casey79westfalia Samba Member
Posted: Wed Sep 24, 2003 12:08 pm Post subject: Transmisson whine |
My transmission is sounding rather noisy. The bus sat for a good amount of time before driving again recently. It is a growling nioise kind of sounds like gerrrrrrrrrrrrrr, errrrrrrrrrr. How do I go about having the fluid checked out. It does not pop out of gear or anything like that. |
Randy in Maine Samba Member
Posted: Wed Sep 24, 2003 12:32 pm Post subject: |
I think I would take it to my local garage or fix it guy and have him change the transaxle fluid. I think you can use something around 80 or 90W. I think I used 85-140 or something like that. Even if that doesn't help at least you will know when it was done last. Sometimes they get water in there for some reason. Don't let them overfill it.
Here is another thought....
sometimes the shifter will produce a vibration if the bushings are all worn out in there. VW spared no expense in coming up with the cheapest bushing they could find and they are just a little pathetic plastic thing. I bought a new kit from either the busdepot or busboys. Mine had a vibration in mostly 3rd gear and the new kit fixed it. There is a bushing that is always gone in the front and another one further back that you can get to. The other ones you can't get to without real work.
I think there is a better description of the fix if you go to the Archives section here or over to Type2.com. |
pogolo Samba Member
Joined: March 20, 2003 Posts: 76 Location: Austin, TX
Posted: Thu Sep 25, 2003 7:35 am Post subject: |
Is your bus fuel-injected? I mistook the sound of my electric fuel pump for a growling transmission. Otherwise....it's easy enough to drain the fluid. You just need a giant (14mm?) allen wrench. |
nothereanymore Samba Member
Posted: Thu Sep 25, 2003 10:20 am Post subject: |
It's a 17mm allen. Thje grrr noise: when does it happen? At idle in neutral? Driving in a particular gear? It could be a multitude of things from the shift linkage to worn gears, bad syncros to dry/worn cv joints. More info needed. |
Posted: Thu Sep 25, 2003 7:04 pm Post subject: |
It occurs when I am accelerating and if while I am accelerating I let off the gas it kind of jerks while slowing down makes a sound like "gererrrrrrr errrr errrr errr errrr with spaces in between the sound just like I said. Like its slipping and catching on and off. But the transmission responds and operates perfectly. I can definately feel the sound in the shift rod though. The transmission just sounds a little grumpy I dont feel it is bad for some reason. |
Posted: Fri Sep 26, 2003 1:44 pm Post subject: |
Oh. That could even be a lumpy burned flywheel/clutch scenario. I wouldn't like to steer you in the wrong direction, so maybe it would be better to have a mechanic to have a test drive. Good luck. |
Posted: Fri Sep 26, 2003 4:29 pm Post subject: |
doubt it. I just installed a new flywheel and german stock bus clutch. The sound is coming from closer than the flywheel |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Mon Sep 29, 2003 8:09 pm Post subject: |
After you change your transaxle oil ( GL-4 but NOT GL-5 ) adjust the nose cone mount. Loosen the 17mm bolts that hold the big metal plate and watch to see how much the transaxle drops as you take the plate off.
Loosen the 17mm nuts on the front of the transaxle and lower the mount assembly about 1/4", you'll see the old position "dirt-scribed", retighten and reassemble. As you tighten the 17mm bolts/plate, the transaxle will rise about 1/4" higher than it was. Now your shift rod will be stress-relieved and transmit less gear noise. You will also have a little less longitudinal movement when you back off the throttle. Try it. 10 minute job.
Colin |
