car barn Samba Member
Joined: October 02, 2008 Posts: 139 Location: Michigan
Posted: Fri Nov 07, 2025 3:42 pm Post subject: What's this bracket for? |
Saw this bracket inside of the front quarter panel of my 65. There's one on both sides. It's welded to the door jam side. It's curved like it's supposed to hold something, but it not touching any other panels.
supercub Samba Member
Posted: Fri Nov 07, 2025 3:47 pm Post subject: Re: What's this bracket for? |
| Defrost tube bracket. The tube connects to the hole at the down at the bottom coming out of the heater channel. Heard they are a pain to reconnect, but I've never personally tried. |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1402 Location: So. Cal
Posted: Fri Nov 07, 2025 4:08 pm Post subject: Re: What's this bracket for? |
| supercub wrote: |
I can attest that they are a pain. My 64 had them sort of "crimped" you can get a slender hand down there to install new ones. I found that no matter what i did my arm came out all tore up from sharp edges down there.
Unbolting the hinge helped me alot.
_________________ 1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat. |
Posted: Fri Nov 07, 2025 4:18 pm Post subject: Re: What's this bracket for? |
| Ahhhh... that makes total sense. Thanks guys. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36324 Location: Conejo Valley, CA
Posted: Fri Nov 07, 2025 4:45 pm Post subject: Re: What's this bracket for? |
Down low are sharp ends of carpet nails driven through it from the drive and passenger kick panels. Beware!
Some have used PVC pipes for the lower part to make the job easier. Search and you'll find this and other tips. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
67conv Samba Member
Joined: July 10, 2005 Posts: 464 Location: Simi Valley, California
Posted: Sat Nov 08, 2025 8:34 am Post subject: Re: What's this bracket for? |
| matthew henricks wrote: |
| supercub wrote: |
Nice approach, Matthew!
But no matter how much of a 'pain' or difficult you think it is with a Beetle sedan, the additional Karmann factory sheet metal bracing surrounding that area added for Convertibles makes any attempt at re-connecting that defrost hose down inside the "Bermuda Triangle" a lesson in frustration and futility! It truly is nearly impossible without dropping the pan!
_________________ 1967 VW Convertible, owned 35 years.
1957 DKW 3=6, owned 21 years.
PREVIOUS: 1972 "Baja Champion SE" Spec. Edition Beetle bought NEW @ Pierce VW in Denver; 1979 Super Beetle Convertible bought NEW @ Downtown LA VW; 1967 type 1 savanna beige; 1967 Porsche 2.0 911S; 1973 Porsche 2.4 911T; 1963 356 T6 B Cabriolet; 1964 356 SC sunroof coupe; 1972 Type-3 Squareback; 1968 + 1969 Type-3 Fastbacks; 1987 Vanagon GL Weekender |
