Praise the lowered
mr69
mr69 is offline
PostPosted: Fri Mar 24, 2006 12:00 pm    Post subject: Praise the lowered Reply with quote
whats better airbags or hydraulics for lowering. i need to be able to clear a dip in my driveway but i want it lowered for crusing.
steven wood
steven wood is offline
PostPosted: Fri Mar 24, 2006 12:12 pm    Post subject: Reply with quote
it depends, If you going to run hydraulics, then you need to use accumalators so the ride isn't as bad. If you are in a cold climate then the seals in the cylinders go bad and the guides break. If you use airbags, then you can buy all of the parts and brackets already prefabbed through KCW. Even though hydraulics are Olde School, I would run hydraulics any day of the week!
thebucket
Samba Stockbroker
thebucket is offline
PostPosted: Fri Mar 24, 2006 12:46 pm    Post subject: Reply with quote
Bags imho
ITMC-El Presidente
OG 55 bullet 3 fold....
http://www.thesamba.com/vw/forum/viewtopic.php?t=150858&highlight=thebuckets++++fold
Notchback65
Notchback65 is offline
PostPosted: Fri Mar 24, 2006 2:46 pm    Post subject: Reply with quote
Get the airbags,because with hydraulics you need a ton of batteries.Do you really need all that clutter in a small space.
sled
sled is offline
PostPosted: Fri Mar 24, 2006 7:11 pm    Post subject: Reply with quote
you dont need any more than 2 batteries (24 volts) for hydraulics
you dont need accumulators for a good ride
if all you want to do is go up and down slowly to clear driveways and speed bumps then either will work just fine, take your pick
PM me if you want explanations and details of either.
67stang302
SBS Hit Squad
67stang302 is offline
PostPosted: Fri Mar 24, 2006 11:01 pm    Post subject: Reply with quote
anybody running bags with really high horse power? I have a project comming up and the curent plan is using a 300hp subie motor and I still want a lowered stance but like the idea of adjustability of bags.
Sorry for the thread jack
Hondaz rulez my lifez
SBSeven 1 YR and still going
59 Kombi laying beam
64 type 34
