Air Conditioning repair - FAS 2.0
Page: 1, 2, 3  Next
VicVan
VicVan is offline
PostPosted: Sun Sep 07, 2025 6:22 pm    Post subject: Air Conditioning repair - FAS 2.0 Reply with quote
At the bottom of this first message, I will include the relevant information collected in this thread. Original message:
Hi all,
I am repairing the stock Air Conditioning in my 1990 Westy. I've never used it since I bought the van seven years ago. The compressor had a crack, and a shorter belt had been installed. When installing the FAS engine 3 years ago, I left the compressor (new) unconnected.
I will change condenser, receiver-drier, all hoses and fittings (most likely Aeroquip EZ-Clip system). The compressor is new (came with the 2001-2005 Jetta AVH engine in the FAS kit). The sticker says R134a, so I am thinking of filling the system myself with Redtek.
I am going through the A/C master topics, which prove very useful.
A couple of questions:
1/ How do you decide how much PAG oil to use?
2/ How do you decide what size of hose to use?
Summary (last updated Sept. 14th, 2025)
- Quantity of oil will be 240 cc (see page 2)
- Size of hose will be similar to original sizes (See DeLvxe's parts list page 1)
'90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH)
VicVan
VicVan is offline
PostPosted: Sun Sep 07, 2025 6:25 pm    Post subject: Re: Air Conditioning repair Reply with quote
A few pictures of the easy part. I was suprised by how good and clean everything looked, compaared to what some of you have posted. Was the A/C used at all? Who knows.
Looks brand new!
I have yet to test the blower motors, but the resistors look good. Their mounting brackets are the only things that broke. Even the drain pipe bits are in good condition.
Evaporator
I will be modifying the wiring as per the Wiring master topic. Will be discussed further in this topic. Looks good anyway.
dhaavers
dhaavers is offline
PostPosted: Mon Sep 08, 2025 7:59 am    Post subject: Re: Air Conditioning repair Reply with quote
Wow, that is super clean, nigh pristine! Very Happy
[Following edited for bad info…my apologies] Embarassed
IIRC, there is a chart for oil amounts in Bentley, yes? I believe #10 hose is for high pressure, #8 for the low pressure side.
It’s been 10 years since my last AC project so I may have forgotten & of course this needs verification but it’ll also bump your thread.
- Dave
"The WonderVan"
vanis13
vanis13 is offline
PostPosted: Mon Sep 08, 2025 10:06 am    Post subject: Re: Air Conditioning repair Reply with quote
IIRC, there is a chart for oil amounts in Bentley, yes? I believe #10 hose is for high pressure, #8 for the low pressure side. It’s been 10 years since my last AC project so I may have forgotten & of course this needs verification but it’ll also bump your thread.
- Dave
Since typically smaller hoses are higher/liquid pressure the above statement is likely incorrect
(though technically/theoretically one could use a larger hose for higher/liquid it is the lower pressure that typically needs the larger volume of the lower pressure)
Oil amounts also vary depending on compressor oil ratio requirements and refrigerant type
AustinGoneWild
AustinGoneWild is offline
PostPosted: Wed Sep 10, 2025 9:04 pm    Post subject: Re: Air Conditioning repair Reply with quote
One thing you can do to make things easy for you, is to remove your refrigerant hoses and take them to a local tubes and hoses type shop. They should be able to build new hoses with fittings. New hoses will contain refrigerant much better than the old R12 hoses.
Edit: also wanted to add that GW has replacement brackets. 255070124D is the part number.
VicVan wrote:
Hi all,
VicVan
VicVan is offline
PostPosted: Thu Sep 11, 2025 2:17 pm    Post subject: Re: Air Conditioning repair Reply with quote
I would like to do that, but the problem is I have a non stock-engine, which requires modification of two of the stock hoses (the ones coming to and from the compressor). I will figure something out.
A few random thoughts/questions:
- My compressor says "SP-10 oil", so that's what I'll be putting in the system. I will thoroughly rinse the components I am reusing (condensator and expansion valve).
- The system will be filled with R134a if a shop does it, or Redtek if I do.
- Folks with engine conversions / non-stock A/C compressor: did you change the pressure switches? OR is the pressure they work at just fine?
- I am going over the elctrical improvements topic, and am figuring out which improvements I will be doing. More in this later.
MartinJS
MartinJS is offline
PostPosted: Thu Sep 11, 2025 2:48 pm    Post subject: Re: Air Conditioning repair Reply with quote
I took mine to the shop. All the hoses were stock length and fitting orientation except the 2 hoses for the compressor which were left a little longer than needed with no fittings at the compressor end only. Measuring can get you close to the correct length for these.
Installed the new hoses once manufactured, then went back to the shop and have them install the 2 fittings for the compressor. This way they can cut the hose to the correct length and get the orientation of the fittings correct before crimping at the compressor.
MartinJS
MartinJS is offline
PostPosted: Thu Sep 11, 2025 2:51 pm    Post subject: Re: Air Conditioning repair Reply with quote
Sorry, just realized previous poster said hose and fittings shop, not AC shop. Mine I had made by local automotive AC shop.
MarkWard
MarkWard is offline
PostPosted: Thu Sep 11, 2025 2:55 pm    Post subject: Re: Air Conditioning repair Reply with quote
Not sure if the compressors are similar, but using the TDI compressor I found adapters to convert the compressor to conventional AC hose ends. Probably in my notes.
I also had to modify the inside of the compressor to get compatible low pressure values to work with conventional expansion valves.
