Matra Tools w/photos
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
1500king
1500king is offline
PostPosted: Wed Jun 19, 2024 1:41 pm    Post subject: Re: Matra Tools w/photos Reply with quote
I had several made from those drawings.
I'm 175cm. They're for small humans, before 1950's steroids and over eating....
BulliBill wrote:
A photo would help, but if those two removable pins are located about a foot or so below the 313 head of the tool, they are for attaching two optional long metal arms and at the end of each arm a Y-shaped metal yoke which would support the mounting of a transaxle bellhousing to the 313 yolk and the two "Y" shaped yolks at the ends of the arms would then support the ends of the axles. A manual photo of the add-on accessory #643 transaxle support arms and yokes:
The long arms and yokes are a fairly rare option which I happen to have on my 313 engine stand. Adding that optional arm and yolk set allows your engine stand to service both engines and transaxles. A very cool optional tool... Mine for your perusal...
Bill
1500king
1500king is offline
PostPosted: Wed Jun 19, 2024 1:53 pm    Post subject: Re: Matra Tools w/photos Reply with quote
There's VW310 and VW310a. They're different. 310a incorporates the 40hp platform.
Fishynos72 wrote:
Good evening,
A long awaited addition to my shed, something I haven't chased but have been eyeing off, as I have a crankshaft to assemble this coming week.
As found condition
Fishynos72
Fishynos72 is offline
PostPosted: Fri Jan 24, 2025 4:39 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Happy 2025 toolaholics.
Forgot to update some new additions late last year. Pretty much rounding out the bench mounted tooling I need for the time being
As purchased, came out of a long time Vw business that closed a few years ago.
The value compressor tool was one I was looking forward to as I've not owned one previously.
How it's currently sitting
I've finally sourced the chemicals to re finish the steel components in the "blued" finish, but yet to have the chance to try them.
I also have to make a replac pin to correct this interesting repair
I won't bother you with too many photos of the the 313 mount and crank holding tool.
The later being the revision to do 40hp onwards and the 313 being the other casting style. I'm sure someone knows more about era details for that change
I have to make up some pieces for instance the tension handle for the 313 and then go through the small pile of tooling once I have this blueing process nailed.
Collector of all things Volkswagen, Hazet and Matra.
1957 old speed fun
https://youtu.be/8A7JyvR-eiA?si=q7Rxfxrspk6zCd6p
2005 Caddy panel van chaos
https://youtube.com/playlist?list=PL2xEOS4ROOAQkVmo-vvYzYY-rGMv3ZkHL&si=cnzqpamsnBr5HlMH
bavarian1
bavarian1 is offline
PostPosted: Fri Feb 07, 2025 3:53 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Matra 309, 309c-1
'58 Beetle - L245 Bronze
'73 Vert SB - Dove Grey
'74 Sedan SB - Tropical Green
'72 Bay Panel - Pastel White
Fishynos72
PostPosted: Sat Jun 28, 2025 9:54 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Hope everyone is well and not sick or my before and after shots.
VW2202C drum puller, to be used in conjunction with 202 and the 202D arms
My 202 needs work and will get a similar treatment to the above, however if anyone has any 202D arms they're not using I'd love the chance to own a set.
1957 old speed fun
thekombistop
thekombistop is offline
PostPosted: Sat Oct 04, 2025 4:56 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Anyone able to identify this tool? Can't find anything about it, whether its part of another tool or if this is even VW to begin with...
Came with a bunch of other Matra or similar VW tools, some aircooled and some early Rabbit tools
Says "US 067" on the backside
Page 9 of 9
