injector leak
thebluemule
thebluemule is offline
PostPosted: Sat Oct 04, 2003 12:07 pm    Post subject: injector leak Reply with quote
Hello...
i have a small pin hole in the rubber going from the fuel manifold to injector.........
is this all one piece? the rubber hose and the injector...
if so? how hard is to replace the whole injector.... does it just slip in....or do i need special tools to replace injector..................??
have located the pin hole...........but gone no further
thanx Samba friends
bobby joe
ratwell
ratwell is offline
PostPosted: Sat Oct 04, 2003 12:44 pm    Post subject: Reply with quote
Disconnect the metal fuel rail and pull it off the rubber. Use a rag to collect the gas that will drip out. Unbolt the injector from the intake manifold and you can remove it.
Cut off the old hose and replace it. Very simply procedure just be careful not to cut into the injector barbs and use proper 7mm high pressure fuel hose. The new hose will be very hard to put on. That's a good sign.
Replace any rubber orings that are cracked.
'78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ
