Tezza Samba Member
Posted: Sat Oct 04, 2003 1:11 am Post subject: Bowden tube |
OK, I've read all about these & think I understand the principle.
My bus has a terrible shudder taking off, less so if I let the clutch out quickly. There's no slipping & otherwise all is fine.
The local mechanic says it's an oily clutch plate...he may be right.
However before I go down that track thought I'd check out the Bowden tube.
Looked OK in situ, with more of a slight S bend than a bow. Took it out without any trouble...looks OK, no rust, no nothing.
I'm going to put it back in using some washer(s) on the male end, as everyone suggests.
My question is...can you put too many washers on?........should I just put one on & see how that goes, then add another if the shudder is still there etc, or should I stick 3 or 4 on straightaway to save time?
It may not solve the problem at all but worth a go.
What does the brains trust think???
Terry _________________ Life with a VW wasn't meant to be easy !
1976, 1600 Beetle ; 1973, 1700 Kombi |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Sat Oct 04, 2003 10:01 am Post subject: |
Make sure it is greased nicely inside the tube, a dry tube (whilst haveing the correct bend) can cause the same shudder as it hangs the cable up
I'd say depending on the thickness of the washers 2-4 if they are thin, or 1-2 if they are thick ( like the case half washers from a type1 engine which I use as they fit the male end of the tube perfectly)
For starters of course... you may need to mess with it several times to get it right/better. and if it is the disc it won't seem to have helped much!
ahhh the joy's of loving our old quirky cars eh? |
Tezza Samba Member
Posted: Sat Oct 04, 2003 6:23 pm Post subject: |
Thanks Keifernet
Will let you know how I go.
Terry
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Sat Oct 04, 2003 6:29 pm Post subject: |
"whilst"?
Been reading haynes instead of bentley, haven't ya? _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
nothereanymore Samba Member
Posted: Tue Oct 07, 2003 3:55 pm Post subject: |
Me thinkest so. More wine wench! |
