Serial numbers used to date code our 28 PCI carburetors
BulliBill
BulliBill is offline
PostPosted: Sun Jan 19, 2020 4:52 pm    Post subject: Serial numbers used to date code our 28 PCI carburetors Reply with quote
Hi all,
I searched but didn't discover a topic about using the serial numbers stamped into the bowl area of our 28 PCI carburetors to sort of "date code" our carbs. Not sure if others have tried to sort out when various carbs were made and track any improvements made in them. I have a box full of 'em and wondered (other numerical progression of serial numbers) how to basically date code them. A few of us might want to find a carb serial number appropriate to the year the engine was produced.
Anyway, if there is already a thread, please point me toward it, or lets do this!
Some of the digits are a bit hard to read. All of the serial numbers I have are either six or seven digits long. My earliest 28 PCI carb in the box is #722944 and my latest is #4998957
Bill Bowman
I'm looking for these license plate frames from old Volkswagen dealerships for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
PostPosted: Sun Jan 19, 2020 5:13 pm    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
There is no specific thread about it as far as I know but I have seen it asked a few times.
A recent thread though:
https://www.thesamba.com/vw/forum/viewtopic.php?t=729601
Volumex
Volumex is offline
PostPosted: Thu Mar 05, 2020 1:32 pm    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
Some info here: https://www.thesamba.com/vw/forum/viewtopic.php?t=482472
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Thu Mar 05, 2020 3:32 pm    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
I'm doing the same thing on a small scale with fuel pumps here
https://instagram.com/mr.ogpaint
Patrick Hall
oldslow
oldslow is offline
PostPosted: Wed Nov 05, 2025 2:02 pm    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
28PCI serial numbers:
I too have found it surprising that so little attention has been paid to the 28PCI. After all, it was used for longer than any other carburetor, and may be the most common VW carburetor ever. Millions of 1950’s beetles, busses, and Ghias and industrial engines had them.
I tabulated data on carburetors from TheSamba forums and gallery, as well as from eBay and my own collection.
28PCI’s can be divided into two broad styles: I call them “early” and “all the rest”.
The early style has a ribbed fuel bowl to accommodate s brass float, and the early top piece has a removable brass idle jet (it’s tiny)
The very earliest base had no provision for vacuum. Later early bases had a “D” shaped boss that was not drilled if it was intended for a bus, or drilled and tapped for vacuum if intended for a beetle. The early bases also had an iron grub screw that held the venturi in place. I believe that as production progressed all early bases were tapped for vacuum, and those headed for a bus had a brass set screw to close off the hole.
The earliest bases lacked the “28 PCI” cast on the bowl, and the round VW logo changed from a fat style to thinner lines over time. There seem to be 3 or 4 slightly different VW logos throughout the entire early to late production.
As for the all the rest? Well sometime between #1364556 and #1965149 was the end of the early bases and tops. The later bases had a steady evolution of minor changes for the rest of the 28PCI run. For example one easy change to spot is the words “Made in W. Germany” this was added around #3500000
So how does this help to match a specific carb to a specific engine? It’s pretty obvious that the 36hp carburetors were sequentially numbered with the earliest seen so far from about #70000 to up to maybe #5000000. At a guess something like 4,930,000 numbered carburetors and an unknown number of blank ones were produced. After reading about total production in the archives I calculate that about 3867975 beetles busses and Ghias were produced with the 36hp engine. Add maybe 73000 industrial 36s to bring the total to about 3,941,000. This doesn’t match up to well with 4,930,000 carburetors. Off by a million. Maybe the carburetor serial numbers are sequential but have gaps, so perhaps carburetor 4998957 is the 3,990,000‘th produced. Maybe VW recycled a million 36hp motors and put new carbs on them. Maybe my production numbers are wrong.
We do know a few things though. The first vac advance carburetor (VJU 4 BR 2) went to December 1953 beetles so we can match that with the first vacuum carburetors. Progressive refinements says the brass float was eliminated 03/17/55.
If you have a zwitter it for sure came with the early style carburetor. If you have a ‘59 or’60 it’s going to say Made in W. Germany. 56,57,58? not sure yet exactly.
So all you picky stock lovers out there, go out to your low mileage never modified engine and photograph the carb and its serial number. Post it in the gallery and tell us about it.
- better to drive a slow car fast than fast car slow -
Dan22
Dan22 is offline
PostPosted: Thu Nov 06, 2025 12:46 pm    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
BulliBill wrote:
Hi all,
Bill Bowman
Hey Bill,
If you think your carb is original to your car, post the number on it. Someone (maybe me!) can make a chart with serial numbers vs car dates and make an extrapolation line to predict other years or numbers. This assumes other folks post their carb and Manuf Date too.
