuche wrote: |
It's probably not a good idea to assume they have sufficient grease. I would get a grease needle long enough to reach into the CV bearing from under the small end of the boot and pump maybe 5 pumps of grease between each pair of balls. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10806 Location: Western WA
Posted: Mon Sep 08, 2025 6:05 pm Post subject: Re: Rear axle advice needed |
Clacking suggests dry.
It can break your cages then you’re ‘done’ (towtruck).
Long needles are hard to find.
With a short sharp needle, you can poke a boot in the flat pleat.
The hole self-seals and theres’s no stress in the flat. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Mon Sep 08, 2025 8:31 pm Post subject: Re: Rear axle advice needed |
| Sodo wrote: |
The hole self-seals and theres’s no stress in the flat. |
Never had any trouble getting hold of one of these:
https://www.autozone.com/grease-and-caulk-applicat...pid=OSA:US |
jlrftype7 Samba Member
Posted: Tue Sep 09, 2025 5:33 am Post subject: Re: Rear axle advice needed |
| SCM wrote: |
| Braukuche wrote: |
I wouldn't assume that at all. My CVs all looked brand new (although I assume they were original to the van) going into this summer when one of 'em started clacking like mad. |
I agree- PLUS, what if the previous owner ran the Redline Grease that we're having issues with. You'll never know until you remove them and get in there. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15410 Location: Syracuse, NY
Posted: Tue Sep 09, 2025 5:59 am Post subject: Re: Rear axle advice needed |
Most certainly can't assume good boots equals adequately lubricated.
in fact there was a thread here once about the Rockford boots allowing water to get in from the small end on the downward side.. it'd collect on the shaft and wick down into the joint.
I've had to grab one of these from a $dollar store and give the joints a shot of motoroil.
this adequately (in my case) lubed and stopped the clacking till I was back home and could service them properly.
I do still carry it as an emergency aid in my spares/emergency kit.
if you have a 'larger' lift then you likely would need to upgrade to Porsche 944/THING CV joints.
added lift equals shorter maintenence intervals.. _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
Kdj Samba Member
Joined: January 28, 2017 Posts: 333 Location: Naptown
Posted: Tue Sep 09, 2025 6:29 am Post subject: Re: Rear axle advice needed |
| When I first bought my van I had a CV failure. Bought a set of 944 chinese knock offs axles from big box auto parts store. Continued to have cv problem's. This last winter I measure those against the original VW ones that I had saved and they where 2.5mm shorter than the VW ones. Replaced the the autoparts store CV's with T3 high angle units and put them on the original VW axles and all is good so far. Moral of story is check the lengths. Not all parts are created equal and it's hard to know what's been change over the years. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10470 Location: Orbiting San Diego
Posted: Tue Sep 09, 2025 7:46 am Post subject: Re: Rear axle advice needed |
Various parts places may list all years as the same but 80-82 CV axles were a little longer than later year watercooled axles.
Starting with 83 watercooled models the trans/engine was moved back and the axles were shortened.
(83 aircooled used 80-82 longer axles)
Mark
| Kdj wrote: |
| When I first bought my van I had a CV failure. Bought a set of 944 chinese knock offs axles from big box auto parts store. Continued to have cv problem's. This last winter I measure those against the original VW ones that I had saved and they where 2.5mm shorter than the VW ones.... |
4Gears4Tires Samba Member
Posted: Tue Sep 09, 2025 8:13 am Post subject: Re: Rear axle advice needed |
| Phishman068 wrote: |
| I don't know of anyone who's actually snapped a Chinese axle, but I do know the joints wear out |
I'm running Chinese front axles on my Syncro. One snapped a cv joint in 3 miles. I replaced it with another Chinese front axle and both fronts have been running just fine for years now. 30k miles maybe? _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10299 Location: Mt Lemmon, AZ
Posted: Tue Sep 09, 2025 8:37 am Post subject: Re: Rear axle advice needed |
I've always been able to stretch the boot enough to slip a quarter inch irrigation hose in there. The end of the hose is cut at an angle to make it easier to get in. After that any small plunger will do. I've used one made for basting meat but drugstores sells this for giving babies medicine and it works fine.
Posted: Tue Sep 09, 2025 9:42 am Post subject: Re: Rear axle advice needed |
I went ahead and ordered the GoWesty axles. I don’t want to order German CVs to find out they won’t work on possibly Chinese axles.
After I disassemble the old ones to see WTF went on I can check to see if the axles are VW units, if so I’ll hang on to them in case the replacements fail down the road.
I just want to make sure in our next long trip we don’t have issues with then CVS.
I’ll post any updates for future reference. _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
1989 Westfalia |
Posted: Fri Sep 26, 2025 8:36 am Post subject: Re: Rear axle advice needed |
Pulled the axles and the CVs were dry as a bone and even rusty. _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
1989 Westfalia |
