Body came off the pan today. Check out the body dolly I made
Leonard Banks
Leonard Banks is offline
PostPosted: Thu Mar 09, 2006 12:23 pm    Post subject: Reply with quote
65kgcoupe:
I notice you have added a buildup to the cross member in the back. Why was that necessary and if it was necessary how much higher did you have to go so when I make mine I will just make the risers that high.
Now for a question in general.
What is the least amount of work needed to remove the body and can anyone give a quick step by step? 1) Remove XXX, 2) unbolt XXX, 3) disconnect XXX ......... N) Lift off body
Gary
Person of Interest
Gary is offline
PostPosted: Thu Mar 09, 2006 12:34 pm    Post subject: Reply with quote
Leonard Banks wrote:
65kgcoupe:
Leonard,
You have PM.
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
Bella Ghia
Bella Ghia is offline
PostPosted: Thu Mar 09, 2006 1:33 pm    Post subject: Reply with quote
Just a re-post to answer your question with some new info.
I would make the up piece 16" tall (extra 4" over the first 12" I posted). The extra 4" helps clear the lowest spot below the rear rocker and the from heater channel. At 12" it just clears on a flat floor, but on uneven floors or if you have mis matched tires it may not clear very well.
On top of the cross bar in the back you will need to add a 2"x4" laying flat. Lay it so it is on the outside of the inner rear fender just under the body mount. This will give you a place to bolt to the rear hi body bolting point.
The front body mount should bolt right up to the cross bar, no spacers needed.
Louie
1969 Autodynamics Caldwell D 13 Formula Vee 1969 Karmann Ghia Vert sold
http://www.thesamba.com/vw/gallery/pix/240775.jpg
kman
kman is offline
PostPosted: Thu Mar 09, 2006 2:17 pm    Post subject: Reply with quote
Ohhh. I'm going to build that for our project. Thanks for the repost.
Lee.
Samba Animal Controller
Lee. is offline
PostPosted: Thu Mar 09, 2006 10:33 pm    Post subject: Reply with quote
Here's the way not to do it........
Circular saw case as a floorjack extension.
I used the buckets to support the body so I could reposition the jack.
Thought I was home free.
Then the body fell onto the pan (wonder why)
Finally, with some help from a brick on the jack
www.DenverWildlifeControl.com
smuenchrath
smuenchrath is offline
PostPosted: Wed May 10, 2006 10:01 am    Post subject: Reply with quote
I plan on building the dolly based on the dimensions that Bella Ghia was nice enough to share in a few weeks. This will be used for my 68 Vert but we also have a 54 Oval that needs to come off the pan as well. Anyone know if the dimensions would be able to work for both?
baco99
baco99 is offline
PostPosted: Wed May 10, 2006 11:11 am    Post subject: Reply with quote
65kgcoupe:
Leonard,
You have PM.
oooh! PM me this info too!
westcoast-paul
westcoast-paul is offline
PostPosted: Wed May 10, 2006 2:15 pm    Post subject: Reply with quote
you = mr.safety
Ozzie
Samba Cone Slayer
Location: Bluffton, S.C. Living in the duality; a Grateful Skynyrd thang.
Ozzie is offline
PostPosted: Wed May 10, 2006 5:57 pm    Post subject: Reply with quote
Bella, that's awesome. I'm space deficient myself and your dolly just made the permanant file. Kudos. Very Happy
Oversteer is when the back of the car hits the wall...
delibessleep
delibessleep is offline
PostPosted: Sun Jul 02, 2006 10:34 am    Post subject: Reply with quote
This is an excellent thread. I am nearing a pan-off for my ghia, and this is very helpful.
My ghia's body is in reasonably good condition...no rot or cancer at the heater channels and only mild surface rust on the body. I have to replace a small section at the center rear bulkhead...near where the transmission cone is. other than that, it's pretty solid.
The floor is toast though...needs complete replacement. Oddly, this body has been off before. The body is a 69 on a 71 pan...many of the bolts securing the pan to the body were brand new...that is, where they decided to put a bolt...I think there were 2 holding the passenger side floor pan to the channel! none in the back by the shock towers, 3 in the back bulkhead connection...all came out with ease. the 4 bolts underneath the front bulk head were there, and loosened up fine...
I don't want to remove anything off the body I don't have to...such as the glass, etc. probably not a good idea, but my goal is to replace the floor boards, replace the entire brake system, inspect the body for unseen nastiness, hit everything with "rust bullet" or "POR-15" and get it back together quickly.
Anyway...to those that removed their Ghia bodies, what advice or step did you forget in the process, or any other "I would do it this way next time" information would you lend? I am planning to build the dolly today(very nice by the way.)
