Stanagon Samba Member
Joined: July 11, 2003 Posts: 4186 Location: Boston, MA
Posted: Tue Dec 27, 2005 11:37 am Post subject: |
UZI wrote: |
langsmer wrote: |
Bias-plys are poop. They stoped making them for a reason! |
really? when did they stop making bias plys?
stan, congrats on the new bambeen! |
The '61 is rollin' bias plys. Pushed around by the OG 40-horse.
New bambeen is doing well and inspiring me to get this beast on the road in '06. Progress continues:
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Tue Dec 27, 2005 12:08 pm Post subject: |
When looking at the photograph, I noticed that the mudflap for the right wheel well is missing. Also, make sure that you remove the packing primer from the battery tray and treat the bare metal with something like metalprep before painting it. I put galvaprep on the bare metal after metalprep. It makes the sheet metal somewhat corrosion resistant, which is really needed on a battery tray. |
Posted: Tue Dec 27, 2005 12:49 pm Post subject: |
The mudflap is there now. It is part of the turkis clip.
Thanks for the suggestion re. packing primer on the battery tray. |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Tue Dec 27, 2005 12:53 pm Post subject: |
Congrats on the baby Stan. The bus is looking good. I agree on the bit with the paint on the tray. I painted over some of it on my rocker and it all peeled off. That stuff is junk. Sandblast it and POR it or something. ALso if you really cared about the VIN in the sheetmetal. You could stamp the correct number in a new peice of metal and weld it in. If done right you can make it look unmolested. Just an idea. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
BryanM Samba Member
Joined: June 14, 2002 Posts: 4212 Location: Concord/Charlotte NC
Posted: Sun Jan 29, 2006 9:32 pm Post subject: |
the bus looks great Stan. _________________ -Bryan
Motorwagen LLC
Concord NC |
langsmer Samba Member
Joined: November 18, 2004 Posts: 1127 Location: CO/NM border
Posted: Sun Jan 29, 2006 10:13 pm Post subject: |
UZI wrote: |
langsmer wrote: |
Hmm, looks like I spoke to soon!
Posted: Fri Apr 14, 2006 11:07 am Post subject: |
I hope george is either blind or using a hand held sheild. _________________ Why buy what you can build.
Rick Samba Member
Joined: December 17, 2003 Posts: 1539 Location: Soquel, California
Posted: Fri Apr 14, 2006 11:14 am Post subject: |
george is hardcore. The evolution of master welder who can look directly at the arc with no adverse affects. |
KombiMonster Samba Member
Joined: April 17, 2001 Posts: 2751 Location: Central Cal.
Posted: Fri Apr 14, 2006 11:37 am Post subject: |
He's using something...there's a red glow on him....hey Stanagon..you can get new caramel material??? _________________ FOOK CANCER
*WANTED* |
Braukuche Samba Member
Posted: Fri Apr 14, 2006 1:16 pm Post subject: |
You can tell he's been doing it for a long time as the skin on his gloveless hands have morphed into asbestos
--Dan |
obus Samba Member
Joined: March 08, 2001 Posts: 11070 Location: just off Garden State Parkway Exit 81
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Fri Apr 14, 2006 7:23 pm Post subject: |
Stanagon wrote: |
George is no apprentice, he's using the force, he's a metalmaster.
The orange glow is from my orange plastic worklight. |
he really should wear some goggles also. one errant spark can really mess up your eye. _________________ .
Wanted:
Posted: Fri Apr 14, 2006 9:36 pm Post subject: |
George was'nt welding just cleaning out his mig on Stanagon bus.
When He atacks my 52 that will be welding |
magic23deluxe Samba Member
Posted: Fri Apr 14, 2006 10:40 pm Post subject: mango |
the perception of welding on the mango is not valid there has to be metal to weld to, iron oxide really is only weldable after a lot of alchemy. and yea blind as a bat sam I am. don`t like those green eggs and ham! |
Posted: Fri Apr 14, 2006 11:00 pm Post subject: mango |
what Stan needs to do is buy a bunch of 1 inch plywood and build a box about four feet high around the bus then reinforce it with 4x4s next he has to line the double line the box with heavy plastic, next fill the box with water then pour all the lye he can acquire into the water . (the next part is where it gets dangerous) then add a couple of large stainless electrodes to the water. put a negative battery jumper cable to the stainless and then the positive to the mango. next pump as much dc into the jumper cables as he can afford for about a week. then simply drain the mixture of rust lye and water off and see whats left of the bus.
with any luck there will be something to start over the entire process with after he flips the mango onto its roof and repeats the above. |
Posted: Mon Apr 17, 2006 10:58 pm Post subject: rotted mango |
the 23 rolls and drives just fine I`m just not too crasy about driving it all over the place, maybe this year it`ll turn red an beige like it supposta be?
my personal choice was for it to be all white with blueish flames coming forwards starting at the back. I`ve still got to finish the custom interior also, as I haven`t found a full width camperseat old style for the back yet. and I`m still debating whether to install the stove sink and fridge out a vanagon. The good news is the the 81 is running fine again as the valves were not burnt just had a lifter problem. the lye is a base bath not acid. It also works with less caustic stuff like baking soda and washing soda. I have a tank for smaller parts, with baking soda its hard to hurt yourself playing with small pieces that are rotted badly. most badly pitted rot takes only a few hours to remove http://en.wikipedia.org/wiki/PH |
