Newbie
JThw8
JThw8 is offline
PostPosted: Wed Sep 17, 2003 12:49 pm    Post subject: Newbie Reply with quote
Hi folks. Newbie here. Im going to pick up my 73 tonite. Its a bit of a restoration project and is currently missing its drivetrain, but it was cheap and the body is mostly straight and solid so it will make a good starting point.
Im located in Southern NJ, hope to find some other Thing junkies in the area.
If anyone is in the area with some drivetrain leads or knows of a parts car ( I need to cut out some rear fender sections to weld in to patch a bad dent on the passenger side rear ) please feel free to drop me a line at [email protected]
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Wed Sep 17, 2003 2:09 pm    Post subject: Reply with quote
You can pretty much use all Bug running gear and beam in a thing. Smile Oh yeah, Welcome to the site!
Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!!
JThw8
JThw8 is offline
PostPosted: Wed Sep 17, 2003 4:55 pm    Post subject: Reply with quote
Yeah, thats pretty much my plan, upon inspection the #$%@ shop that removed the tranny just torched of the frame ends so I will have to find a donor and weld that back in too.
The PO is trying to find me the old tranny from his other car so I can steal the output flanges off it to convert a beetle trans if needed.
Still need to find a back half though, the more I look at it the less I think it will succumb to a big mallet Sad
bljones
Resident Wit
bljones is offline
PostPosted: Wed Sep 17, 2003 5:47 pm    Post subject: Reply with quote
I have a Thing trans available if you need it.
OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2%
JThw8
JThw8 is offline
PostPosted: Wed Sep 17, 2003 6:04 pm    Post subject: Reply with quote
I definitely need it, but Im concerned with what shipping would cost. ship to zip is 08012, if the shipping can be arranged for a decent price I wil definitely like to hear more
Thanks!
Jim
TimGud
TimGud is offline
PostPosted: Thu Sep 18, 2003 7:23 am    Post subject: Reply with quote
Now that is going to be hard to fix. If you can try to get a Thing transaxle as it's geared for the heavy beast.
Once it's running though it will be worth all the effort you put into it. They are a blast to drive!
bljones
Resident Wit
bljones is offline
PostPosted: Thu Sep 18, 2003 7:29 am    Post subject: Reply with quote
Trannies are heavy, so UPS shipping is out. I can ship by greyhound, ABF or Forward Air. $350 including shipping.
OG JHC
2%
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Thu Sep 18, 2003 10:13 am    Post subject: Reply with quote
How far back did they torch off the frame horns? I have welded some on to replace RUSTED out ones before several times, it was really pretty simple, Take some measurements first...Sawzall some off a donor pan/ old t-bone and then after you mock it backup make sure you have the angle and dimensions to your satifaction them Mig weld them up good.
I tacked them up and bolted the tranny moount cross member in place to get that dimension right and square everything up.
Good Luck!
edgy
edgy is offline
PostPosted: Thu Sep 18, 2003 4:31 pm    Post subject: Reply with quote
Check shipping for the tranny. I got a used Vanagon transmission from Michigan to MD for $150 via truck. I sent the core back via FedEx for about $100.
