Type 3 dropped spindles
Page: 1, 2, 3 ... 18, 19, 20  Next
Ollatron
Ollatron is offline
PostPosted: Mon Apr 11, 2005 3:02 am    Post subject: Type 3 dropped spindles Reply with quote
So who apart from Airkewled sells dropped spindles for early type threes then?
I need a pair asap.
Thanks,
Ollie
Cool
Mr. Bubblehead
El Chupa Nibre
Mr. Bubblehead is offline
PostPosted: Mon Apr 11, 2005 6:56 am    Post subject: Reply with quote
BerT3 make them. Try using
OGST
Samba Member #4862
Ollatron
Ollatron is offline
PostPosted: Mon Apr 11, 2005 6:59 am    Post subject: Reply with quote
Thanks, been talking to him also but he doesn't seem to want to give me a price.
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Mon Apr 11, 2005 8:35 am    Post subject: Reply with quote
If you're looking for something less expensive, you ain't gonna find it unless someone has a pair they are selling used.
There are physical limitations as well as safety factors that are involved with a dropped spindle -- it's NOT simply a matter of cutting it off and rewelding it!
If you want your car lowered, do it the standard way. If you have to lower it the geometrically correct way plus with the cool factore then the standard rule applies: You gotta pay to play.
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
Ollatron
Ollatron is offline
PostPosted: Mon Apr 11, 2005 8:41 am    Post subject: Reply with quote
Yeah thanks, but there's no need to patronise me, I know what I'm doing, I already run a juiced and slammed Notch, but I wanna go lower at the front.
And I'm not looking for a cheap way around it, I'm just looking for someone to actually give me a price.
Thanks.
Smile
73notch
73notch is offline
PostPosted: Mon Apr 11, 2005 4:14 pm    Post subject: Reply with quote
you can go as low as you want pretty much lowering it the standard way.
but
airkewleds are 200
berts are welded, and require more work, so they will cost more than 200.
those are the only 2 i know of.
SubyNotch.com is back up!
Notched
Notched is offline
PostPosted: Mon Apr 11, 2005 5:22 pm    Post subject: Reply with quote
Cut the bump stops. You can set it on the ground.
Harsh ride tho...
Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org
Notched
Notched is offline
PostPosted: Mon Apr 11, 2005 5:26 pm    Post subject: Reply with quote
I don't think ACN was patronizing (yank spelling) you. Just giving you some info.
Juiced? What does this mean? Big motor? Nitrous? or is this some sort of Monster Garage Notch that actually makes juice? (I like orange.)
No one makes a drop spindle for a Type 3 commercially, yet (that I'm aware of) - Ber and Airkewld (soon) are the closest you can get.
The only other alternative that I know of is the Type 1 beam that KCW builds for a Type 3 - then you can run any number of dropped spindles for a Type 1.
Phillip Bradfield
Ollatron
Ollatron is offline
PostPosted: Tue Apr 12, 2005 1:11 am    Post subject: Reply with quote
Thanks Philip, and apologies again to ACN, I was having a bad day yesterday... Smile
I meant juiced as in hydraulic suspension. Problem I'm having is that by using 6inch rams and not having dropped brackets, on full drop it sits on the fully compressed rams, limiting how low it will go, so I need the dropped spindles to give me the extra drop.
I could get the car lower as it's lowered 3 splines at the front... but that means no juice!
Thanks for all your help guys, much appreciated.
Ollie
BerT3
BerT3 is offline
PostPosted: Tue Apr 12, 2005 9:05 am    Post subject: Reply with quote
Info from my brochure:
Specifications:
- 42mm drop ≈ 2” drop (more at the fenders)
- Bearing sizes 17.5 mm and 29 mm + caliper bolt spacing of 56 mm (disc brake only)
- CNC machined on a milling cutter
- Spring pinned matched
- Welded after heating to ensure good penetration *
- Bolted through for extra strength (1 M10 + 2 M12 bolts)
- Stock speedo cable can be used
- New speedo cable grommet included
- Installation manual included
* Note that because of the welded design these dropped spindles increase track 10mm to each side
** Note that because of the bolt in ball joints, which are bolted from the bottom, it is impossible to achieve an even bigger drop.