Also, I have new floor sections, painted the factory black. Obviously I want to cure these with rust proofing...should I blast the pans to get the paint off? What did you do?
Thanks!
63 Single Cab
87 Westy
18 Alltrack
Biology is destiny...choose your mutations carefully
VolksWatson
VolksWatson is offline
PostPosted: Sun Jul 09, 2006 7:45 pm    Post subject: Reply with quote
Are 4X4 boards a requirement? It seems like you could use 2X4s in some areas. I would think the legs would need to be 4x4s, where as some of the sides may be 2X4s... As you can tell I am not a structural engineer...
VolksWatson
stang68001
stang68001 is offline
PostPosted: Fri Apr 27, 2007 12:28 pm    Post subject: Reply with quote
awesome idea... I'm going to make one this weekend w some slight tricked out mods. If you make on end detachable, you can raise the rear of the body and slide the dolly in, then raise the front of the body and attach the front of the dolly. I have drawings but no clue how to post them. This makes it possible to lift the body with one person, no problem!! Solidworks renderings attached... yes i am an engineer and a proud nerd!
MYFIRSTCAR
MYFIRSTCAR is offline
PostPosted: Fri Apr 27, 2007 12:55 pm    Post subject: NICE Reply with quote
Great job. I like the idea of using wood. We all tend to think metal but wood does the trick and is easier to work with unless you cut it too short! Thanks for sharing and keep everyone updated!
stang68001
PostPosted: Mon Apr 30, 2007 7:59 am    Post subject: Reply with quote
Worked Perfectly! So with some minimal help from my brave wife (quickly moving underneath the car to put the last 4x4 in place, we perfected the 2 person lift using a partially collapsible body dolly. looking at the pictures, it almost make me want to put hydraulics on the ghia! (almost, but not enough)
I used 30" uprights and 4" heavy duty casters, which gave lots of clearance.
swhitcomb
swhitcomb is offline
PostPosted: Tue May 22, 2007 2:07 am    Post subject: Reply with quote
I made mine and put my Ghia on it last weekend.
Now I can get to working on the underside of the car again. Have a new heater channel to go in, and a new drivers rear fender to follow.
View user's profile Send private message Send e-mail Visit poster's website AIM Address Facebook Instagram Gallery Classifieds Feedback
dc2
dc2 is offline
PostPosted: Tue May 22, 2007 3:55 pm    Post subject: hi great idea Reply with quote
looks good ill have to build one of those now for my ghia resto. good luck
life is what you make it so make it good.
Gary '62
Gary '62 is offline
PostPosted: Wed Jun 04, 2008 3:04 pm    Post subject: Pan off restoration Reply with quote
Just had my ghia on the ramp the floorpan both sides heater channels and cills are shot, also the front and back of the pan where it meets the body, the previous owner sold it on to me with a line of partial restoration needed an impulse buy off ebay!! what can I say, always wanted a ghia so, on closer inspection its all or nothing.I have a 68 bug auto stick as a daily driver so the ghia is going to get the works, I have never seperated a pan and body before so could do with a walk through on the process has anyone got time to give me a tutorial?
thanks
Gary '62 ghia
hpw
hpw is offline
PostPosted: Sun May 31, 2009 2:08 pm    Post subject: Reply with quote
Something I found out about this wood dolly that others in the future may
want to know......I built mine in place on the car. It seems everyone was
building the frame and putting the body onto the dolly. But this is what I
did and it worked. Removed the front tires. drums/discs, motor/tranny
already out and horizontal 4x4's slid into place....then I lowered the pan
down instead of having to find others to help me lift the body. I was able
to do the whole thing by myself, except for a few minutes of holding the
long 4x4 with the dollies already bolted on. Clear as mud Question
http://www.youtube.com/watch?v=3SLIzSCt_cg&list=FLIX26sGa8__1F1loczLPTtg&index=2
jwold
jwold is offline
PostPosted: Mon Nov 11, 2013 11:17 am    Post subject: Reply with quote
Also keep in mind the wheels that are pictured in Bella's pictoral are pretty tall. I made a dolly recently but didn't realize (till now) that the body on the dolly wouldn't clear the shock towers, so I made my verticle peices 24 inches so I can roll the pan under the dolly, and will also make getting under the car for welding & repair that much easier.
motorhead364
motorhead364 is offline
PostPosted: Fri Nov 15, 2013 4:48 pm    Post subject: Reply with quote
Used your general dimensions and built mine. Couldn't find that big of a caster so I went with 5". I made my risers 2'. Rest is the same
Got some cleanup to do now so I can really get going
63 ghia coupe
Page 3 of 4
