kintail Samba Member
Posted: Sat Nov 12, 2005 1:26 pm Post subject: SO 23 Hatch replacement - Advice sought |
Here's the situation for my '61 Westy:
Have removed the original hatch from the '61 with surface rust, couple of bent edges, hinge pins bent both sides, ....and one hatch bolt snapped off. Still restorable though.....
Have a '60 Westy hatch in way better shape, with minimal rust, straight hinges and all four bolts fine. However it is slightly different then the '61........ has two rubber stops on the hatch (need replacements... ideas?) unlike the '61 Hatch for resting the hatch on the roof........and the '60 hatch bolts are square shaped versus round on the '61....... plus an original wood panel I can refinish.
What would you do? Get uber vintage and restore the original '61 hatch..... or merely buff up the '60 hatch and install .......
Anybody reproing the interior Westy wood framing.......... have one structural roof brace I will need to replace...
Thanks!
Scott
'67 Westy
'61 Westy
'59 Beetle Kabriolett |
zimblewinder Samba Member
Joined: January 22, 2004 Posts: 893 Location: Australia
Posted: Sat Nov 12, 2005 4:21 pm Post subject: |
Only original one time, if youre thinking about this now, thenyoure most likely to remember it every time you look at the bus an know you should have gone with the original. I thought the westys were all about intricate detail and accessories?? Just my thoughts. Cheers _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism |
spookymulder Samba Proletariat
Joined: January 02, 2004 Posts: 3298 Location: I'm either at 95608, 97537 or 94708 only my CPA knows for sure
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Sat Nov 12, 2005 10:14 pm Post subject: |
pictures might be helpful. the hatch is a bolt on item, so you can easily change your mind no matter what decision you make unless it is the last item before the paint shop.
offhand, I can think of at least half a dozen variations of the hatch.
I am planning on replacing the hatch on my '56 westy because the original one is fairly messed up. I found on off of a '60 that looks pretty good. I will put them side by side and make sure that the new one is just the same as the old one should be. and make any necesary mods.
a couple pics of my westy with its roasted hatch:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=218391
http://www.thesamba.com/vw/forum/album_page.php?pic_id=218387
Clara makes the wood framing for the roof. _________________ .
Wanted:
Tim Samba Member
Joined: September 04, 2003 Posts: 170 Location: Texas
Stocknazi Samba Member
Posted: Sun Nov 13, 2005 7:09 am Post subject: |
ill agree with lind's pervious post. its a bolt on item and you can change your mind no matter what.
nobody will know if the hatch is the og one that came on your bus, well almost nobody
why not repair and restore both hatches, then you can use either one, plus you will have an item thats very sellable, of course if it were me i would stash one away for a future project _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Wed Nov 16, 2005 8:32 pm Post subject: |
Here is what I am dealing with....
'61 Hatch
'61 Hatch bolt
'61 Hinge pin
'60 Hatch
'60 Hatch bolt/hinge |
Levonbenelli Samba Member
Posted: Wed Nov 16, 2005 9:04 pm Post subject: |
us the 60 hatch and keep the og around to resto, or pass on if you ever decide to sell the bus _________________ Wanted: flipseat parts: rear jump seat, folding chair, cups |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Thu Nov 17, 2005 8:21 am Post subject: |
The rubber buffers for truck gates look similar to those on the hatches. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
