llamas1 Samba Member
Joined: July 27, 2003 Posts: 237 Location: Houston, TX
Posted: Mon Oct 27, 2003 8:18 am Post subject: Strange sound |
While manually turning the engine I can hear a pssssss like sound from what seems to be coming from the #4 head. Is this caused by valves being too loose? |
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4848 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Mon Oct 27, 2003 8:33 am Post subject: |
You have 4 heads on your motor? Not really it's just squeezing the air and then letting it out. That's what it sounds like to me. Do a compression check to be sure. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Posted: Mon Oct 27, 2003 8:37 am Post subject: |
Correction, The #4 cylinder/side of the head. |
wgargan Samba Member
Joined: September 21, 2002 Posts: 871 Location: Dreaming of the Rockies
Posted: Mon Oct 27, 2003 8:38 am Post subject: |
I always get that sound when turning the engine over by hand, i think its normal. _________________ Current ride:
1983.5 Watercooled Vanagon 'L' Automatic transmission |
Posted: Mon Oct 27, 2003 8:44 am Post subject: |
I was hoping it's normal but It only seems to be coming from the compression of one piston rather than all four. I will definately get a hold of a compression tester. |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Mon Oct 27, 2003 9:10 pm Post subject: Re: Strange sound |
llamas1 wrote: |
I get that sound also. It changes over time and it migrates all over the engine. I do believe it has something to do with the way your rings rotate and occasionally line up and then rotate past that point. Not to worry.
Colin |
Posted: Mon Oct 27, 2003 9:17 pm Post subject: |
correct me if I am wrong, But your rings should not be rotating after they have set, right?
lc _________________ Current ride:
