Anyone here had much experiance with the Rotax 912
MVB
MVB is offline
PostPosted: Wed Nov 05, 2025 4:35 am    Post subject: Anyone here had much experiance with the Rotax 912 Reply with quote
I Found one for sale cheap. I assume it’s too far gone for aircraft certification.
Anyway anyone know how hard it is to remove the Reduction gearing & replace it with a Type 1 or Type 4 flywheel, at either end?
They have alloy Nikie Barrels, a dry sump & rev to 5.8K (hence the reduction gearing) & come with fully closed deck watercooled heads (but each head’s cooling system has a capacity of just 1.5 litres) with air cooled barrels & air cooled crankcase.
Anyway does anyone here know much about them?
Nitramrebrab72
Nitramrebrab72 is offline
PostPosted: Wed Nov 05, 2025 6:45 am    Post subject: Re: Anyone here had much experiance with the Rotax 912 Reply with quote
Good for making a light weight beetle...
MVB
MVB is offline
PostPosted: Wed Nov 05, 2025 7:21 am    Post subject: Re: Anyone here had much experiance with the Rotax 912 Reply with quote
I don’t know if the heads are shrunk screwed, like Generation 4 Jabaroo heads are.