The ball joints would hit the rim itself
Options:
1 Anti-bump steer bushes installed
2 Predrilled new brake dust covers
3 Media blasted + metallised before purchase
Prices:
- Complete: € 450 + postage
- Complete with option 1: add € 50 + postage
- Complete with option 2: add € 50 + postage
- Complete with option 3: add € 50 + postage
- Exchange: distract € 100 for 2 complete sets !
- Deposit required: € 250
- Postage in relation to location – weight: 10 kg
THE FITTER IS RESPONSIBLE FOR TESTING AND ENSURING SAFETY
Notched
Notched is offline
PostPosted: Tue Apr 12, 2005 9:55 am    Post subject: Reply with quote
I meant juiced as in hydraulic suspension. <snip> Ollie
No worries. Do you have any pics? Not too many Type 3's out there running hydaulics.
Phillip Bradfield
Ollatron
Ollatron is offline
PostPosted: Tue Apr 12, 2005 10:06 am    Post subject: Reply with quote
These any good?
Twisted Evil
type3nut64
type3nut64 is offline
PostPosted: Tue Apr 12, 2005 10:08 am    Post subject: Reply with quote
Did you extend the shock towers or ram towers? Sounds like the your torsion bars might be limiting you from full travel? I pulled my bars out and machined them down so there are no splines and I have full travel. Well as much as the ball joints will allow.
I have a set spindle on order from airkewld because my new ball joints are holding me about a inch from the ground.
Good luck.
Paul Davis
type3nut64
Air_Cooled_Nut
Nice details, BerT!
The First Invasion
Ollatron
Ollatron is offline
PostPosted: Tue Apr 12, 2005 10:21 am    Post subject: Reply with quote
Good luck.
Paul Davis
type3nut64
Thanks Paul,
Torsion bars all seem fine, like I said I think it's the rams which are preventing me from going lower as they're fully compressed, but there's more travle available in the rest of the set up.
I could go with shorter rams as an answer but then it'd cut down the amount of travel up front on full lift.
Cheers,
Ollie
spoon
Samba Penetrator
spoon is offline
PostPosted: Thu Jan 26, 2006 10:39 am    Post subject: Reply with quote
What's the word on the drop spindles? Ollatron, you still around?
Justin Razz
Pit Bull Myths, Busted!
http://www.badrap.org/monster-myths
Type 3 > Type 1
spoon
Samba Penetrator
spoon is offline
PostPosted: Thu Jan 26, 2006 7:40 pm    Post subject: Reply with quote
Nevermind, Pete ain't makin' 'em anymore.
Type 3 > Type 1
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Thu Jan 26, 2006 7:45 pm    Post subject: Reply with quote
did Pete make any? - last I heard, he was waiting to get enough commitments to build some...
póg mo thóin
Certified DHS Technician
Samba Member # 24517
Airkewld
Airkewld is offline
PostPosted: Thu Jan 26, 2006 8:49 pm    Post subject: Reply with quote
Just to clear up any confusion, I am going to call up each and every one of the people tomorrow who have placed a pre order with me regarding these spindles to make sure of a list of people who still want them. If by the end of tomorrow i do not have 50 preorders, i am scrapping the idea and refunding anybody who has pre paid. Tomorrow it will be one year from the original date when i started this list, and still i have yet to come up with 50 people who want to help out with these, pretty sad. But we will see tomorrow, i will post what i found out at 5:00pm. Talk to you then.
TheSamba members-only discount - TheSamba
FAQ - https://airkewld.co/FAQ
View our Industry Leading Products - https://www.airkewld.com/Products-s/2322.htm
We made a iPhone Ringtone with a Classic VW Turbo Engine - https://airkewld.co/RingtoneTurbo
YouTube Channel - https://airkewld.co/SubSamba
spoon
Samba Penetrator
spoon is offline
PostPosted: Thu Jan 26, 2006 8:52 pm    Post subject: Reply with quote
Fuck dude. I wish I had a credit card number to give ya Pete. I only have a money order... so let's hope he gets to 50. In Sept. he had like 43 I think...
Type 3 > Type 1
Page 1 of 20
