Steve22 Samba Member
Joined: March 05, 2004 Posts: 1389 Location: the wild unknown
Posted: Sun Jan 29, 2006 10:38 am Post subject: ideas on shortening the throttle cable? |
I need to shorten the throttle cable on my '73 super by about 1.5 inches to suit my dual carb linkage. Any ideas on the best way to do this? _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter |
volksfiend Samba Member
Joined: June 01, 2004 Posts: 283 Location: Mo....West of Mexico
Posted: Sun Jan 29, 2006 10:41 am Post subject: |
get the heavy duty multi strand throttle cable that is cut to length. Solder it where you need to cut it to keep it from unraveling....then cut with a good pair of side cutters. Otherwise there is a common kit available for shortening stick cables...but the heavy duty cables are really the way to go...buy once and forget about it for years. |
oldmanx Samba Member
Joined: January 28, 2006 Posts: 15 Location: New Lenox, IL
Posted: Sun Jan 29, 2006 10:49 am Post subject: |
I allways use a piece of heat shrink tubing on the end of throttle and clutch cables. It stops fraying and allows much improved grip where tightened at clamps, carb throttle or mating two cables together. I joined a shortened clutch cable a few years ago and have had no slippage. I do the same with my carb. |
Posted: Sun Jan 29, 2006 11:08 am Post subject: |
both excellent ideas... think I'll solder then heat shrink over it for now.
I found that a '68-'74 T3 w/FI throttle cable is the correct length (2610 mm vs 2642mm) any reason wht this cable wouldn't fit the super? _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Jan 29, 2006 1:37 pm Post subject: |
hmmm - my cable is a solid wire - just did it on mine. Had a brass tube slipped and crimped over the wire. I used a dremel to remove the old brass, Hit the hobby shop for new tubing and crimped it on. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
El Guero Samba Member
Joined: January 03, 2004 Posts: 1197 Location: I.E. Y-QUE
Posted: Sun Jan 29, 2006 8:22 pm Post subject: |
cb performance has a nice universal throttle cable that comes with either the early or late end that hooks up to the pedal you cut the end you dont need then it comes with a piece that you slip the end to and tightened down _________________ Praise the Lowered... |
Posted: Sun Jan 29, 2006 8:37 pm Post subject: |
No. 16 butt splices... hadn't thought of that, guess its a good thing I haven't had the chance to go back out to the shop yet. _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
