Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26253 Location: Olympia Wash Rinse & Repeat
Posted: Wed Sep 10, 2025 8:26 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
| don.ville wrote: |
The rears have tight spots and loose spots.
I’ll report back a what the O’Reillys brake drum people find out.
I already dropped it off without measuring it. |
Brake drums always have a little tight and loose feel at the drum. As long as the pedal does not pulse it should be good in that way. Personally have rounded back out drums that were badly warped over a month of daily driving locally. When possible coming up to a stop will apply pressure to the brake pedal gently at first and ramp the pressure up slower than normal.
Not a lot of excess material in VW drums to just cut out, so that should be a last option. Having the drum surface angled from inside to outside or gouged badly due to say you let the shoes wear down to metal. _________________ In Stereo, Where Available! |
don.ville  Samba YardMan
Joined: February 07, 2008 Posts: 2967 Location: West Palm Beach, FL
Posted: Wed Sep 10, 2025 7:22 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Well O’Reillys couldn’t do the drums because of the splines on the drum they said it would not work on their machine.
Picked them up.
One drum is thicker than the other.
This one has a wider inside diameter since the lip is thinner.
Shoe fits the arc of the good drum.
The same shoe does not fit the other drum arc.
This drum appeared to have been cut??
Type 3 rear brake drum.
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
Posted: Wed Sep 10, 2025 7:36 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
| Eric&Barb wrote: |
| don.ville wrote: |
First part from the rebuild kit I tried was the accelerator pump diaphragm.
The new part at the top has a strange double diaphragm. Mistake or different design? |
Mistake, you could cut off most of the outer side rubber to turn that into a good part. With two it can not flex properly enough. |
This can’t be a mistake. What are the odds?
I got this one from Amazon from a different manufacturer. This kits had more parts and included a fuel filter and floats.
The pump diagram also has a double gasket
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15446 Location: Casa de Oro, California
Posted: Thu Sep 11, 2025 6:30 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
| don.ville wrote: |
Picked them up.
The diameter I'm asking about is from one side inside of the drum to the other inside of the far side of that drum. |
Posted: Thu Sep 11, 2025 7:42 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
This is a 205mm drum from factory for a 63-65 Type 3.
My calipers aren’t that wide and the tape measure I have is not precise enough to measure wear between the drums _________________
Posted: Mon Sep 15, 2025 8:27 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Posted: Mon Sep 15, 2025 8:29 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
new bearing cap bolts and wavy washers, new emergency brake to backing plate mounting clip and bolt.
Posted: Tue Sep 30, 2025 8:56 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Brakes feel really good.
Moving on to other parts.
My fried egg turn signals are Hella old, time for an update.
I will skip painting the plastic chrome ring, looks fine to me.
Part was from CIP1 _________________
Posted: Thu Oct 02, 2025 6:47 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
| Eric&Barb wrote: |
| don.ville wrote: |
Check out this product advertised where the pic shows what looks like double seals on the rubber parts.
https://www.thesamba.com/vw/classifieds/detail.php?id=2560098
Posted: Tue Oct 07, 2025 6:09 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Random pics of interior with TMI seat covers and cheap home carpet on the floor.
BarryL  Samba Member
Posted: Tue Oct 07, 2025 6:25 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
So nice. Good job.
What sequence of layers did you use on the seats? |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4996 Location: Stuck in Ohio
Posted: Tue Oct 07, 2025 8:37 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
| BarryL wrote: |
So nice. Good job.
Metal springs, carpet/fabric layer over springs, TMI custom fit sponges for each seat, then vinyl seat cover
Posted: Thu Oct 09, 2025 4:19 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Another random cleanup item.
The rubber trim on the elephant ear mirrors.
I removed the old trim sometime before 2010 and left it naked since then.
The sharp edge cut a serious slice in my forearm earlier this year when I was washing the roof. Lots of blood lost.
Let’s fix that.
I ordered part 211857515 from Wolfsburg West for a few dollars.
I was really stiff so I had to heat it up.
BarryL  Samba Member
Posted: Fri Oct 10, 2025 6:08 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
| don.ville wrote: |
| The sharp edge cut a serious slice in my forearm earlier this year when I was washing the roof. Lots of blood lost. |
Dude, that sounds serious. When you least expect something. |
Posted: Wed Oct 22, 2025 3:26 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Before I bought my bus the interior light switch on the left side of the steering was missing. Just an empty hole for the last 18 years.
Well I had enough in my piggy bank to get an OE switch to fill the void
Not wired as yet.
The previous owner already installed door pin switches to make the lights come on when the front doors and rear hatch are opened. I disconnected the rear hatch switch but left the ones on the front door since I would have to weld up the holes if I removed them.
Saving up next for the headlight, wiper, and hazard switches on the dashboard to replace the late model beetle switches. _________________
Posted: Thu Oct 23, 2025 5:07 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
It may be time to change the oil cooler seals. I see small amounts of oil under the carb.
If I pull engine I’ll do the pushrod seals at the same time.
Not wanting to mess with head bolts, I got these.
Anyone use these ? _________________
BarryL  Samba Member
Posted: Thu Oct 23, 2025 6:36 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
| I have used two individual ones on an engine that two pushrods bent and took out the tube. It feels like they are just in there by-gosh-or-by-golly but somehow they have been drip free. |
