Package Shelf Dimensions
K9SWR
K9SWR is offline
PostPosted: Sat Nov 08, 2025 7:30 pm    Post subject: Package Shelf Dimensions Reply with quote
I was wondering if anyone has dimensions and detailed pictures of a package tray?
I'd like to try to make my own package tray.
zerotofifty
zerotofifty is offline
PostPosted: Sat Nov 08, 2025 9:09 pm    Post subject: Re: Package Shelf Dimensions Reply with quote
I dont have that, but I know of someone that has a wicker one, under the dash. His was mounted a bit to low, such that the tip of the driver's shoe hits the bottom of the wicker shelf when using the brake or clutch pedals. It is VERY annoying, and the wicker got torn from the tip of his shoe brushing on it.
My advice is mount your shelf with plenty of clearance over the pedals, consider some drivers may have big feet, or wear pointy shoes, cowboy boots, big work boots. Leave lots of space. Some folks push the pedals with their toes, other folks with their heels. You should make clearance for these situations. It is also a safety concern if ones tip of shoe hits the shelf when needing to brake!
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
jinx758
jinx758 is offline
PostPosted: Sun Nov 09, 2025 9:10 am    Post subject: Re: Package Shelf Dimensions Reply with quote
A few years ago a member of my car club used a roll of floral wire & cheap duct tape from Wally-World to get a surprisingly accurate template of the contours under the dash of his bug to make a package tray DIY-style.
He found some wicker type shelves at a craft store & fashioned a fairly cool & functional tray.
Didn't hold up too well but the 2nd one has been coated with clear stay from a can.
I used that floral wire to make a template for the sides of an under dash console but left the paper template at a buddy's garage & got trashed. ARGH ...
Outside the box can work ... good luck
jinx
" It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor
panicman
panicman is offline
PostPosted: Tue Nov 11, 2025 9:41 pm    Post subject: Re: Package Shelf Dimensions Reply with quote
What kind of shelf are you wanting images and measurements of? The bambus, or the Kamei?
K9SWR
K9SWR is offline
PostPosted: Wed Nov 12, 2025 8:48 am    Post subject: Re: Package Shelf Dimensions Reply with quote
I honestly didn't know there was more than one... I think eithher would be fine.
