DIY Judson
BFB
BFB is offline
PostPosted: Fri Nov 14, 2025 6:56 pm    Post subject: DIY Judson Reply with quote
anyone ever made or considered making a Judson type supercharger?
I don’t figure it’d be to hard to do the machine work , its a pretty simple design. But id figure getting the right material for the rotor vanes would difficult?
I have a book, more like a homemade than production, that goes over modifying air tools to work as superchargers for small engines. Always thought that was a cool idea
Most experts aren't.
RWK
RWK is offline
PostPosted: Fri Nov 14, 2025 8:20 pm    Post subject: Re: DIY Judson Reply with quote
I have used some of the garolite/bakelite products from McMaster for the one's I have done, flat and true to size.
And yes, just a simple pump.
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
FarmerBill Premium Member
FarmerBill is offline
PostPosted: Fri Nov 14, 2025 8:27 pm    Post subject: Re: DIY Judson Reply with quote
The vanes are phenolic I believe, probably with some sort of fiber or fabric reinforcement. I would imagine the trick is to get them dead flat and of equal weight.
BFB
BFB is offline
PostPosted: Sat Nov 15, 2025 11:12 am    Post subject: Re: DIY Judson Reply with quote
Having used air tools for a few decades, ive rebuilt several and it seemed the vanes in those were fiber reinforced.
I wonder if nylon would be good? Ive read they use it for gears in rc cars and that it has a “lubricating “ type property and pretty heat tolerant too?
RWK
RWK is offline
PostPosted: Sat Nov 15, 2025 8:15 pm    Post subject: Re: DIY Judson Reply with quote
Yes, the Garolite is a fiber/epoxy reinforced phenolic, nylon isn't typically used as vanes in pumps, use the material the vanes were originally designed with, engineering is already done.
73 Type 181
63 Type 113
BFB
BFB is offline
PostPosted: Sun Nov 16, 2025 10:07 am    Post subject: Re: DIY Judson Reply with quote
surprisingly there's more info online than I thought there'd be, and apparently quite a few different manufacturers of the vane type superchargers which doesn't surprise me at all were just more familiar with the Judson in the VW world.
one place I read said "Judson's tend to use a version of Tufnol called Carp", someone else said they personally built one using carbon impregnated fiberglass.
I read a clip from an old article that looked to be from the 60's and guy stated that for higher boost, about 25 psi, one company used iron vanes and sleeves. which I thought would make sense, thats what's used for piston rings & cylinders.
Dusty1
Dusty1 is offline
PostPosted: Mon Nov 17, 2025 1:40 pm    Post subject: Re: DIY Judson Reply with quote
I like phenolic impregnated linen.
"May you live an interesting life."