I also used R134. If you don’t have the equipment an AC shop can recover it if you need to change a component. Red Tek, you’re likely blowing it off into space. Ok if your ac works first swing, not if you find you need to modify the compressor. I’m not familiar with your compressor, but similar era.
Later compressors do away with the clutch completely. That’s another hill to conquer. I’ve not taken that on. I understand it’s solvable.
wesitarz
wesitarz is offline
PostPosted: Thu Sep 11, 2025 7:31 pm    Post subject: Re: Air Conditioning repair Reply with quote
VicVan wrote:
Hi all,
I thought I saw the amount of oil needed in the long A/C topic. I was looking at YouTube car A/C videos that show diagrams of the hi and lo sides. (Lo side bigger size hose only from the expansion valve/evaporator to the compressor, I believe)
https://www.weidefamily.net/vanagon/ ( Subie Engine-3) shows mod of the vanagon compressor fittings. Maybe you could do similar if you got the compressor fittings for youe engine from a wrecker (Malahat)
VicVan
VicVan is offline
PostPosted: Thu Sep 11, 2025 8:08 pm    Post subject: Re: Air Conditioning repair Reply with quote
That sounds really good. So they installed the compressor-side fittings in the van directly?
VicVan
VicVan is offline
PostPosted: Thu Sep 11, 2025 8:10 pm    Post subject: Re: Air Conditioning repair Reply with quote
I'll ask FAS (manufacturer of the engine conversion kit) how they do this. I did not realize the pressures would be different.
VicVan
VicVan is offline
PostPosted: Thu Sep 11, 2025 8:11 pm    Post subject: Re: Air Conditioning repair Reply with quote
Thanks!
DeLvxe
DeLvxe is offline
PostPosted: Thu Sep 11, 2025 9:39 pm    Post subject: Re: Air Conditioning repair Reply with quote
I am at the tail end of doing what you are doing: just finished putting the system together and about to pull a vacuum.
This is an all new system in a subaru swapped 1991 camper. I used EZ clips throughout, replaced the compressor, condenser, and receiver. Cleaned and reused the evaporator and expansion valve. I am working on a write up and parts list, but will add the draft to your post. The system will use 134a refrigerant.
About your oil question, the info is in the Bentley. If I remember correctly, it is 0.3 oz in each of the receiver, the high pressure hose, and the low pressure hose. The evaporator gets 5.something oz of oil. I used PAG 100. Feel free to DM me your phone number if you want to talk.
To get you started, here is my parts list and diagram of the system. Yours should be exactly the same with the exception of the connection to the compressor -- this wil depend on the location / orientation of your compressor, the specific adapters, and how you want to route the hoses.
I suggest you take all the hoses out -- go ahead and cut them to make it easier. Pay careful attention to hose routing and take some photos. you can take some measurments of the three sizes of hose (-6, -8, and -10), but you should be able to use the lengths in my parts list.
1991 manual camper with EJ25
Abscate
Abscate is offline
PostPosted: Thu Sep 11, 2025 9:43 pm    Post subject: Re: Air Conditioning repair Reply with quote
The refrigerant dictates the oil type, not the compressor. Make sure you know what’s in the system before adding any oil.
MartinJS
MartinJS is offline
PostPosted: Fri Sep 12, 2025 6:58 am    Post subject: Re: Air Conditioning repair Reply with quote
Yes, cut lines and crimped connectors in the engine compartment.
vanis13
vanis13 is offline
PostPosted: Fri Sep 12, 2025 7:52 am    Post subject: Re: Air Conditioning repair Reply with quote
True
You will notice that if you add those numbers up they do not match the total oil for the system....Those are "if component is replaced" number...and that number may change depending on what refrigerant/oil ratio your compressor requires. These quantities are for the original R12.
The total oil , again, depends on refrigerant/oil ratio your compressor requires and that needs the volume capacity of the system.
VicVan
VicVan is offline
PostPosted: Fri Sep 12, 2025 9:11 pm    Post subject: Re: Air Conditioning repair Reply with quote
DeLvxe! Wow! That is going to be so helpful. Thanks. It might be helpful to talk on the phone, when I'm further along.
Compressor: Is it the same model than the stock Subaru-provided one?
Hoses: you used the same sizes for the new hoses?
Fittings #8 and #9 on your list: what are these? where is the OEM port?
Abscate: The system will be empty, save for what's in the new compressor: SP-10. I will therefore be using SP-10 (or its compatible replacement SP-15) in my system.
I see. How/where do I find this information?
edit: I've found the Sanden SV service manual (here: https://sanden.com/servicemanual/ ). Page 9:
6.8 Oil Charge
• Oil Circulation Ratio (OCR) should be between 3.3% and 8% ratio of oil to refrigerant by weight.
I'll check if the numbers in the Bentley match this. Not sure how to estimate the weight of refrigerant that goes in the system though.
dobryan
dobryan is offline
PostPosted: Sat Sep 13, 2025 6:52 am    Post subject: Re: Air Conditioning repair Reply with quote
6.8 Oil Charge
Refrigerant is measured by weight, not volume. So whatever the manual says to add is by weight.
Dave O
The Western Syncro build
vanis13
vanis13 is offline
PostPosted: Sat Sep 13, 2025 10:58 am    Post subject: Re: Air Conditioning repair Reply with quote
[b]6.8 Oil Charge
[/b]
that % seems extremely low as often it is close to 25%. (the 3.3-8% OCR possibly for a different refrigerant or a different tech compressor?)
in the link you gave the USA market manual does not have the language you quoted. please provide a specific link/screen shot/filename
Page: 1, 2, 3  Next
