Mystery Stroker crankshaft
Peter T.
Peter T. is offline
PostPosted: Mon Jul 15, 2019 4:49 pm    Post subject: Mystery Stroker crankshaft Reply with quote
I got this from a retired Vw mechanic and he told me that its a billet crank for a Denzel but the dimensions are wrong.
All the journals measure 50mm and the stroke looks to be 69mm.
The flywheel end has 4 instead of 8 wholes.
The only markings on it is #151.
Anybody have a clue about this crankshaft?
Erik G
Erik G is offline
PostPosted: Mon Jul 15, 2019 4:56 pm    Post subject: Re: Mystery Stroker crankshaft Reply with quote
https://www.thesamba.com/vw/classifieds/detail.php?id=2081209
Peter T.
Peter T. is offline
PostPosted: Mon Jul 15, 2019 5:09 pm    Post subject: Re: Mystery Stroker crankshaft Reply with quote
It looks like a Hirth crank but its solid and not a roller crank.
[email protected]
JERRY63VW@YAHOO.COM is offline
PostPosted: Mon Jul 15, 2019 6:01 pm    Post subject: Re: Mystery Stroker crankshaft Reply with quote
By what i know denzel only had a 67mm crankshaft... Is this crank for a 36hp or 40hp
Peter T.
Peter T. is offline
PostPosted: Mon Jul 15, 2019 7:24 pm    Post subject: Re: Mystery Stroker crankshaft Reply with quote
Its a 36hp crank
earthquake
earthquake is offline
PostPosted: Fri Jul 19, 2019 11:54 am    Post subject: Re: Mystery Stroker crankshaft Reply with quote
It looks like some body asked LEGO to build a crank for a VW!
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
motofly196
motofly196 is offline
PostPosted: Sun Jul 21, 2019 11:38 am    Post subject: Re: Mystery Stroker crankshaft Reply with quote
I wouldn't be the one that has to clearance the case for that crank.... Shocked
slalombuggy
slalombuggy is offline
PostPosted: Sun Jul 21, 2019 5:32 pm    Post subject: Re: Mystery Stroker crankshaft Reply with quote
Holy windage Batman. That looks positively agricultural.
brad
Dr. Denzel
Dr. Denzel is offline
PostPosted: Sat Jul 27, 2019 9:10 pm    Post subject: Re: Mystery Stroker crankshaft Reply with quote
Denzels did indeed come with 67mm cranks, but there were also other stokes.
The earliest Denzel factory 1300cc engines had a bore and stroke of 80mm X 64mm. (This would have been when they used the stock 36hp VW crank with a stroke of 64mm.)
Later Denzel factory 1300cc engines had a bore and stroke of 78mm X 67mm.
In the later years Denzel also offered two 1488cc engines, one in their standard roadster and one in their high performance "Sport International" roadster. These engines had a bore and stroke of 80x74 mm. At least some of the Denzel 1500 engines had a Hirth roller bearing crankshaft, just as early Porsche pushrod 1500cc 356 engines and the 1500cc Carrera four-cam 356A engines.
Just to make it a little more complicated, some Denzel kit engines were sold by EMPI at the same time as they sold their X100 stroker crank. The circa 1960 EMPI literature I have which includes the X100 crank for the 36 hp engine does not list the stroke, but says the X100 is 6mm longer. This would make it stroke of 70mm.
I have a Denzel kit engine that has a crank that appears to have a 69.5mm stroke. I wonder if the literature mentioned above just rounded off an actual 5.5mm increase to a 6mm increase? (The difference being an EMPI crank of 69.5mm or an EMPI crank of 70mm.)
Lastly, some Denzel cranks are stamped "ES" followed by several digits, such as "ES 625". Does anyone know what the "ES" indicates?
Jim Perrin
QRP
QRP is offline
PostPosted: Mon Sep 23, 2019 12:06 am    Post subject: Re: Mystery Stroker crankshaft Reply with quote
HAHAHAHAHA!
[email protected]
PostPosted: Sun Sep 14, 2025 6:07 pm    Post subject: Re: Mystery Stroker crankshaft Reply with quote
Whatever happend to this crankshaft???...
puchfinnland
puchfinnland is offline
PostPosted: Mon Sep 15, 2025 5:50 pm    Post subject: Re: Mystery Stroker crankshaft Reply with quote
Did DENZEL ever make a 40hp conversion??
ABYC marine master technician , EX European auto technician, new business- EASTCOASTWEST , custom work on campers, only systems, no mechanical
[email protected]
PostPosted: Mon Sep 15, 2025 5:58 pm    Post subject: Re: Mystery Stroker crankshaft Reply with quote
No...but there was a story's i heard years ago that denzel well working with bmw in the 1960s denzel had empi sell his 36hp kits just like okras during that time but was also working on kits for the 40hp but I've never seen any denzel heads for 40hp .. maybe bmw stopped him from it ??? But as of now no denzel 40hp parts were made ...unless someone finds a denzel protype 40hp head but I think by now we would of seen them ..but who knows if the story was true ..
