1968 squareback battery problem
VWfiend78
VWfiend78 is offline
PostPosted: Fri Nov 07, 2025 6:17 pm    Post subject: 1968 squareback battery problem Reply with quote
Question here , I had an old battery that went dead , it was an ACDelco group 42 and I replaced it with a 26r. Now tha car started right up but sounds weird like the starter is spinning too much or whining I guess you could say . Seams to start with a lot less cranks too . Like too fast if you will if that makes sense . Any ideas? Maybe sticking ignition switch?Thanks
Bobnotch
Bobnotch is offline
PostPosted: Sat Nov 08, 2025 10:56 am    Post subject: Re: 1968 squareback battery problem Reply with quote
Maybe the difference is having a new battery vs having an almost dead one that you just got used to. I run an AC Delco top and side post battery in my own car. I can't remember the group number though, but I also have a couple of side post vehicles (GM's) around here which allows me to move it around and keep it charged. Wink
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
biffidum
biffidum is offline
PostPosted: Mon Nov 10, 2025 6:09 pm    Post subject: Re: 1968 squareback battery problem Reply with quote
I'm assuming your vehicle is all 12V...
VWfiend78
PostPosted: Tue Nov 11, 2025 11:22 am    Post subject: Re: 1968 squareback battery problem Reply with quote
Yes 12v
gt1953
gt1953 is offline
PostPosted: Tue Nov 11, 2025 12:56 pm    Post subject: Re: 1968 squareback battery problem Reply with quote
Is the starter releasing??
72 type 1
72 Squareback
VWfiend78
PostPosted: Sat Nov 15, 2025 10:43 pm    Post subject: Re: 1968 squareback battery problem Reply with quote
Yes it starts but seems like it is maybe atuck on for a second after so it whines , if that makes sense .