1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074
janerick3
janerick3 is offline
PostPosted: Thu Nov 06, 2025 2:06 pm    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
I've posted some of these numbers sometime in the distant past, but here goes:
28 PCI:
- 1377021 from engine 20-0922XXX, 12/54, early base, undrilled vacuum boss
- 1436019 from engine 1-0960XXX, 01/55, early base, brass tag
- 1716897, not original to engine, late base, steel tag
- 4650897, believed from 1960 engine
I have 1-2 others buried in my shed w/no traceability
Thanks,
Jan K.
Dan22
Dan22 is offline
PostPosted: Fri Nov 07, 2025 5:09 pm    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
Here is a graphical predictor of the carburetor number based on the engine number using the data in this and other threads. The curve looks reasonable given the increasing popularity of the cars and production increases.
If I get other confirmed numbers I can add it and give an update. The formula is there but you have to use an x number based on what excel uses for a date, something like the number of seconds since 1970 or something like that. And you need a scientific calculator for the exponent of e.
I really hope BulliBill posts the carb number on his original June 1955 beetle because my car is also a June car. Smile
Ted2
Ted2 is offline
PostPosted: Mon Nov 10, 2025 5:21 am    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
As an aside, I have two carbs with partial aluminum tags. What were those for?
my59
my59 is offline
PostPosted: Mon Nov 10, 2025 9:46 am    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
The 28PCI in the car has one (inaccessible at the moment), and my parts 28PCI has one- stamped 111 129 023. Its the part number.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
BulliBill
PostPosted: Mon Nov 10, 2025 4:16 pm    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
Dan22 wrote:
BulliBill wrote:
Hi all,
Bill Bowman
Hey Bill,
Wow! I just saw this. I just went to look for the carburetor serial number and of course it is stamped into the carburetor bowl on the forward side of the carb facing the fan housing. Hard to read the numbers, but without removing "Martha's" original 28 PCI carburetor and with the help of a tach flashlight and a swivel head dental mirror I think what I can make out is 1614435. I hope that's correct! No way I could get a camera in there for a photo...
The factory carb aluminum stamped part numer tag says: 111 129 023 with no letters after the number.
Bill
Dan22
Dan22 is offline
PostPosted: Thu Nov 13, 2025 9:48 am    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
Thanks Bill. The mirror method should be fine!
I plugged it into the data and it fits perfectly in the curve between April and July.
Käfer2
Käfer2 is offline
PostPosted: Thu Nov 13, 2025 11:26 am    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
Carb S/N 2378750
factory carb aluminum stamped part numer tag: 111 129 023
Oval, date of manufacture Nov 27, 56
Body # 3784XX
Chassis # is 1 366 0XX
Engine # 1 638 9XX -> Nov. 1956
((Carb S/N 2301388
Engine # 122-0262XX
Industrial engine, manufacturing Date on nameplate „1956“
It is difficult to narrow it down more precisely.
Corresponding to https://www.thesamba.com/vw/archives/info/industrialdating.php
„122-024 443: Oct 04, 56“
„122-026 807: Dec 29, 56“
it was manufactured between this days))
Dan22
Dan22 is offline
PostPosted: Thu Nov 13, 2025 12:23 pm    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
Very nice. I will add these too.
sunroof
sunroof is offline
PostPosted: Fri Nov 14, 2025 10:11 am    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
This is a 28PCI that is from a car built during the first week of August 1954
Engine #1-0832260
Don
Better and better mistakes!
BulliBill
PostPosted: Sun Nov 16, 2025 4:21 pm    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
Well, I just acquired another complete and fairly nice condition Solex 28 PCI carb with serial number 3107901. It unfortunately didn't come with an original car to try to cordinate/verify adate of original installation. I'm guessing that it is around 1958-ish? It had the brass plug in the vacuum port to the distributor, so I'm guessing it was originally mounted on a Type 2 with a centrifigal advance distributor.
Bill
Dan22
Dan22 is offline
PostPosted: Mon Nov 17, 2025 11:48 am    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
OK I added the few more rows that I had. One seemed out of place noted in the red dot. I added more tickmarks to better see the numbers. The formula for some unknown reason is not working with this chart. I back calculated both ways solving for X and Y. The graphical interpretation is all I can offer at this point.
Käfer2
Käfer2 is offline
PostPosted: Mon Nov 17, 2025 12:06 pm    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
Oh I'm sorry Dan, thank you for your keen eye.
I mentioned the ovals body number 3784XX
Chassis number is 1 366 0XX
I have corrected it above.
Dan22
Dan22 is offline
PostPosted: Mon Nov 17, 2025 12:22 pm    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
OK I fixed the data in my table and it will show next round.
sunroof
sunroof is offline
PostPosted: Mon Nov 17, 2025 12:59 pm    Post subject: Re: Serial numbers used to date code our 28 PCI carburetors Reply with quote
Forget everything I said. This carb did NOT come with the car. I bought it from someone here on thesamba. I could not make the original work so I replaced it.
Don
