Fuel sender repair
Yannvanh
Yannvanh is offline
PostPosted: Tue Oct 28, 2025 4:31 pm    Post subject: Fuel sender repair Reply with quote
Next on my project was the gas tank/fuel sender.
Did a test on my fuel sender but it was heavily corroded.
So gave it a shot and tried to repair.
Started to take it apart and clean al the components!
Originally it was riveted but i took a copper bolt and gave it a try
Made a gasket so no fuel would leak at the connector.
Then started building it up:
A bakelite washer to avoid contact from positive to ground:
Metal washer on top:
I soldered the cable back (hard to see in the pic)
Put everything back together and give it a test!
Empty tank:
3/4 tank:
I need to order a fuel gauge so i can test it on a gauge itself but i think i did a good job!
'66 vw splitbus project:
Instagram page:
yannicks_splitbus_project
Always there to help!
BarryL Premium Member
BarryL is offline
PostPosted: Tue Oct 28, 2025 6:34 pm    Post subject: Re: Fuel sender repair Reply with quote
I especially commend you for the nichrome wire part.
@Buswerx
@Buswerx is offline
PostPosted: Fri Nov 14, 2025 11:13 pm    Post subject: Re: Fuel sender repair Reply with quote
Wow
Lots of work and patience
Good work
matthew henricks
matthew henricks is offline
PostPosted: Tue Nov 18, 2025 8:18 am    Post subject: Re: Fuel sender repair Reply with quote
Very nice. Something many would never even consider. Love it!
1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat.
Douglas Denlinger
Douglas Denlinger is offline
PostPosted: Wed Nov 19, 2025 8:59 am    Post subject: Re: Fuel sender repair Reply with quote
I knew there was a reason I have held on to all the originals that were removed from customers buses that were not working over the years.....something to do during retirement! Nice work!
Transporter Restorations
Upholstery Haus
Active 23 Window Samba Collector/Restorer,since 1986
