dwill49965 Samba Member
Joined: August 08, 2005 Posts: 1396 Location: Dartmouth, Nova Scotia
Posted: Thu Jan 19, 2006 4:01 pm Post subject: Can anyone identify this voltage regulator? |
This voltage regulator is on my 78 Westy. It works fine, and charges my dual battery setup no problem. I'm just curious about the manufacturer, and what vehicle it may be from originally. Local auto electrical shops couldn't tell me, or identify the symbol or part number.
The wiring to it is that the light green wire goes to terminal 67, my blue and red wires are connected together and both go to terminal 15 (blue then goes forward to the alt wng light). The brown wire goes to ground.
_________________ Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A
Meyer wrote: |
Lastly, you just referred to US citizens as 'Americans'. Exactly what kind of Canadian are you? From what continent? |
Posted: Thu Jan 19, 2006 4:17 pm Post subject: |
Oops, I was so busy trying to get the images to work properly that I forgot to mention: 2.0 L, FI, with Bosch 70 amp alternator. _________________ Darryl
Meyer wrote: |
germansupplyscott Samba Member
Posted: Thu Jan 19, 2006 4:25 pm Post subject: |
i can't tell you what is supposed to be for, but it definitely is not for a VW Bus. _________________ SL |
VWBusrepairman Samba Member
Posted: Fri Jan 20, 2006 4:11 am Post subject: |
looks rabbit or some other water-cooled VW to me... |
VWGirl Samba Member
Joined: June 03, 2003 Posts: 2462 Location: Powder Springs, GA
Posted: Fri Jan 20, 2006 4:35 am Post subject: |
VWBusrepairman wrote: |
actually, all watercooled vw's should have internal voltage regulators as VW went to that in, I believe, 74? which is when they started producing the watercooleds. _________________ Without love in the dream it will never come true |
Posted: Mon Jan 23, 2006 11:28 am Post subject: |
Thanks for the suggestions everyone, and for the views. I'll keep using it until it craps out.
"If it ain't broke, I won't fix it." (intil I have to) _________________ Darryl
Meyer wrote: |
TheBeast Samba Member
Posted: Mon Jan 23, 2006 1:59 pm Post subject: |
Ya, must of came from here:
http://kalecoauto.com _________________ 1963 Anthracite Beetle 1776 w/ 34pict
1979 Bus Westfalia- Sage green w/ fancy stripes
1978 Bus - Sunroof model
1970 Beetle Convertible
1982 Rabbit Pick-up
1984 Vanagon Westfalia |
