jcpatrickharrison Samba Member
Posted: Fri Feb 24, 2006 10:06 am Post subject: 1965 Bug Windshield Washer Questions |
My bug has a washer bottle with a long metal stem coming off it on one side and a black screw on top with a hose on the other side.
Here are my questions:
1. Do I just pump the metal stem with air at the gas station? If so, how much air do I put in?
2. It looks like the rubber hose from the screw cap needs to be replaced. Is this something I can just get at autozone... like a generic rubber hose product? If so, what size hose?
3. Where does the rubber hose hook up to once I replace it?
Thanks!
J |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
Posted: Fri Feb 24, 2006 10:26 am Post subject: |
The valve stem on the bottle is supposed to be connected to the spare tire valve via a short connector with a regulator. The washer is pressurized by the spare tire. once the spare tire pressure drops to 18psi the valve in the regulator/connector closes and wont let any more air out of the spare (so the spare will still be useable if needed). The hose connects from the cap on the bottle to the back of the switch on the dash. There is another hose coming off the switch that goes to the squirter on the cowl. I dont know the size of the rubber hose, but take a piece with you to the auto parts or hardware store.
BTW, the valve that connects the spare to the washer bottle is hard to find. I am looking for one myself. So for the most part, most washers on old bugs are just "decorative"! _________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Fri Feb 24, 2006 10:30 am Post subject: |
Although a lot of Beetle's windshield washer bottles are connected to the spare tire valve, 65's aren't. They have a bottle with a bicycle valve that is indeed filled up by an air pump. The owner's manual makes specific reference to it. I carry a bicycle pump in my trunk for this purpose. I just go by trial and error although there is a pressure label on my bottle but I don't remember now what it says.
Everything else 67 Florida said about how the system is hooked up is on the mark. |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Fri Feb 24, 2006 10:52 am Post subject: |
79SuperVert wrote: |
I stand corrected! I assumed the deal was the same on my '65 as '67 since the tanks are nearly identical. Not so, as I consulted the manual. It says fill the tank at the filling station to 36psi max (the bottle says 35).
Well, I learned something new !
-kent _________________ -Kent (BaT "daleallen")
Posted: Fri Feb 24, 2006 11:31 am Post subject: |
I always thought the hookup to the spare was a really bad idea - I'm surprised VW thought of it. Any leak in the system and your spare goes flat. Much better IMO to pressurize the bottle separately. |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Fri Feb 24, 2006 12:17 pm Post subject: |
Prior to 68 the spare tire hookup was an optional extra in the USA. It used a unique air tube with a circular valve in it. _________________ Midwest Autosavers, Inc. Woodstock, IL |
Juan Samba Member
Joined: September 01, 2003 Posts: 878 Location: Miami, FL
Posted: Fri Feb 24, 2006 1:29 pm Post subject: |
67 Florida Deluxe wrote: |
-kent |
whoa! me too! so wait, the windshield washer bottle has a bicycle valve and you're supposed to put air on that? i'm confused now. i guess if anything i'll read it in the manual later. |
Posted: Fri Feb 24, 2006 3:18 pm Post subject: |
Here's the bottle in my '67. It is identical to the one in my '65 except the label is yellow. You can see the air valve just to the left of the filler cap. That's where you would pressurize the container to about 35 psi with an air hose or the connector to the spare. If the regulator for the spare tire connector is working properly, it will cut off the supply from the spare at 18psi so the spare didnt go flat.
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Fri Feb 24, 2006 3:36 pm Post subject: |
A page from a 1963 owner's manual describes the stock system:
http://www.thesamba.com/vw/archives/manuals/63bugowners/page20-21.jpg
and yep, the hose that connects it to the spare tire was only an accessory. Some had a provision that had another tire filler valve on it that allowed you to add air to the tire without unhooking the hoses, others did not. The one shown in the old Bentley workshop manual has the extra fitting on it, I've not seen one of these in person:
The accessory hose that I have in my 62 is the other style.
-Andy |
DAM62BUG Samba Member
Posted: Sat Feb 25, 2006 5:12 pm Post subject: |
Put me on the list too!!!!! |
