Swing axle parts compatibility
summerof78
summerof78 is offline
PostPosted: Tue Nov 04, 2025 8:48 am    Post subject: Swing axle parts compatibility Reply with quote
Which model years of gear box parts can be used interchangeably?
Specifically, I need a new differential for my '66 sedan. I need to narrow the search down.
Lookin' for a wheel stamped 5/66
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Tue Nov 04, 2025 4:59 pm    Post subject: Re: Swing axle parts compatibility Reply with quote
Since no one answered you I will give you my best recollection and if slightly off, hopefully someone will correct it. My recollection is that around 62 to 66 US bug used the same gearing so in that range would probably be be your best shot.
pondoras box
pondoras box is offline
PostPosted: Tue Nov 04, 2025 5:40 pm    Post subject: Re: Swing axle parts compatibility Reply with quote
Pretty much anything from 61 to 68 will work. 67 and 68 axle length and end castings are longer but will still bolt right up.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
Bruce
Bruce is offline
PostPosted: Sat Nov 08, 2025 1:57 pm    Post subject: Re: Swing axle parts compatibility Reply with quote
Do you know if your car has its original gearbox?
If it does, and you only need a new differential, you need to look for one from a 61-66 Beetle trans. Your 66 ring gear is attached using 6 bolts. After 67, they used 8 bolts, so the diff is different.
summerof78
PostPosted: Tue Nov 11, 2025 10:29 am    Post subject: Re: Swing axle parts compatibility Reply with quote
99% sure, though I haven't scraped off the sludge to get the numbers and verify. It is indeed 6 bolt.
That's the info I needed and no matter how many Google searches I did it wasn't coming up. Their stupid AI was useless.
Anyway, many thanks.
brian rogers
brian rogers is offline
PostPosted: Wed Nov 12, 2025 11:54 am    Post subject: Re: Swing axle parts compatibility Reply with quote
62 to 66 are all the same. 67 is unique to 67 with long axel and short splines. 68 has long axel long splines. The difference is the bearing will interchange but axels, housings and bearing caps will not. IF the trans is complete they will interchange.
