flat4freak1978 Samba Member
Joined: June 02, 2003 Posts: 793 Location: stone mountain georgia
Posted: Mon Sep 15, 2003 8:00 am Post subject: 2 questions. |
1. i am trying to change my fan belt on my 78 bus because my old one is squeaking. i take off the pulley and cannot get the pulley off the bolt it is on ????? any help here would be most appreciated. peace.
2. Do i have to remove the 46mm axle nut in order to build the rear brakes on my 78 bus?? help again would be greatly appreciated as i can tell my rear brakes are shot to heck.
peace
justin _________________ 1978 bus. 2.0 f.i. manual trans. "the great gonzo" |
NeverHadaBeetle Samba Member
Joined: October 08, 2002 Posts: 442 Location: Missouri
Posted: Mon Sep 15, 2003 8:12 am Post subject: |
Whoaaaa there Freak! Don't remove the pulley. You need an allen wrench (6mm I think) to loosen the hex head bolt behind the plastic cover just above the alternator. The plastic cover is about 3-4 inches long and plugs into the engine tin. Loosen this bolt, but do not remove it. Now climb under the bus and look for the bottom bracket that holds the alternator. It should be obvious. Use a 14mm or a 13mm (I have seen both) nut with an open ended wrench and loosen, but do not remove this nut. After loosening these two nuts/bolts the alternator should slide back and forth enough to remove, replace, and adjust the belt.
You do not need to remove the axle nut on the rear drum to service the brakes. Remove the two 11mm bolts from the outside of the drum. Access the adjuster wheel through the small hole in the bottom backside of the drum and and back the shoes off by loosening the adjuster wheel. The drum will now come off, but it may take some work. Now go buy a Bentley Manual with the money you have saved by doing your own work. Good luck. _________________ "Well, we shot the line and we went for broke
With a thousand screamin' trucks
An' eleven long-haired friends a' Jesus
In a chartreuse micra-bus." |
Posted: Mon Sep 15, 2003 4:32 pm Post subject: |
hey man i appreciate it. i have a bentley manual. take care. _________________ 1978 bus. 2.0 f.i. manual trans. "the great gonzo" |
